Question about Exercise & Fitness
How do I remove Motor Hood from Smooth Fitness 5.25 treadmill
Took off the screws on the side of Motor Hood can't get the Hood to budge.
    New Friend:
  • 38 Answers
Sometimes there is a grab underneath with care should lift off
Posted on Dec 15, 2014
How to remove motor hood cover on Avanti treadmill 380
is simle only take out the screw in front and rear from the Hood cover there are screw with screwdriver or allen hexGod bless you
Apr 08, 2013 | Avanti Fitness AT380 Treadmill
How to remove motor hood cover on Avant treadmill 380
take the hood cover with screwdriver or allen hex in front and rearGod bless you
F63 sole treadmill, low speed error when inclined
If the calibration does not pass you may need to check the speed sensoralignment. You must understand the instruction for calibration is under the hood for motor.
1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
2) if the problem persist you must Test the main motor for open, ground 3) the main control board faulty. See the block diagram that I did as person like you that understand that 90% of functions the main motor controller board has effect.
good luck. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Dec 01, 2011 | Sole Fitness F63 Treadmill
95t black screen
Dear Sir:
Wacht this video:
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.youtube.com/watch?v=E-q-uS4t6so
1. Power
o 1 Ensurethat the treadmill is plugged into a grounded outlet using the correct surgesuppressor. Use a UL 1449 suppressor listed as a transient voltage surgesuppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure theservices of an electrician if the outlet is not grounded, or move the Proformtreadmill near a grounded outlet. Do not use an extension cord. o 2 Insertthe safety key fully into the display. Treadmills with keys are designed not toturn on without the safety key in place. o 3 Findthe circuit breaker on the front of the frame and make sure it is not tripped.The circuit breaker is a vertical switch on the 540S and a horizontal switch onthe 540 Interactive Trainer. Press it to the "Reset" position, whichwill be labeled.2. ReedSwitch
o 1 Unplugthe treadmill and remove the safety key. o 2 Movethe upright base of the treadmill down with the help of another person and liftthe uprights so that you can get to the underside of the console. Use aPhillips screwdriver with at least a 5-inch shaft to remove the screws. Thereare five hood screws on the 540 Interactive trainer and four screws on the540S. o 3 Removethe motor hood to get to the small reed switch by pivoting the hood off theframe. Find the reed switch and magnet, which are on the left side of thepulley for both models. o 4 Turnthe pulley with your hand until the reed switch aligns with the magnet. Thereshould be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inchby loosening the reed switch screw and sliding it to the correct distance. Tightenthe screw. o 5 Reversethe directions to put the hood back on and the treadmill upright in theoriginal position.Sincerely. God bless you.
E.CUADRA
Oct 28, 2011 | Life Fitness 95Te Treadmill
I have a Life Fitness 9100, and the display is dead, it worked fine the last time it was used two weeks ago. Thanks!
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
Adjust and clean very softly.
Oct 22, 2011 | Life Fitness 9100 Next Generation...
Our machine display show the following masage MOTOR CONTROLLER COMM DRD
two possible issues
one, unplug treadmill remove hood and make sure the main power connector to the motor control box is in properly then turn treadmill back on this has worked for me before
two , you have blown the overload resistor on the motor control board (mcb) to check this unplug treadmill and remove the steel motor control box from under the hood remove the motor control board from inside the box and inspect it for damage and /or electrical burn smell
if you find damage you will need to get it repaired contact glide fitness products in santa ana california 1866 637 4600 for all information including shipping . it cost $200 plus shipping which is a deal since a new one is $1000,i have many repaired by them
a common issue for the overload to blow is friction between the belt and deck board . if you have an auto waxer , the waxer nozzle is usually plugged . the nozzle should be cleaned once a month
contact glide for their non clogging wax to resolve this issue
good luck
Dec 26, 2010 | Life Fitness 95Ti Treadmill 95 Ti
I am having trouble removing hood/motor cover on Epic 550 treadmill. I have removed 4 - 3/4" screws from front panel and 2 - 1/2" screws from underneath. Still feels locked on. Are there other...
If you lift your treadmill deck up, you will find 2 screws underneath, on the side, towards the front. remove them and that should do the trick.
Nov 23, 2010 | Epic View 550 Treadmill
My smoothfitness 5.25 treadmill is stuck in the
Unplug your unit take the motor shroud off and you will see a circuit board (Motor Control Board) their should be L E D s on the board. Now plug your unit in and you will see these light up if you have a second pair of hands that can help you have them press you incline controls.
You should see one of these L E D s light up followed with a click of a relay this activate the incline motor some of these boards will have a 3 amp fuse to protect the board from damage , if you see a open fuse replace it with the same exact fuse. If it blows again either you have a shorted armature winding or the worm screw is frozen. I would call Smooth Fitness, depending wiether this was made by either Sports Art Fitness or Keys Finess they will direct you to theproper parties.
Mar 11, 2010 | Smoothfitness Exercise & Fitness
Thumping noise that increases with speed
OPEN MOTOR SHROUD SO YOU CAN BETTER INSPECT THE UNIT CHECK THE DRIVE BELT THEN I WOULD CHECK THE RUNNING BELT TO SEE IF THEIR IS ANY DEBRIS THAT THE BELT ITSELF IS SPLITTING SINCE YOUR SAY A THUMPING SOUND. SINCE KEYS FITNESS MADE THIS UNIT THEY ARE NO LONGER IN BUSINESS, BUT TREADMILL DOCTOR HAD PURCHASED THE PARTS. SO GO TO TREADMILL DOCTOR.COM THEY MAY HAVE THE PARTS YOU NEED
Mar 01, 2010 | Smoothfitness Smooth 5.45 Folding...
Exercise & Fitness Logo
104 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
