Is there a was to set it up so you can see how much has been delivered instead of just seeing the vtbd amount the whole time?
  • kakima Dec 14, 2014
    What make and model is "it"?
    Top Expert:
  • Office Equip... Master
  • 14,162 Answers
Most laserjets have that ability and mainly on a network. you would be best to contact the printer company. THe most common two is HP and Xerox. If you need a phone number let me know or just google it or go to gethuman.com and search for the company phone numbers. Find Best Customer Support Phone Number Contact Info any Company
Posted on Dec 15, 2014
What is amp. draw of minn kota 40pd? thanks
Digital Maximizer™
Digital Maximizer™. Up to five times longer run time on a single charge.
Conventional speed coil technology wastes energy by delivering a constant, steady flow of power to the motor regardless of the speed setting resulting in wasted energy.
Pioneered in 1985, Minn Kotas innovative Maximizer™ technology delivers the precise amount of power needed at any setting, along with variable speed control. Now, our advanced, digital microprocessing optimizes draw to extend battery life and reduce damaging heat. Get up to five times longer run time on a single charge.
Would think you would have to ask direct, but standard practice is to run your Minn Kota from a separate battery anyway, so the draw is pretty irrelevant to main engine starting.
your manual is here and states it has a battery level meter.
http://www.minnkotamotors.com/Support/Owner-Manuals/PowerDrive-V2/
Minn Kota Motors
Jan 06, 2016 | Minn Kota Boating
At low throttle opening on long steady motorway runs.soot gathers at end of tailpipes.running rich?
Sounds like it. Are your plugs sooting up? Does it smell over-rich? Has fuel consumption got worse?
First thing I would do is check the air filter. If it, or the air intake pipes are blocked or restricted then not enough air is getting in to form the correct air/fuel mixture. This means that even if the mixture setting is correct for normal running, the correct amount of fuel is being delivered but cannot combust efficiently with the reduced amount of air creating an over rich mixture.
If all is as it should be then spray carb cleaner into the air intake (engine running, air filter out) in short bursts. The engine will stutter as the cleaner runs through the system so be prepared to blip the throttle to keep it running. When it runs smooth again, another burst of carb cleaner, blip until smooth again and repeat a few times. This will clean out the jets and deposits in the carb and may help.
As you used the word motorway instead of highway, I am guessing you are in the UK and not US. In which case don't buy the cleaner from Halfords as motor factors are way way cheaper (£2 instead of a fiver a can).
Good luck and let me know how you get on.
Steve
Sep 24, 2015 | 1999 Honda CBR 1100 XX Super blackbird
How Quickly Can I Have The Cash Advance?
Following a complete contract qualifies and performed, funding is going to be available the moment your merchant processing account is converted and also the Merchant Cash Advance lender sees 2 days of net settlement.
Aug 04, 2015 | Retail Supplies
When I press the espresso button instead of esspreso makes a long coffe .I must ad I descaled it yesterday .
You may have accidentally changed the amount setting for your espresso shot when resetting the descale counter.
If you lost the manual you can find one here.
http://www.gaggia-usa.com/support_docs/Gaggia_Brera_Quickstart_Guide.pdf
On page 11 (with the printed number 31) you find how to change these settings:
• Place a cup under the dispensing spout.
• Hold the "espresso size" button pressed for 5 seconds to enter the programming mode; the "coffee" icon will blink quickly and the coffee will start to be brewed; the icon will flash during the whole coffee brewing cycle.
• Press the same "espresso size" button again when the amount of coffee in the cup reaches the desired level.
At this point the button "espresso size" is programmed; each time it is pressed and released, the machine will brew the same amount of coffee that was just programmed.
The same operation can be repeated for the "Lungo size" button.
Jun 15, 2015 | Gaggia Brera Coffee Maker
How do I descal D1000GT
I doubt that you have so much scale that you only get half volume. It could be that the programming is set to TIMING instead of VOLUME. With TIMING, you need to ensure your water pressure is consistent - otherwise a drop in pressure caused by a nearby sink running will "time out," and the result is less volume.
Volumetric water control will not stop until it delivers the full airpot, assuming it is set correctly.
