Power Acoustik amp
I have a power acoustik 4500 gothic series amp that quit working and is in protect mode
    Problem Solver:
  • 14 Answers
First thing to do is check the fuse. If it is still in good condition then you may have blown your amp
You can make sure no wires are touching an also tried wiring in a mode that does not put it at its maximum ohm load.
Posted on Dec 15, 2014
  • David S Dec 15, 2014
    Iv checked all the fuses and disconnected the rcas, i also checked power and ground with a meter so I know it's something internal, just don't know what components I should check first
2 Suggested Answers
e-Guru
  • 3917 Answers
SOURCE: need sitting for my amp
Most fan cooled amplifiers would be fine on its side provided the flow of air is not impeded. Unless it's been modified the probability of a wire falling into the blades is pretty small. Where you may want to be concerned is if it's a convection cooled amplifier which would depend heat rising away from heat producing components and their heat sinks. Placing this type of amp on its side could reduce the efficiency of its cooling capabilities possibly causing it to thermally shut down and/or shorten its lifespan.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 28, 2010
I have two amps my power acoustic ov2-1800 stays in protect mode when i turn my car on, and my other amp is a JL Audio and it goes in and out of procect mode randomly??? Any insight???
You have a short. Check all power connections to both amps, all the way back to the battery. Then check to make sure speakers are connected properly
Jun 04, 2010 | Power Acoustik GOTHIC OV2-1800 Car Amp
How to bridge a 4ch power acoustik amp to 2ch
I had the Power acoustik saphire 4ch and had to do the same thing. Use the Positive from Term1 (spkr1) and Negative from Term2(spkr2). Good Luck.
Nov 26, 2009 | Power Acoustik GOTHIC OV4-800 Car Audio...
I have a power acoustic gothic series 1600 watt amp, it was playing fine last night and just went off, protect light on. Today i tried it, there is a very small amount of sound thru the speakers but thats...
There are really only two possibilities here. If you have the gain turned up too high then your amp will get over worked and will go into protect mode. It is a safety feature. You should never really have the gain at much over 50% up. If you have to consistently run it higher than that you are overworking your amp and it will either shut down to protect itself or you will fry it.
Nov 19, 2009 | Power Acoustik LT-980/2 Car Audio...
Power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Aug 18, 2009 | Power Acoustik GOTHIC OV2-800 Car Audio...
My amp is flashing in and out of protect
you must likey just fryed the wires, try putting in bigger fuses, and unhooking everything and re hooking it up
Jun 13, 2009 | Power Acoustik GOTHIC OV2-1800 Car Amp
My amp goes in protect mode
Maybe the audio amplifier IC´s are damaged
Feb 06, 2009 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Power acoustik gothic ov2-1600
What are the circuit board designations (Q111, Q112, Q211, Q212...) for the parts you replaced?
Did you replace the defective parts with identical transistors?
Which transistors are heating up?
Nov 07, 2008 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Protection light
have you wired it up properly + to + and - to - and the power + and -
Aug 13, 2007 | Power Acoustik GOTHIC OV4-600 Car Audio...
Power Acoustik
the amp shouldnt even lite up w/o the ground attached.
Jan 25, 2007 | Power Acoustik GOTHIC OV2-520 Car Audio...
56 people viewed this question
 Grubhead
Grubhead
