Question about Jensen Vm9215bt Vm9215bt 7 Widescreen Bluetoothmultimedia System
I have a Jensen wm9215 radio,microphone won't work on bt
Radio won't key up
Microphone or output circuit problem are most likely---The 25 is a fairly trouble free radio.
The microphone is the most common issue--broken wires inside the plug connection or a broken wire in the cable up to the microphone head.
Dec 21, 2012 | Cobra 25 NW LTD Classic Purist Mobile CB...
Wiring diagram for cobra 29 ltd BT mic , when each color go
if you have another cobra mic that was previously used on a 29 it should fit . just about all 4 pin cobra mics are alike .You can even use them on Galaxy radios and others.
Jul 27, 2012 | Cobra Radio Communications
I have a Cobra 29 WX NW BT and i can not receive any transmisions unless the other CB user is right beside me. If they move more then a car lenght away i can see the signal come in but no voice. Also my PA...
You have a bad microphone. There is most likely a broken wire in the microphone jack.
Without a microphone the radio will not go into receive mode, at all. Same thing happens when there is a disconnected wire in the mic cord. Because the radio you have, has Talkback in it, you can always hear a little audio coming through, but not a lot.
Try a new mic or one you know is good.
Jun 11, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
No sound microphone does not work
Check the audio drive maybe are lost when you change the sistem
Apr 23, 2010 | Jensen JMP-13A Consumer Microphone
Electrical connector
Go to the Jensen Website and call up their technicians they might sell you a radio harness for like $10- $20 Most retailers won sell you a harness for each radio has its own and no extra. Or you can try to find a broken similar Jensen radio and unplug its harness or go to Best Buy roadshop where they install radio's and they may have a spare jensen harness.
Apr 05, 2010 | Jensen VM9510 Car DVD Player
I purchased a s500 Talk-Back speaker. There was not paperwork included with the speaker. Which wire is the PA. I am thinking it is the small red wire. Also: in order to use the Blue Tooth function of the...
It is the small red wire that goes in the PA, or you can just ground this wire. The bluetooth will work through the stock microphone.The external mic is for handsfree use.
Jan 15, 2009 | Cobra 29 LTD CB Radio
Jensen mic (JMP12) won't work on my Dell/Vista laptop
hi what it comes to me if you have a driver to install it and dont work ....check this the plug may not getting contact right or the positive is no ground or reverse.......saludos
Nov 18, 2008 | Jensen JMP12 Consumer Microphone
Jensen Vm9215bt Vm9215bt 7 Widescreen Bluetoothmultimedia System Logo
41 people viewed this question
Top Jensen Video Cameras Experts
Are you a Jensen Video Camera Expert? Answer questions, earn points and help others