Here's everything for the D100GT:
http://www.wilburcurtis.com/sites/default/files/cleaning_instructions/F-3318.pdf
http://www.wilburcurtis.com/sites/default/files/service-manuals/F-3338.pdf
The way these commercial machines work is by maintaining a volume of 200 degree water in a boiler. When you brew, fresh cold water is allowed into the boiler, displacing a set amount of hot water out to the coffee baskets.
Scale? You might very well have some, depending on your local water supply, and lack of filters. You'd have to pop the lid on the boiler to see if there is any buildup, but I would not recommend it if you don't know what you're doing. Descaling gets a little involved - you might want to bring in a coffee machine tech. That way s/he will ensure that the system is completely flushed, not to mention setting the water volume.
https://www.google.com/search?q=activated+citric+acid&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a&channel=sb
Oct 06, 2014 | Coffee Makers & Espresso Machines
What are the benefits of meal replacement drinks?
Meal replacement drinks offer the following benefits:
They contain a high amount of protein (around 40 grams), which is excellent for people who engage in high intensity activities (such as weight training).
  • They contain a low amount of calories, which is great for those looking for a low caloric alternative to whole food meal.
  • They are really easy to make.
  • They're much cheaper than going out to eat. They cost around $2 per packet.
  • They contain a large amount of minerals and vitamins.
  • Sometimes you are hungry but don't feel like taking 15-20 minutes to eat. Instead, you can quickly prepare a meal replacement drink and drink it in no time.
Jan 10, 2013 | Health & Beauty
Dvd, sound, no picture
If your DVD is external, I'd check TVs input settings: if your DVD on "progressive scan" mode, it delivers video signal via "component" connections: green, blue, red plus 2 separate red/white for the sound. If you trying to use 3 wires: yellow, red, white( composite), good chance, that the only sound is delivered. Try to switch DVD off 'progressive", if you only have 3 wires. It will deliver "picture". Or, verso-visa: using "component", 5 wires, but DVD set off "progressive scan". I've seen that confusion many times! Unless you have 'built in" DVD player. no matter what, it's must be broken! Use external DVD player, instead! $30 and trip to the store, will solve your problem. Don't want to fix TV, if everything else is alright. Myself, I never liked those "combo" units. You got stuck with mediocre TV and lousy DVD player. Better: separate them!
Good luck,
Alex.
Dec 25, 2011 | Toshiba Televison & Video
Utbd del alarm keeps showing
It's actually "VTBD del" which means the "Volume To Be Delivered" has been set and the pump has delivered that much food. Pause the pump (Start/Hold button), then press and hold the VTBD button (below Start/Hold) for 5 seconds. That clears the VTBD.
Mar 30, 2011 | Kendall KANGAROO Pump Sets
Instead of replacing the Capacitors may be is better to check the the amount of current by loading each one of the capacitors. In my dell E193Fpc the capacitors don't look swollen. The question is what is...
That will take more time than repalcing the caps, bad caps can have high ESR, to measure current discharge during the AC discharge cycle of 50~100KHz each power supply will be real hard unless you have very low Z AC amp meter that has frequency response higher than 100KHz and not introduce resistance in series with the cap, if you look at the rating of ESR (PANASONIC fm/fc series cap made for switching power supply, it is in milli Ohm range. Better off replaceing 50 cents parts or use good cap meter that can do leakage, ESR, capacitance test if you want to analyze the caps, shop time will be too expensive. Just my 2cents adn 30 years of experience.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 23, 2010 | Dell E193FP 19" LCD Monitor
Ice dispenser in door- won't deliver whole ice
Dear Sir,
I have purchased a whirlpool refrigerator on dt.05.11.2006 from M/S.Ganesh Enterprises, Angul bearing Invoice No. 335. last few days the main door of the refrigerator is not working properly. A part is broken from the door(clamp). Inspite of repeated contact and reminder the dealer have not taken any action till today and telling that the parts is not available.
I am very much dissatisfied with the service of the dealer. Therefore I am request you Sir, kindly look into the matter and necessary action in this regard please be taken.
Thanking You,
Yours faithfully,
R.Agarwalla,
06764-232367, 234667
Jul 15, 2008 | Refrigerators
k24674
jasbo
jasbo
