Question about Vacuums
I was just given one of these. After cleaning an entire room and going through the entire tank of solution the recovery tank was bone dry. is that normal or should some of the water have been recovered?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
Is it a carpet cleaner? If so, you should have dirty water (vacuumed from the carpet) in the recovery tank.
Most carpet cleaners have a transparent vacuum intake so you can see the dirty water going in as you pull back on the return sweep. Check for clogs or a broken belt. I advise against using you cleaner until the water pickup is repaired. Leaving water in the underlayment can cause mold,mildew and rotten floorboards.
I hope this helps. Good Luck!
Posted on Dec 15, 2014
micromaster
  • 3614 Answers
SOURCE: Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Posted on Jun 01, 2008
  • 37 Answers
SOURCE: Just bought a Hoover steam
you may have put the lid on your recovery tank on wrong. on some models you have to lock the front in first then snap it down in the back. if you can pull the lid away from the tank then its on wrong and isnt making a seal.
Posted on Sep 28, 2008
  • 17 Answers
SOURCE: recovery tank not filling
The tank has an automatic shutoff float (red) that will stop the suction if the water level gets too high. this can also happen if the tank is not level or clean as the float can bounce around and jam at the top. I've actually had this one happen). I would make sure the float is down during the cleaning and see if the suction comes back. if not, please provide more details and we'll get 'er fixed!
Posted on Feb 04, 2009
SOURCE: recovery tank not working
recovery tank empty where do you look to see where the hair ball is so i can clean it
Posted on Apr 04, 2009
  • 18 Answers
SOURCE: water does not go to the recovery tank at the bottom need help
You want to check the lid on the bottom on your tank. If you can stand in front of the machine, while it's in the upright position and pull on the lid, if it moves you have it on wrong. Try putting the lid on the front to the back, instead of back to front.
Posted on Jun 11, 2009
What setting do I need to have the machine on to **** up the excess water? I want to download the manual but can't seem to find a link to do so, how would I do that?
You should have the vacuum set to Wash/Rinse for all steps in cleaning. Press the trigger to release the cleaning solution and push the vacuum forward. With the trigger still pressed, bring the vacuum back towards you). Then release the trigger and again move the vacuum forward and then back. Repeat the "dry" strokes until the dirty water enters the dirty water tank. Watch the water going through the dirty water tank lid. Empty the dirty water tank if the suction fails or the tone changes. Do more dry strokes after cleaning the entire surface until you do not see more water entering the dirty water tank.
The manual is available from Hoover at the product site: http://hoover.com/products/details/f7411900/max-extract-dual-v-widepath-carpet-cleaner/ . The direct link is here: http://hoover.com/file/592/ .
I hope this helps.
Aug 08, 2011 | Hoover SteamVac F7411-900 Upright Vacuum
I just purchased a floormate. I can't seem to get it to spray cleaning solution.
Turn the cleaner off and then on again to determine whether the cause of no suction resulted from the activation of the automatic shut-off. There are two reasons a tank will automatically shut off. The first is if the recovery tank is full. Located on the lower front panel of the unit, the recovery tank can be easily emptied and replaced into position. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
Turn the unit on again and check the suctioning action. The second reason automatic shut-off could take place is if the handle was raised to an upright position while the motor was running. Should this occur, simply turn the unit off, wait a moment for the shut-off to reset, and turn it on again to continue cleaning.
  • 2 Make sure the filter and filter lid are properly positioned in the recovery tank lid. The cause of the problem could be that the filter or the filter lid were missing or were not in the proper position.
  • 3 Check that both recovery tank and/or solution tanks are locked in place and are positioned properly. The recovery tank is located on the lower front panel of the Floormate, and the solution tank is located in the front top panel of the unit. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
  • 4 Observe whether filter is dirty. If the filter is dirty, clean the filter by turning the cleaner off and disconnecting it from the electrical unit. Take out the recovery tank and lid. Remove loose debris from the filter by wiping clean with a brush or tapping the filter over a garbage can. After this is completed, the filter may be rinsed clean for additional cleaning and then air dried before returning the filter to the unit.
  • 5 Check that the nozzle is in the proper position and locked. Locate the nozzle underneath the suctioning base of the unit. Make sure the latches are out and line up the middle section of the nozzle with the opening of the cleaner. Hold the nozzle in place while simultaneously sliding the latches inward to lock in
  • Mar 07, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
    Hoover steam vac doesn't pick up all cleaning soluation when cleaning carpet? I have clean both filters
    Please look to make sure the rubber ring gasket is still in place under the recovery tank. The tube on the bottom of the recovery tank must seal to the rubber ring to get suction.
    Dec 29, 2009 | Hoover SteamVac F5914-900 SpinScrub...
    Hoover steamvac not picking up water
    you don't have the recovery tank lid on correctly.
    Jul 19, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
    Recovery tank not filling
    Feb 04, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
    Bissell ProHeat 7901 will not **** up water
    Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
    Bissell Proheat Upright Wet/Dry Vacuum Problems
    heatman101
    adfa
    Nov 11, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
    Just bought a Hoover steam vac. Did the dining room. everything okay.. emptied recovery tank and replaced. started on living room. dirty water not going into recovery tank. carpets very wet. What did I...
    Sep 27, 2008 | Vacuums
    Water?
    There are two tanks on that machine. The lower tank is the recovery for the dirty water and the upper tank is for the clean water solution. You mix the detergent with the clean water and away you go.
    Feb 08, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
    Soap not dispensing
    Hi. Try it just using cold water only. If this now flows ok the water you are putting in to tank is to hot causing pressure to build up in tank which which causes the plunger to not be able to push hard enough against valve in the tank.
    Sep 03, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
    Vacuums Logo
    63 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
