Question about PIAA 2008 Chevy Uplander - All Uplander models - Xtreme White Bulbs
WHY DOES MY ALARM GO OFF WHEN I TRY TO UE MY REMOTE START
THE LOCKS WORK BUT WHEN I PUSH REMOTE START THE ALARM SOUNDS
    Sergeant:
  • 470 Answers
Most of them do come on for a couple seconds and shut off
Posted on Dec 18, 2014
Disable factory alarm
You are not able to disarm the factory alarm on this vehicle. You will need to have it diagnosed. But the issues sounds to me like the key fob is bad and needs to be replaced
May 19, 2014 | 2007 Kia Spectra LX Sedan
Where is the fuse box on my '99 Durango SLT 5.2?
. most likely you need to change the remote battery. It's responcable for many things working correctly. my daughters car locked on her and the alarm sounded and had to disconnect battery in her car to get alarm to stop. when a theft is in process the vehicle takes over and don't allow it to crank and the radio also stops working along with other things. so try battery first in remote.
May 02, 2014 | 1999 Dodge Durango
How to program a remote control viper 5900 for a chevy Tahoe
Should be a switch for overriding the alarm under the drivers side dash. Two wires going to it (grey black) with a push button on the end if it. Have the driver door open and turn the ignition to on not running,,,, push the valet button and let go and then push and hold valet button........ Hit lock on the transmitter one time while still holding the valet button down. You should get a chirp for entering program and then when you lock on the remote it will make another chirp. But the chirp will sound awkward. Let go of valet and and turn truck off. And test remote. If that's doesn't work you may need to follow all the same steps but instead if press once and press and hold you will need to push 8 times and hold on the 9th and hit lock on the remote. I'm pretty sure the it's sequence is for alarm security and 8 steps is for remote start only models. Food for though if my mind is working backwards. Best off luck. All else fails I'm sure a shop will do for about 20$
Oct 28, 2013 | 5900 SST 2-Way Security System / Remote...
Truck won't start yet again - locked up/disabled
Check for other ground wires. That's the cause of most problems. Clean Battery post (+ and -) and trace them as far back as you can making sure they are tight and clean. Check fuses, make sure wires are tight on the starter. If that does not work take and unplug every wire on alarm itself. If she moves the seat up check near the brake pedal and look for bad connetions.
Aug 05, 2013 | 5303P LCD 2Way Security System with Remote...
I bought a Chevy Trailblazer, used, had keyless remote access Viper Alarm after manufacturer. Had trouble with transmission and alarm....took to Chevy dealer they replaced transmission. Now the remote...
You need to find the black push button called the valet button. That is the overide. Get in the car turn the key to IGN as the alarm is going off and then you have either 5 or 10 seconds to push that button once and then 2-5 seconds later the alarm is shut off. To put the car into valet mode which means no alarm at all you put the key to IGN push that button once then pull key out at which point the blue light should turn solid blue.
Or option two is you open a door and hit the lock, then unlock, then lock button again on the remote and the blue led will be solid which means no crazy alarm.
Mar 08, 2010 | 2004 Chevrolet TrailBlazer
Alarm goes off when trying to remote start my o 06 malibu was up!!!
i hav same problem chaged battery noticed battery holder was loose so i soldered it very carefully everything works fine xcept remote start alarm just goes off like when you push the panic button not sure what happened dont think i shorted out the circuit board in the fob if engine light is on this car wont start via remote these remotes must b progamed by dealer or pro shop prob using what they call a tech II computer to remote start you hav to press lock button 1st even if car is already locked i figured this out pess and hold lock button then press start alarm dont ring and the car starts.
Jan 13, 2010 | 2005 Chevrolet Malibu
How to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Nov 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Remote starter does not work but will unlock and lock doors.
depending on your alarm which it sounds like a viper model maybe? on my 02 you have to incorporate a factory alarm bypass module in order to be able to start the truck, they run about 100.00 bucks and have to be profssionally installed. The truck wont start because the computer isnt recieving the proper starting sequence due to the factory alarm
Jan 11, 2009 | 2003 GMC Sierra 1500
CHECK ENGINE LIGHT
Any time the Service Engine light comes on the remote start is disabled for the engines safety. As far as the SES light, your dealer should be able to help you with the diag.
Nov 17, 2008 | 2008 Chevrolet Hhr
PIAA 2008 Chevy Uplander - All Uplander models - Xtreme White Bulbs Logo
64 people viewed this question
Top PIAA Optics Experts
Lawrence Oravetz
Vernon Taylor
Are you a PIAA Optic Expert? Answer questions, earn points and help others
