Question about Toys
Where can I buy parts to repair a maistro Christmas musical carousel?
Mr christmas carousel lights above each horse won't turn on
i would check any bulbs it might have some times it only takes one to blow to stop the others working.not saying this is what is going on with yours .
Nov 30, 2016 | Washing Machines
Hello, my name is Susi & I live in the UK. At Christmas 17 years ago I bought a Maisto Santa's Carousel Park. But 12 years ago I lost the adaptor that came with it. I asked ppl & tried other adaptors but...
Maplins sell an adapter that has multi-voltage settings and a whole array of connectors, I'm sure they have what you require. Check online, they have a questions part too that is usually very helpful. Find an adapter on the site and you can ask a ? about it... and get an answer too ! .... Good luck... Red.
Dec 03, 2014 | Computers & Internet
MR. CHRISTMAS CAROUSEL WON'T TURN
I realize this post is way old, but wanted to thank LtJim for his description on how to take it apart.
It turns out the reason mine was not spinning is that one of the plastic mechanisms that make the horses go up and down (located under the main piece that comes off with LtJim's directions) had partially broken and that horse would go all the way to the bottom and then the carousel would stop spinning.. There was no way to fix the plastic, but by holding the horse up with zip ties hidden under the top got the thing to work again. Thanks again!
Dec 12, 2012 | Toys
How do I patch holes. There seem to be a couple causing part of the carousel not inflating
I used gaffer tape, seems to work perfectly. Adheres well and it's stronger than the original material anyway. Hope this helps.
Dec 09, 2010 | Carousel Airblown Inflatable Christmas...
We have a Gemmy airblown carousel with four figures inside. It will only partially inflate. We have unzipped everything and untwisted everything. The bottom inflates and part of the top but nothing in...
mine is doing the same it gets twisted cutting off the air supply. I unwind it and lubed it but it continues to happen. there seems to be some sort of spring on the inside at the based. i'm thinking of cutting the tie straps and seeing whats inside...
Nov 29, 2010 | Carousel Airblown Inflatable Christmas...
Mr christmas double decker carousel rotation stopped.
These things are really hit or miss. The company (Mr. Christmas) is virtually useless in the realm of tech support. Caveat Emptor and all that. Personally I have no use for this sort of thing but I must admit they ARE cute (when they work)!
I met a gentleman at the Citigroup Station Model Train exhibit (where I work as a train operator during the holidays) who had a problem similar to yours (in his case it's the music which doesn't work). I offered to attempt to fix this fellow's Mr. Christmas carousel (which he bought used, strike one!). Being a model railroader, I have vast experience repairing model trains but thought this might be a challenge. I did some online research and came to the same conclusion you did (ie Mr Christmas doesn't give a *%&^ once you've bought something, and there's NO viable tech support or schematics to be found). I was nearly about to throw in the towel and return it when I figured out how to open it. I will at least get you to the innards.
My guess is that these carousels are more or less mechanically similar (this fellow has the Disney Carousel, model 94448). The carousel consists of an outer "roof" which snaps around an inner roof (where the horsie poles insert; there are four little tabs which keep it attached to the outer roof). To get the outer roof off, however, you need to carefully remove the "crown" (which is glued on with some sort of silicone based adhesive) It is glued on with some sort of silicone based glue. BE CAREFUL removing it! Once the crown is off, you'll see a screw. Unscrewing it allows you to remove the outer roof.
If you feel mechanically adept enough, continue but TAKE NOTES as there are a LOT of screws and parts from here to the bottom base (where the motor and electronics are located). Once the roof is off, you will see the light wipers and contact pad. You will need to unsolder the two wires from the sprung wipers (be careful not to lose the springs!). You can now unscrew the hexagonal nut which holds the light wiper bracket/wipers in place. CAREFULLY remove this piece! You will now need to unscrew the contact board. pull it over the central shaft. You can now remove the inner roof. Once the inner roof is removed, you can lift up the main assembly (ie the horses, &c); CAREFULLY place this aside!
You are now at the base. There are several screws holding the motor and central shaft to the plastic base. This will come free but will remain wired to the switches. FYI the whole mess is a rubber band drive (sort of like an old cassette player or VCR). If there is no rubber band connecting the motor to the shaft, that is your problem! If the motor plain doesn't work, check the wiring fro the motor to the switch!
To reassemble, just reverse the directions. HINT: the roof will only go on top of the mechanism one way, so if it doesn't quite fit just rotate the roof until it does! Good luck!
Dec 27, 2008 | Toys
Need light bulb for Gemmy 6ft inflatable carousel
Go to the website holidayinflatables.com or buyinflatables.com they carry parts for inflatables.
Dec 07, 2008 | Carousel Airblown Inflatable Christmas...
Toys Logo
65 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
