Question about Spectre 2002 Chevy Impala - 3.4L V6 - Air Filter
My car wont start after I have driven a while and turn off engine. When I try to start it cranks well but will not turn over. If I let it sit for 20 minutes it will start again???
I changed the fuel filter. still does it. No chk engine light.
    New Friend:
Sounds like you got a shorted starter the windings in the starter short when they get hot when this happens when the starter is hot it can't hardly turn the engine over because there is not enough magnetism ti turn the starter and thus the car motor over. cools off it is fine gets hot and shorts out replace starter
Posted on Jan 03, 2015
    New Friend:
  • 28 Answers
Sounds like you're in tank fuel pump is starting to go bad..happened to my astro van a few years ago..kept doing this until one day it just didn't work. Have someone do a fuel pressure test before and after turning the engine over...Also try this..before trying to start your engine turn your switch to ON for about ten seconds and listen very carefully for the pump running to prime the fuel system and injectors it should run for about five seconds...then try starting the engine...get into the habit of waiting those 10 seconds to insure proper priming of the system..good luck
Posted on Jan 01, 2015
My 03 santa fe sometimes will not start as if the diesel is not getting to the engine any thoughts
most starting problems with diesels can be sourced to
low fuel pressures( pressure draining off over time), air in the system, glo-plugs not working and slow cranking speeds
run the fault codes first to check for possible electronic and sensor faults
take it to an accredited diesel shop and have the fuel system and fuel pressure checked
Apr 22, 2016 | Hyundai 01 02 03 04 05 06 Santa Fe Air...
The engine turns but won't start, after no problems the day before
You should get a code reader to see if there are any OBD codes that are set. This problem is usually caused by the crank sensor
Mar 17, 2016 | Hyundai 2007 ELANTRA Electric Engine...
Cranks wont start drains battery
It could be that your fuel filter is clogged or your fuel pump went out. Can you tell me if it happened suddenly, or did it gradually get to this point over time?
Aug 18, 2015 | aFe 2000 Nissan Maxima - 3.0L V6 - Air...
Engine cranks very slow on starting and will not start
refill the battery with electrolyt and charge it fully, then try to start the vehicle
If it cranks/turns over no faster have the starter motor checked.
Ensure that the timing belt is intact before you do anything, and that it is in the correct position.
Ensure that the oil is clear of water and is clean and is topped up to the top mark on the dipstick
Assuming you have checked the above and the belt and oil/coolant is all as they should be, and you have a fully charged battery and the starter is ok .......attempt to start the vehicle. Turn it over/ crank it over a few times if it does not start immediately.
Should it not start perform a compression check to find out the
engine's state of health.
Then come back with the results and we can go feom there.
Add the detail of your work and the make and model of the vehicle, along with the engine option, and repost the query
Jul 18, 2015 | Spectre 2003 Dodge Stratus - 2.4L 4-cyl....
Why does my car just turn over but wont start
A suggestion would be to check your fuel filter to make sure it is not stopped up. Your fuse to the fuel pump may also need to be checked. Chevys are notorius for bad fuel pumps.
Jun 03, 2014 | aFe 2001 Chevy Cavalier - 2.4L 4-cyl....
Wont turn on
does the lights come on but the motor does not turn, if it is this it can be the starter for the motor inside next to the motor is a started solenoid this starts the motor to run. when they start to fail you get a buzzing sound or a humming, eventually it just fails. also the motors are prone to fail after time, and they don't do replacements for this part
Mar 30, 2014 | Air Purifiers
Reset engine indicator light
1. With the Car Off, Press and hold down the Odometer Trip Reset Button. 2. While still pressing the Trip Reset Button, Turn the Ignition Key half way on where all your oil, check engine lights etc.. turn on. Don't turn it as far as you would to normally start the car. Wait a few seconds and the Check engine light will turn off. 3. Turn the key back to the Off position and you're done.
(source: Yahoo Answers)
Feb 08, 2014 | aFe 2004 Honda Accord - 3.0L V6 - Air...
My machine is 4-5 years old and it suddenly wont turn on. I switched outlets but it appears dead.
Open up the elecrical panel and see if you have any fuses form the incoming power if you do it might be blown
Aug 31, 2009 | Sun Pure SP-20 Air Purifier
Spectre 2002 Chevy Impala - 3.4L V6 - Air Filter Logo
99 people viewed this question
Top Spectre Air Purifiers Experts
Lawrence Oravetz
Jesse Walters
Jesse Walters
Are you a Spectre Air Purifier Expert? Answer questions, earn points and help others
