Question about Minolta Office Equipment & Supplies
Remove c-24 errorminolta di450/500
C-24 error minolta di450/500
  • Minolta Master
  • 6,850 Answers
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Dec 27, 2014
    Sergeant:
  • Minolta Expert
  • 229 Answers
Code Description Remedy C0000 Fusing Motor's failure to turn
• The Lock signal remains HIGH for a continuous period of 1.5 sec. or more after the lapse of 10 sec. after the motor has started turning. • The Lock signal remains LOW for a continuous period of 1.5 sec. or more after the lapse of 10 sec. after the motor has stopped turning. 1 Fusing Motor turns when the Start key is pressed. NO Correct drive coupling. 2 Fusing Motor rotation: the voltage across PJ7A-1A on Master Board and GND is DC5V (motor deenergized) and DC0V (motor energized) when the Start key is pressed. NO Change Master Board. 3 Fusing Motor rotation: the voltage across PJ7A-2A on Master Board and GND is DC5V (motor deenergized) and DC0V (motor energized) when the Start key is pressed. YES Change Master Board. NO Change motor. C0010 PC Drum Drive Motor's failure to turn
• The Lock signal remains HIGH for a continuous period of 1.5 sec. or more after the lapse of 10 sec. after the motor has started turning. • The Lock signal remains LOW for a continuous period of 1.5 sec. or more after the lapse of 10 sec. after the motor has stopped turning. 1 PC Drum Drive Motor turns when the Start key is pressed. NO Correct drive coupling. 2 PC Drum Drive Motor rotation: the voltage across PJ7A-3A on Master Board and GND is DC5V (motor deenergized) and DC0V (motor energized) when the Start key is pressed. NO Change Master Board. 3 PC Drum Drive Motor rotation: the voltage across PJ7A-4A on Master Board and GND is DC5V (motor deenergized) and DC0V (motor energized) when the Start key is pressed. YES Change Master Board. NO Change motor. C0040 Suction Fan Motor's failure to turn
The Lock signal remains HIGH for a continuous period of 1.5 sec. or more after the lapse of 10 sec. after the motor has started turning at high speed. 1 Suction Fan Motor turns when the malfunction is reset. NO Check motor for installation. 2 Suction Fan Motor rotation: the voltage across PJ13A-1B on Master Board and GND is DC5V after the malfunction has been reset. YES Change Master Board. NO Change motor. C0042 Fusing Unit Cooling Fan Motor's failure to turn
The Lock signal remains HIGH for a continuous period of 1.5 sec. or more after the lapse of 10 sec. after the motor has started turning at high speed. 1 Fusing Unit Cooling Fan Motor rotation: the voltage across PJ13C-1 on Power Supply Board and GND is DC24V (during high-speed rotation) and DC16V (during low-speed rotation) after the malfunction has been reset. NO Change Power Supply Board. 2 Fusing Unit Cooling Fan Motor rotation: the voltage across PJ13C-3 on Power Supply Board and GND is DC5V after the malfunction has been reset. YES Change Master Board. NO Check motor for installation. Change motor. C0044 EDH Fan Motor malfunction
See the relevant option service manual. C0045 IR Cooling Fan Motor malfunction
The Lock signal remains HIGH for a continuous period of 1.5 sec. or more after the lapse of 10 sec. after the motor has stopped turning. 1 IR Cooling Fan Motor rotation: the voltage across PJ4IC-4 on SCP Board and GND is DC24V (during high-speed rotation) and DC12V (during low-speed rotation) after the malfunction has been reset. NO Change SCP Board. 2 IR Cooling Fan Motor rotation: the voltage across PJ4IC-6 on SCP Board and GND is DC5V after the malfunction has been reset. YES Change SCP Board. NO Check motor for installation. Change motor. C0046 PH Cooling Fan Motor 1 malfunction
The Lock signal remains HIGH for a continuous period of 1.5 sec. or more after the lapse of 10 sec. after the motor has started turning. 1 PH Cooling Fan Motor 1 rotation: the voltage across PJ4IC-1 on Master Board and GND is DC24V after the malfunction has been reset. NO Change SCP Board. 2 PH Cooling Fan Motor 1 rotation: the voltage across PJ4IC-3 on Master Board and GND is DC0V after the malfunction has been reset. YES Change SCP Board. NO Check motor for installation. Change motor. C0047 PH Cooling Fan Motor 2 malfunction
