Bose sound system for my omega .audio turns on sometimes when ignition is turned on when I start the car it cuts out again and won't play anymore ? All fuses are fine!
Vauxhall omega Bose sound system keeps cutting out when car is started!?
check where you have the power supply for the system as it may be from the start side of the ignition and not from the accessories side of the ignition
Dec 14, 2014 | Cars & Trucks
Amp fuse keeps blowing when car is turned off
It sounds like that fuse is supplying power to more than just the amp and is being shorted out in the START mode. Normally I would think the power to the sound system would be cut off by the ignition switch in the START mode. Try to find out what else that fuse supplies power to. You can disconnect suspected trouble areas to see if that helps locate the source of the fault.
Feb 16, 2013 | GMC Cars & Trucks
My remote will not cut on my Bose Cinemate system. I have changed the batteries in my remote and the red light on the receiver is illuminated, so I know the system is operational, . I've also unplugged...
It seems to be a common misconception that the remote is necessary to turn a device on. All devices have hard-wired power controls. Does THAT work? It is unclear which device (remote or the Cinemate) is malfunctioning. If the Cinemate won't turn on by its own power switch the remote won't magically bypass whatever the problem is.
The Cinemate Manual offers some steps to take if it won't turn on, as well as other guidance.
Bose.com
Jul 31, 2011 | Audio Players & Recorders
My Bose Wave radio/cd won`t play cd`s anymore. The radio works great. The cd player worked tonite, the would stick in a certain part of a song. Very intermittent. Now tries to read the disc, then says disc...
"I`ve used an aerosol air can to clean thru the cd slot"What type? not an "empty" can of paint, hairspray, chemical of some sort i hope. Compressed air at most I hope. If not, that's your Bose out the window!
The lense sounds like it needs a clean, you can buy these in disc for with tiny brushes on. Made by BIB and Allsop amongst many brands
Aug 30, 2010 | Bose Wave Music System CD Shelf System
I have a lexicon omaga drive but when i hook it up its like i need a 64 bit driver
Don't know what OS you're running. Omega has published drivers for Vista and 7 64-bit versions. They say they don't support XP 64, but when I hooked my unit up to my computer and the hardware install wizard came up the OS found and installed Microsoft published general USB audio device drivers for all inputs, midi, and mac USB channels of the Omega, and automatically set it as my default device. I hooked headphones into the Omega unit and could hear system sounds. So far so good. Went to My Music and fired up an audio file. Windows Media Player started up and the song started playing but I couldn't hear anything. Opened the same file with Audacity, could see the VU meters bouncing, but still no sound in my headphones. Went in to the preferences of Audacity, and manually set the speaker default to the Omega mac USB device. Hit play again and voila! I had sound. Closed the file, started WMP manually, went in to options, and again set the speaker default to Omega mac USB. Opened the same audio file and this time it played just fine. The driver files Windows used for my card were
C:\\WINDOWS\SysWOW64\ksproxy.ax, C:\\WINDOWS\System32\drivers\ks.sys, C:\\WINDOWS\System32\drivers\ksthunk.sys,
C:\\WINDOWS\System32\drivers\portcls.sys,
C:\\WINDOWS\System32\drivers\stream.sys,
C:\\WINDOWS\System32\drivers\USBAUDIO.sys,
C:\\WINDOWS\System32\ksproxy.ax,
C:\\WINDOWS\System32\ksuser.dll,
C:\\WINDOWS\System32\wdmaud.drv,
all version 5.2.3790.1830
Hope this helps everybody else with this problem.
May 21, 2010 | Lexicon Omega Pro Studio External Sound...
Can't get video to work so bose works with tv sound
We fixed it. We had everything hooked up right, but - stupid us - we didn't turn the sound off on the TV. Once I turned the TV's sound setting to off, I flipped the speaker switch a few times on the Bose remote, then turned up the volume on the Bose and it worked.
Sep 19, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Popping noise and cutting volume on Iphone
i have the same problem. I started after an iphone software update.
Jun 15, 2009 | Apple Bose SoundDock Series II Digital...
BOSE LIFE STYLE SYSTEM SOUND (AUDIO) GOES QUITE FOR A SECOND
This was posted a while ago, so I'm sure it's probably been solved by now. For anyone with audio issues using this or any other Lifestyle system: If you experience audio problems (no audio, intermittent audio) from more than just 1 source (especially if it involves internal sources like DVDs or the radio) then just reset this by unplugging the power for about 30+ seconds from the bass module and the media center DC power. Check the audio input cable (multi-pin din going from the media center to the bass module) for bent pins.
If this doesn't solve the problem, you could try replacing the input cable, but those are usually pretty robust. You could call Bose at 800-367-4008 for tech support or to set up a repair if this fails.
Dec 14, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
Sound keeps turning off
We had the same problem, we unplugged and re-plugged in the Bose unit and the sound problem stopped!
Apr 09, 2007 | Bose 3·2·1 II System
51 people viewed this question
 Grubhead
Grubhead
