Question about Bosch 1998 Mercedes E320 Window Motor Front Left
Power windows all go down when car is turned off and driivers door is closed.
Checked fuses.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 22 Answers
Your door switch may have shorted out.
Posted on Jan 03, 2015
2003 gmc envoy Windows fuse
Are all windows not working ? Two separate circuit breakers left & right . Both in rear fuse box . Fuse Block - Rear Beneath the left rear seat
Check for broken wires inside the rubber boot from body to doors.
Do you know about electronic control modules ?
The power window system consists of the following components:
Driver door module (DDM)
Passenger door module (PDM)
Body control module (BCM)
LR power window switch
RR power window switch
Window up and window down relays in each of the rear passenger window switches
Window lockout switch
Reversible power window motors in each of the doors (circuit breaker protected)
LT DOOR CB 25A (System power for left rear window)
RT DOOR CB 25A (System power for right rear window)
The power window system will operate anytime the retained accessory power (RAP) system is active or when the ignition switch is in the ACCY or ON position.
The DDM contains 4 power window switches which are integral components. Closing any of the normally open, rocker type switches provides the DDM with a request for power window operation. The switches for the 2 front windows have 3 positions Up, Down and Express Down, while the switches for the rear windows have only 2 positions, Up and Down. Each of these switches and their positions is a direct input into the DDM. Upon receiving a request for power window operation, the DDM, transmits a class 2 message indicating the switch and it's changed position.
The PDM contains a single power window switch that is an integral component. Closing of this normally open, rocker switch provides the PDM with a request for the front passenger power window operation. The switch for the front passenger window has 2 positions Up and Down. Each of these switch positions is a direct input to the PDM.
The 2 rear passenger doors have there own switches. Each of the switches contain a power window up and down relay. A switch activation alone can control the up and down functions of the rear windows. However the BCM, upon receiving a class 2 message from the DDM, can control the set of relays which will activate the rear window motors.
Check
Oct 21, 2016 | 2003 GMC Envoy
My power windows won't work. I checked fuses
The relays for the power windows are part of the switch assemblies. 1 relay for up and 1 for down in each switch. I don't think there are any relays for the mirrors, but if there are I think they would also be in the switch panel.
Pull off the door panel and check for power at the window motor and then trace back from there. Most likely cause is broken/loose wiring or connectors.
If you are getting power to the window motor, the gear assembly may be seized, but this is unusual on a drivers door. The gear assembly can be removed from the motor and coaxed back into working order with lots of penetrating oil and a suitable spanner on the cog.
Mar 12, 2010 | 1997 Jaguar XJ6
1990 buick century All power windows will not move fuses on fuse block (locaated in back of glove box door )checked ok with ohm meter T.I.A. ****
Well I was wrong, the window on pass side worked from the switch on the pass door !! So now that I know this I took apart the driver side door switch controll panel ( ie. 4 windows switch up/down & 4 door lock / unlock switch) I found 12 volts to the door lock section but NO 12 volts to the window section ( with key on) !! ratheer then trying to trace out this wire (oange) I took 12 volts from the door & jumpered it to the window 12 volt supply { now I know the door wire is thicker ( more amps) then the window supply but I dont't think I'll be useing all 4 window moters at once...} oh well what the hell it's almost 20 years old has three sets of seats & gets close to 28 MPG....
Oct 16, 2009 | Buick Century Cars & Trucks
Power windows will not work none of the windows roll up or down. Fuses have already been checked
check the power window switch make sure its working. to check turn oon the dome light in the car, depress the switch if the light dims then the switch is good, next step, check the fuse and relays that control the power window make sure its good. take off the door panel and make sure the window is still in its track, check the poter for operation by adding 12v
Jul 31, 2009 | 1998 Nissan Pathfinder
Power windows and power doorlocks won't work
Try replacing your window switch on the drivers front door.
May 19, 2009 | 1992 Nissan Maxima
Power windows dont work?
checked all fuses?
power window motor?
Apr 26, 2009 | 1990 Acura Integra Hatchback
My passenger door has no power,my security light is on constantly
Have lost power to the passenger side door. Without power system doesnt recognize door closed because of no power to door ajar switch which keeps dome light on. Security light stays on because without power to rest of systems supplied by fuse it cannot tell if doors and windows closed to engage security features. Most common is for power wire to break somewhere near where it leaves to main body and enters the door.
Apr 25, 2009 | 2003 Pontiac Bonneville
Power windows and door locks not working ,checked all fuses look good?
My jeep liberty passenger side door won't open and the window won't go up or down....what is the problem?
Apr 14, 2009 | Jeep Liberty Cars & Trucks
Front passanger window not working.fuse checked;
it is most likely the window motor has failed.
Mar 19, 2009 | 1996 Ford Escort 4 Door
Bosch 1998 Mercedes E320 Window Motor Front Left Logo
62 people viewed this question
Top Bosch Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Bosch Air Tool and Compressor Expert? Answer questions, earn points and help others