The Lock signal remains HIGH for a continuous period of 1.5 sec. or more after the lapse of 10 sec. after the motor has started turning. 1 PH Cooling Fan Motor 2 rotation: the voltage across PJ4IC-7 on Master Board and GND is DC24V after the malfunction has been reset. NO Change SCP Board. 2 PH Cooling Fan Motor 2 rotation: the voltage across PJ4IC-9 on Master Board and GND is DC0V after the malfunction has been reset. YES Change SCP Board. NO Check motor for installation. Change motor. C0049 Paper source option Vertical Transport Cooling Fan Motor malfunction 1 Vertical Transport Cooling Fan Motor rotation: the voltage across PJ14A-1 on Power Supply Board and GND is DC24V after the malfunction has been reset. NO Change Control Board. 2 Vertical Transport Cooling Fan Motor rotation: the voltage across PJ14A-3 on Power Supply Board and GND is DC0V after the malfunction has been reset. YES Change Control Board. NO Check motor for installation. Change motor. C004C Ventilation Fan Motor's failure to turn
• The Lock signal remains HIGH for a continuous period of 1.5 sec. or more after the lapse of 10 sec. after the motor has started turning. • The Lock signal remains LOW for a continuous period of 1.5 sec. or more after the lapse of 10 sec. after the motor has stopped turning. 1 Ventilation Fan Motor rotation: the voltage across P
Posted on Dec 15, 2014
  • iftikharhmd40 Dec 15, 2014
    high speed. 1 Suction Fan Motor turns when the malfunction is reset. NO Check motor for installation. 2 Suction Fan Motor rotation: the voltage across PJ13A-1B on Master Board and GND is DC5V after the malfunction has been reset. YES Change Master Board. NO Change motor. C0042 Fusing Unit Cooling Fan Motor’s failure to turn The Lock signal remains HIGH for a continuous period of 1.5 sec. or more after the lapse of 10 sec. after the motor has started turning at high speed. 1 Fusing Unit Cooling Fan Motor rotation: the voltage across PJ13C-1 on Power Supply Board and GND is DC24V (during high-speed rotation) and DC16V (during low-speed rotation) after the malfunction has been reset. NO Change Power Supply Board. 2 Fusing Unit Cooling Fan Motor rotation: the voltage across PJ13C-3 on Power Supply Board and GND is DC5V after the malfunction has been reset. YES Change Master Board. NO Check motor for installation. C
SOURCE:
Minolta 5000 Maxxum Auto/Manual, Did it rewind? How do I tell, I am an advanced photog, but this is new. Says 24 with 2 arrows right pointing. Should I darkroom it??? TY
Darkroom is always safest in these situations. Sounds like you don't have a manual - if you google the make and model, followed by the word Manual, you may be able to find one.
Aug 24, 2016 | Minolta Photography
How to remove c-24
1 PJ7A, CN10, and CN41 are plugged securely into Master Board. NO Plug them in securely. 2 Photosensor/LED of the AIDC Sensor are contaminated. YES Clean. NO Change AIDC Sensor Board. Change Master Board.
Dec 16, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
Remove c-24 error
unplug wait a minute (that is 60 seconds) and then plug in & turn back on
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
Dec 13, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
Minolta di450 how i can solve this code c-0540
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
May 18, 2014 | Minolta Office Equipment & Supplies
Minolta DI450 error code C-0920
1st paper draw lift motor is jammed or burn out or the control board is bad. Check for paper behind the draw, also remove any paper from left side of draw.
Dec 26, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
Of 24 error
Cof 024 - AIDC sensor contamination correction failure.The photosensore LED located under OPC drum of the AIDC sensor dirty.Clean the sensor,reset the malfunction code if the necessary perform F5 AIDC auto adjustment.
Mar 06, 2013 | Minolta Di550 B&W Laser Printer
Como fazer para tirar codigo c of 24 na minolta di 552
Remove the drum assy. and drum and clean the sensor that monitors the drum. if still bad replace the drum and or sensor
Sep 11, 2012 | Minolta Office Equipment & Supplies
Konica minolta bizhub 363 error message c-2201
remove the toner bottle let machine thur its paces when it says install toner bottle install correctly
Feb 24, 2012 | Minolta Office Equipment & Supplies
Konica minolta 363 error message c-2201
remove the toner bottle reinstall when machine ask for it.
Konica Minolta C350 colour copier T096 error code??
Transfer belt code C096 mite try open and closing the front door where you put the toner. Also remove the image transfer belt and then reseat it.
Apr 10, 2009 | Minolta Office Equipment & Supplies
152 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
