Question about Home
I have a 6 Ft led light-show tree part no: 151-0725-6 with a 3 year waranty I've had it for one year it does not work wires heated in small box. Can you help me find Noma for this
Canadian Tire will not take it back. It has a 3 year warranty Ive used it for one (1) jear only can you help me ???
After 7 yrs of use, it just stopped working
I agree that It could be one of the other reasons listed here.....
But, I had the same problem with a 1,000 watt Kenwood amplifier and it worked like a boss for the whole two years that I had it and then one day the box that I had my subs in somehow came apart and after I changed out boxes the amp quit working. It came on but it wouldn't work anymore except for when I turned it a certain way or sat it against something.. Anyway it ended up being a loose female port plug on the inside where the auxilary cables plug up.
Hope it helps.
May 11, 2013 | Clarion APA4320 Car Audio Amplifier
I just bought a 2003 Envoy It had the check engine light on. It showed on the the scanner a code for the Crankshaft Sensor and said something about advanced timing. So i've had the crankshaft sen
Why would you be at a dealer with a 10 year old vehicle
Have extra money to throw away
How about a local repair shop
How is it you had work done & still
have any problems,what do these
shops do,half a job
Mar 18, 2013 | 2003 GMC Envoy
TH-15A won't make sound. Comes on, then flashing front light
This probably means there is a failure and the internal protection circuits have activated. It will probably have to go to a shop for repair.
Jan 03, 2011 | Mackie ProFX8 / TH-15A PA Package
MY 3 PIECE GEMMY CHRISTMAS TREES STOPPED WORKING THE SPEAKER FOR MUSIC JUST KINDA HUMMS AND THE LIGHTS WILL NOT WORK
Here's what you do... This is for the trio christmas tree light show.
What you need.... small precision pointing tool.
On the largest tree base electrical box there is a push button. Press and release that button. A red led will flash indicating the box is in sync mode. turn the remote on and on the back of your remort, there is a small hole with the words reset over the top of it. Using the small precision pointing tool, press the recessed button and release. The remote will sync to the base unit. Walla!! Merry Christmas to all!!!
Nov 29, 2009 | Gemmy Toys
We bought the Gemmy Christmas tree trio last year. Just set it up today and the light show effects will not reset. Can't find the instruction manual
Press reset on the top of the main unit under the middle tree. The light will blink. While it's blinking, use a pin to press in the reset button on the back of the remote. The blinking light should go out, and you should be good to go. FWIW - I just looked for almost an hour before I found this answer today on-line. It worked for us.
Nov 27, 2009 | Gemmy Toys
No LED power lights go on
the light with the power light(middle) is a blue/purple faint light try checking it out at night.The squiggy(as heat waves) will only light when the amps shuts down due to thermal protection(wait for it to cool). The bolt/yellow (short circuit) will light when there is an electrical overload in any of the wires(check +ve leads).
May 26, 2009 | MTX JackHammer JH202 Car Audio Amplifier
Gemmy light show lollipops not working right
The gemmy light shows are amazing when working correctly. BUT that may be for one season only. I bought the white trio set of Christmas trees after one season the trees turned brown, tried to get in touch gemmy. Two days later my reply was I improperly stored my trees. All the other set of trees I've seen turn brown after one season. As far as I know gemmy quit making the white trees. Long story short they did't warranty my trees, as for the lollipops 4 or 5 light systems aren't interchangeable, I tried to replace the led in my 5 light system with a led from a 4 light system the led worked but wouldn't sync. When trying to make repairs you must use parts from alike sets of the same year models, alike models from different years don't work. Also when changing led circuit boards solder the wires the way you take them off or you'll short the board out. If you have bad sets of lights you can make repairs if they are alike.
Nov 18, 2008 | Sport & Outdoor - Others
Home Logo
85 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
