Question about Crosley CDE6000 Electric Dryer
I have a crosley ele. dryer, push start and will only run a few seconds then cuts off, whats the problem?
  • 40 Answers
You may have something is jamming up like a tight roller, torn felt seal or may be something stuck in the blower. If all parts mechanical look good then you have a bad motor.
Posted on Dec 15, 2014
gittos73
  • 244 Answers
SOURCE: Crosley dryer
right the part that is faulty is a silver tube which is fastened to the motor take it of making sure you have done a diagram of the wiring replace it once replaced the dryer will work fine common fault on these dryers its just wear and tear m8
Posted on Nov 17, 2007
  • 91 Answers
SOURCE: Crosley Electric dryer stopped in mid cycle and will not start
if the machine is completly dead an not doing anything locate your fuse panel ,check your fuses for the dryer ,if you can find wich one is it reset the breakers again you probably popped one of the 2 lines since you need 2 for a 220v.
good luck!
Posted on May 27, 2009
  • 97 Answers
SOURCE: Crosley dryer Cdes563sq0 if i turn the timer on
It sounds like there is a problem with the motor/belt. If you can get the top up, mine you have to push in two clips between the lid and the body about two inches in from the right and left sides, you can look down into the machine to see if the belt is still on track or if the motor is turning. I had one dryer that the belt would come off the spring tensioned idler pulley. Best of luck
Posted on Mar 21, 2010
heatman101
  • 43501 Answers
SOURCE: MY CROSLEY DRYER WILL NOT
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
heatman101
  • 43501 Answers
SOURCE: my crosley dryer will not start when pushed, the
Dryer Repair - The
Dryer Repair - The
heatman101
Posted on Dec 05, 2010
My dryer cuts on and then off I have by passed the thermal cutoff fuse and the door switch it will turn on when I plug it back in and run a few seconds and then cut off please help
does it run as long as you keep the start switch pushed then stop when you let go of button if so bad centrifugal switch in drive motor
Feb 20, 2015 | Dryers
My dryer will not tumble when you push the button it lights up and the heat comes it won't start
Do you hear the motor running? If so, then it's likely the belt or motor coupling is broken, or has somehow come disconnected.
If the motor's not running, then it needs to be checked by a technician. But If you have a warranty, then just contact them to do the repair.
Jun 30, 2014 | Crosley Dryers
Crosley model ced5563rq, checked continuty on limiter fuse, door switch, off/on switch, checked heating coil, hi/low thermostats, circuit breakers and voltage. all seem to be ok. the dryer will not start....
What you still the actul circuits on the timer,the thing that can make a dryer not start are things you hav ealready checked plus also the timer&motor,and perhaps a belt switch i could not find your actual model number to see if it has a belt switch but lots of brand use a switch that cuts motor curcuit when belt is broke, but as i said it also could be timer or motor
GENE
Aug 17, 2011 | Crosley Dryers
MY CROSLEY DRYER WILL NOT COME ON. IT WAS WORKING FINE AND NOW WHEN I PUSH THE START BUTTON NOTHING HAPPENS.
heatman101
Aug 28, 2010 | Crosley Dryers
My dryer works but does not heat
ihave a crosley ele. dryer works will not heat take out the drum or take the belt loss and it heats
Apr 08, 2010 | Kenmore Dryers
My crosley dryer will not start when pushed, the timer starts, but no power to start dryer
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 11, 2009 | Crosley CDE6000 Electric Dryer
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 62972 ele dryer
THERE IS A SMALL RELAY THAT THAT BUTTON ACTIVATES ... THE RELAY SOUNDS LIKE IT IS BAD. BEFORE REPAIRING I WOULD HAVE A "FIXED-FEE" DIAGNOSTIC TEST DONE. USUALLY 30-50 DOLLARS. THEN THERE IS THE REPAIR COST. IS IT WORTH IT?
Apr 28, 2007 | Kenmore 62972 Electric Dryer
Crosley CDE6000 Electric Dryer Logo
71 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
