Question about Kitchen Ranges
I heard a pop when I turned on my front burner a few weeks ago and not that burner does not work, replaced the element and also the control box behind that burner knob as well. Still not working....could it be a fuse?
5 Suggested Answers
SOURCE: Burners Blew
I had a similar problem while mine was still under warranty. Seemed like every time I used the oven and stove top for a major dinner it would short out and I would get an error code: F1:E6. They replaced the board under the display area, but it happened again about 6 months later. Turned out that when they made the oven they didn't insert a chimney like vent system from the bottom left side of the oven to the vent holes that come out the upper left side of the stovetop. This caused the panel to overheat and stop the entire oven from working. They replaced the board again and installed the "chimney vent system" and I haven't had the problem occur again (it's been 3 years!).
Posted on Feb 17, 2008
SOURCE: Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Posted on Dec 17, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
  • 272 Answers
SOURCE: Front right element popped and started a fire...I
Usually when a burner goes it is the switch that goes at the same time. There is a fusable link in the switch itself that blows, they are easy to replace. It is usually best to replace the recerptacle as well as the surge usually builds up a lot of carbon on the connectors and may cause some arcing and difficulty down the road.
Posted on May 18, 2009
Maytag electric cooktop popping breaker.
The problem is most likely in the element in one of the coils, if they are the tube type and look like pencil thick heating elements, they can develope a short circuit inside them. The actual heating wire is encased with ceramic filler and then put in that tube. The heating wire moves when it gets hot and can work its way to the case and cause a short. Unhook the power from the whole unit and use the meter to check the rersistance of the coils between the heating element and the case
Jan 13, 2013 | Cooktops
Suddenly, No tail lights, brake lights, turns signal or back up lights At 83000 miles, 6 months ago, replaced head gaskets. 1 week later, service engine soon light came on. Tech said it was an oxygen...
just look for the blackened/burned pin on the rear light plastic connector and sand it down to re-establish a good electrical connection and save yourself $800 big ones on replacing the multiswitch.
Jun 26, 2011 | 1999 Chevrolet Venture
I was preheating my Samsung ftq387lwgx oven and heard 3 loud popping noises. Shut it off because it scared me. Turned it back on and it doesnt heat up and the top burners don't work either. The clock...
It sounds as if the oven element short circuited and blew one of the internal fuses in the range. If this occurs it generally knocks out the oven circuit and two hotplates. Locate the fuses, they are mostly in the griller/broiler section. Sometimes they are in the back of the range. Replace fuse wire and power will be restored. Before you turn the oven back on carry out a visual inspection of the element for holes/blow marks. It this is the problem the element will need replacing.
Feb 18, 2011 | Kitchen Ranges
I have a Whirlpool electric range RF263LXTQ2- 2 yrs old-it gets so hot that the large burner pans are both charred black. Had it looked at about a year ago and couldn't find any problem-top and front of...
Since you are having problems with multiple elements the problem is probably the circuit board that controls them. This can be ordered and replaced. Be sure to unplug the stove before getting into the circuit board though.
Mar 13, 2017 | Whirlpool RF263LXTQ Range
Head a popping sound and oven temperature doesn't work
Most likely a bad element. Turn off the power to the oven. Remove the racks. Use a phillips screwdriver or 1/4 inch nut driver to remove the mounting screws at the back of the oven cavity to remove the element. Carefully pull the element out and remove the wires. Do not let the wires fall back into the holes. Use a volt meter set for continuity. Touch one meter lead to one terminal on the element. Touch the other meter lead to the other terminal. If you get NO reading the element is bad. A new element will correct your problem. If the element reads as good you have a wiring problem or a bad control.
Jan 04, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
Kenmore 790.9641240, while using stove top power burner (front left) a loud pop was heard and I thought I saw a blue flash (like an arc) above the pan, the next day received a slight electrical tingle...
Tom (Tchange): I also had arc/pop/short of SSB like g_royer. This was preceded over a few days by the Element ON indicator always ON (with all surface select switches OFF). I found the arc marks and burns on the SSB and replaced it. Element ON indicator went OUT, but like you, element no longer heats. I just checked continuity for each of the relays on the Lockout Board. In spite of the error designation on the Wiring Diagram (swapping P3 with P6), I found an OPEN relay for that element. Now to order the Lockout Board, just like g_royer.
Jun 25, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
Bake or broil does not work
if an element itself had shorted it would not stop the other from working and you could inspect each element and see blistering as evidence.the pop you heard has to be in common with both elements but not the cook top[burners]so thats going to be the wiring in the back of range, or switching,[thermostat,clock timer or oven selector switch,depends on which model you have]you will have to pull range and remove back pannels.you will find an obivous burn't connection.too repair all new connections must be clean and tight,or will burn again.
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
Kitchen Ranges Logo
46 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
