Question about Sony Playstation 3 (PS3) Console
My ps3 home-screen won't pop-up.
After it goes through the motions of making sure the data hasn't been damaged, it gets stuck on the first screen shown.
    Master:
  • Sony Master
  • 665 Answers
Do you mean the "Disclaimer" screen? You may have a bad hard drive, and need to replace it. Sometimes the automatic repair can't help.
Posted on Dec 22, 2014
3 Suggested Answers
ccarmac1
  • 199 Answers
SOURCE: my ps3 has an erra
follow this guide,
http://community.us.playstation.com/thread/466287?start=0&tstart=0
or to save your self the headache then buy a hard drive at your local electronic shop, they cost around $30 for the same GIG storage or you can buy your self a bigger one too
www.1RepairStop.com
Posted on Sep 20, 2011
SOURCE: ps3 won't work, screen says restore software
take out ur harddrive, turn ps3 on wit no hardrive den put it back in and turn on again,
if this dosent work hold power button and eject button on front of ps3, 1st u will hear 1 beep then 2beeps ,wen u hear 2 leave go,
it will say connect controller with usb, do that and u will get 6 options,
pick option 3,but if that dosnt work pick option 6 ,but option 6 will delete all ur saved data so be warned.
Posted on Nov 25, 2012
E Motion LCD TV Model X26/29E won't turn on - seems stuck in standby (red light on). Remote control is OK.
My sisters e-motion lcd tv is locked in, standby mode. I think that replacing the psu (power supply unit) is the answer. but be careful of introducing static damage to the components as you can cause latent component damage and then future repair is not so easy to locate! always make sure that you fault find using the proses of elimination ie start from the begining !! Make sure you have a 240v supply going in and then probe for your outputs.. If your out put measurements are ok then you can eliminate your power supply unit as your problem circuit .....
Dec 05, 2012 | Televison & Video
Knocking sound under rear of 1980 corvette.
If the sound changes as the car goes quicker I would open up your diff cover and take a look inside for any damage along with making sure that your pinion hasn't loosened over the years.
Oct 23, 2012 | 1980 Chevrolet Corvette
My computer won't start
this is usually due to a ram fault or some other physical error. check and make sure the ram hasn't popped out of place by unscrewing the panel on the bottom of the laptop
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Jul 18, 2012 | Computers & Internet
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
2002 chev pu heater won't change to a/c -blows hot air all the time
The first thing to do here is have the AC system checked to make sure your refrigerant hasn't leaked out due to a failed seal or damaged condenser core.
Jun 11, 2012 | Cars & Trucks
Trunk won't open
can you access it from the back seat.? you might have to remove the bench seat and then the back rest to shine flashlight to see if indeed something is jammed in the latch.
Aug 12, 2017 | 2007 Chevrolet Corvette Convertible
Why does my aspire laptop loose data while writing in word. and other sites
sounds like there's something messed up with your delete key, pop the key off and double check for debris, and make sure the rubber boot isn't worn and stuck down. if it's stuck popped in just pop it out and try again, if it's worn you'll need a new boot. be careful you don't pull the scissors apart when you pop it off. if you do it can become a pain in the **** to put back together. you can also get a qtip and some alcohol and clean the contact before putting it back together. good luck
Feb 27, 2012 | Acer Aspire 7741z
Is there any way to set up a mobile carrier on Motorola Defy
From any home screen, go to 'Menu > Settings > Wireless & networks > Mobile networks > Access point names'. Once there, tap 'Menu > New APN', according to your carrier's data, fill in, at least, 'Name', 'APN', 'Username' and 'Password'. If your carrier has given you additional data, you can fill other fields there too, if you wish so, and know what to fill in, that is. Once finished, tap 'Menu > Save', and press the back button as many times as required to take you back to the home screen.
Now you must make sure the mobile data flow is allowed. Again, from the home screen, go to 'Menu > Settings > Data manager (in some builds, it will appear as 'Battery & data manager') > Data delivery', and make sure that 'Data enabled' is checked. If you want your mobile data plan always active, activate 'Background data' too. If your data plan is valid outside your town, you can also set 'Data roaming'.
Hope it works for you.
Anyway, please, let me know if you need further informations.
Regards,Carlos
Oct 31, 2011 | Motorola Mobility Defy Cell Phone
Ps3 has madden 12 stuck inside and when i power it up it turns off after 2 seconds.
Is your PS3 hot? If the PS3 system gets to hot I know it has a few issues starting/staying on. Leave it off for a bit and let it cool down. Make sure it's in a well ventilated spot and clear any dust off it and the surrounding area. Then try to turn it on again.
This is a weird fix, but I've read of some people finding success by removing their hard drive and turning the PS3 on without one in. You won't be able to use the PS3 in any meaningful way, but you might be able to eject the disk. Here's a nice guide to removing it. Afterwards put the hard drive back in and hope for the best.
You could also try booting into the recovery console, but if it won't turn on for more than 2 seconds you might not be able to get to it. Still worth a shot though.
1) With PS3 console off, hold power button until it turns on then off.
2) Release power button, then hold again until you hear 2 quick beeps, then release.
3) If, somehow, the console is on at this point, try ejecting the disk.
4) Follow instructions (connect controller), then just try the different options, starting with 1 and working your way down. You should know that option 4 (Rebuild Database) might delete some of your saved data, and option 5 (Restore PS3 System) definitely will.
I've actually gone through the same situation myself when I first got my PS3; I got the disk out by just constantly hitting the eject button. Randomly it worked and popped out, but I was still unable to turn it on for more than 2 seconds. I ended up having to send it in for repair which might be what you need to do. Here's the link to their service/repair website. It's not a fun process; if you're out of warranty it costs $100-$150, and either way it takes at least 3 weeks and you'll lose all your saved data. I remember the questionnaire asks if a game is stuck in the console or not, but I'm unsure as to how reliable they are at returning it.
In case your system is flashing any lights that may be useful, here's a link to what they mean. Not listed is Solid Yellow, which generally is referred to as the Yellow Light of Death (YLOD). If your console has that you're definitely sending it back to Sony.
Hope you're able to fix it!
Sep 02, 2011 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
