Question about GE Kitchen Ranges
At work we have molder ge drop in stoves and we are getting error codes f3 f4, then oven turns off
  • GE Master
  • 1,253 Answers
F3 and f4 are temperature sensor faults. check the thermometer sensor in the oven.
Posted on Dec 15, 2014
My oven displayed F5 then F3 code I believe after a nearby lightning strike, When installing new sensor with supplied wire nuts I found black marks on oven side connector. Immediate F4 error code when...
When checking the sensor it shouls be checked at room temp (even if power off) at it should be between 1060-1100 ohms at room tempature. 16 ohms the new sensor is shorted the F2/F3/F4 all relate a faided sensor and the F5 error code says the clock (electronic oven control) is defective.
Test the sensor again at room temp...if only 16ohms its no good and will throw the F4 code everytime again a good sensor measured at room temp should be between 1060-1100 ohms
GENE
Sep 06, 2011 | GE JTP15 Electric Single Oven
GE single oven with touch pad settings. Getting error code F-4 after selecting any bake or broil function keys. Oven light works, fan for convection oven seems to be working. Makes no unusual noise. will...
Hi, the F2 error code means that the oven is overheating for an unknown reason. F3 and F4 indicate a problem with the oven sensor, which usually requires replacing the sensor.
Jan 21, 2011 | GE Ovens
Error code f3
F3
or
F4
Open or shorted oven temperature sensor
(RTD) Check sensor harness and harness connection between
oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is
ok.
Dec 16, 2010 | GE JGRP20 Gas Single Oven
My ge oven model # J RSO4BOW3 is showing a error code F3 and F5
F3
or
F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC).
Oct 30, 2010 | GE JRS04 Electric Single Oven
Kenmore Gas Range model # 362.75491990 F3 error Oven will not hold temp - error message displays and beeps I Replaced the oven temp sensor same issue Is the control panel bad?
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect.
these are some other code error that will help you in case of next time.
  1. Step 1 Press "Off/Cancel" (or "Cancel/Off" depending on your model) to clear the error code. Note the code if it reappears.
  2. Step 2 Replace the touchpad if the code displayed is "F0," "F7" or "F10." A function key is stuck or shorted.
  3. Step 3 Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
  4. Step 4 Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
  5. Step 5 Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is the main control unit. "F5," F6" and "F8 are codes that indicate problems in the ERC functions.
  6. Step 6 Inspect the door-lock assembly and circuit if "F9" is displayed. The door must lock when the oven is in use. If the lock mechanism is not functioning or if the detection circuit is malfunctioning, the stove will display "F9."
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
"F3" codes mean your oven temperature sensor has failed or shorted out. The only thing you can do is to replace the sensor.
Take care.
May 11, 2010 | Microwave Ovens
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Older Ge F4 error Code
Your oven temperature sensor is bad and must be replaced.
Feb 28, 2009 | GE JTP85 Electric Double Oven
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
100 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
