Question about Siemens Gigaset C300 Quad Cordless Phone
My handset displays SMS mem full Del.messages. How do I do this please? I have never used the SMS so how can it be full?
Everytime I try to do powers and square roots I get an error message
An ERR: MEMORY is given when there is not enough memory to perform the instruction or function. To increase available memory by deleting the contents of any variable (real or complex number, list, matrix, Y= variable, program, Apps, AppVars, picture, graph database, or string), follow these steps. • Press [2nd] [MEM] to display the MEMORY menu.
• Press 2: Mem Mgmt/Del.
• Select a variable or data that needs to be deleted and press [ENTER].
• Use the arrow keys to move the cursor next to the item, and then press [DEL]. The variable or data should now be deleted from the memory.
When deleting programs or Apps, a message asking for confirmation will appear. Select 2:Yes to continue. To leave any variable screen without deleting anything, press [2nd] [MODE].
Jun 29, 2012 | Texas Instruments TI-84 Plus Silver...
My Nokia E63 display a message of ' Phone memory full " and also says 'Please delete files'. Which files to delete and how ? Thanks. Partha
I woud clean up your mobile phone by:
  • Copying your photos on your handset to your PC/Laptop and deleting most of the photos as they can take up a large amount of memory.
  • There are physical available memory limits to the total number of SMS/Messages in your Inbox/Outbox/Sent/Other folders: delete old SMS/messages.
  • There are physical available memory limits in the total number of contacts: delete all redundant directories entries.
You can also try using a bigger microSD card to alleviate your memory limitation.
Hope it helps.
Dec 14, 2010 | Nokia E63 Cell Phone
Hi.... I'm using opera mini 5.1 in my mobile micromax Q5 and I'm facing problem while I download the video from any web site and I get an error again and again that downloading failed. Please help...
Hi.... i am using handset micromax Q5 since last one years untill then there has no problem come in handset till today. but
recently one problem create in my handset not enough memory
message display on screen whenever send SMS to anyone.
kindly i request you please short out my as early as possible.
Thanks
RAKESH PATEL
my address is - rakesh_jagruti@rediffmail.com
Nov 28, 2010 | Cell Phones
Message memory full
hi what the phone is saying is its capable of holding 500 message but in reality this means if you have enough free memory your phone can store 500 messages so what you need to do is delete all the sent/outbox/inbox/drafts message delete all the ones you dont need.
Also delete any pictures you dont need as these take up loads of mem also delete any ringtones that your never going to use as alot of the messages you got free with the phone you never use so make sure you delete any of these that your sure you dont want as these also take up loads of memory once you have done this you should find your phone will work just fine
Dec 19, 2009 | Samsung Star GT-S5233 Cell Phone
Sms memory full del some sms
Your Inbox Only support 200 sms... And when I say Inbox it includes your My folder as well... So you see 197+ 26 beyond your range... Delete Data from my Folder.... Problem solved.
Nov 19, 2009 | Samsung Star GT-S5233 Cell Phone
Sometimes i am not able to receive SMS text messages via Starhub Singapore. I am using LG KC910 model. There is lot of memory free in handset.
I am not able to Send SMS text messages via Mci iran. I am using LG KC910 model. There is lot of memory free in handset.
Sep 01, 2009 | LG KC910 Renoir Cell Phone
Sms problem
Nokia N95 is a Symbian handset. You might had opened many applications at one time which are consuming a lot of space on your handset. Try closing some applications or removing one-two applications from your handset and see if if works. Other then this you can try out expanding the memory for your handset.
Jun 07, 2009 | Nokia N95 Cellular Phone
Envelope icon flashing on screen (not voicemail icon)
Try deleting some text messages in the in box this may solve the problem.
Jul 02, 2008 | Samsung Cell Phones
Message sending failed
Have you checked your SMS-settings ? Some of the programs you´ve installed could have changed the default settings from your provider.
Oct 04, 2007 | Nokia 6680 Cellular Phone
Storing #s in memory
Try this. Memory The handset can store up to ten 24-digit numbers with up to 15-character names in memory for quick dialing. This memory feature is in addition to the CID memory log, which stores up to 40 CID records in the handset. Storing a Name and Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the mem button. 3. Press the desired memory location (0 through 9) or use Caller ID/vol (+ or to scroll to the desired memory location. NOTE: If the memory location is occupied, the memory location number and its contents show in the display. 4. Press the mem button again. The display shows ENTER NAME. NOTE: If you don?t want to enter the name, skip step 5. 5. Use the touch-tone pad on the handset to enter the name (up to 15 characters) and press the mem button to save. More than one letter is stored in each of the number keys. For example, to enter the name Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Wait for one second. Press the 5 key 3 times for the second letter L. Press the 1 key to insert a space between the L and the S. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H. 6. Press the mem button to save the name. The display shows ENTER TEL NUMBR. 7. Use the touch-tone pad to enter the telephone number you want to store (up to 24 digits). 8. Press mem again to store the number. You will hear a confirmation tone. NOTE: If you make a mistake press the del/chan button to backspace and erase the wrong character(s) or number(s). If there are any further questions or comments, please post here. Please rate this solution through fix-ya.com Thank you
Jun 18, 2007 | GE 25836 Cordless Phone
Siemens Gigaset C300 Quad Cordless Phone Logo
89 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
