Question about Sony Trinitron Stereo Kv-27s66 27 Inch Color 27" Tv
I have a Sony Trinitron TV model number KV27S66. This morning I turned it on, it worked for a few seconds then the picture became a vertical rainbow and then the TV shut itself off. After unplugging i
Unplugging it for a few minutes then plug it in and turn it on....no change. Then doing a reset.
    Top Expert:
  • Sony Master
  • 74,459 Answers
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Dec 15, 2014
My Sony Trinitron stand by/timer light is on and will let me put tv on but only stays on for a few seconds . Model #KV27S66 Oct 99
Your TV has an overload due to some faulty components inside it. This type of fault is usually noted with overheating of horizontal output transistor connected to LOT of the TV. This may be due to LOT fault, or fault to the transistor itself. When it overheats, it put a short between supply rail, and the power supply regulator system inside your TV will detect that short and will shut down automaticaly. Please note; if the TV works after some time, say after 15 or 20 minutes; and again shuts down after working for a short period, and the cycle repeats, surely there is a winding short inside LOT, which cannot be detected by normal multimeter measurments. If it is so, replace LOT and the horizontal output transistor at the same time.
Oct 14, 2010 | Sony Televison & Video
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV switch light flickers 11 times but no function
Hopefully it is only a board component that needs replacing and your dry joints that need re-doing. I would advise that you take it to a television repair shop as this type of repair can be very complex (replacing resistors and capacitors just to name a few).
Dec 03, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Wega Trinitron KV-32HS20 TV
The 4 blinks usually indicate a vertical problem. If you can solder, you can fix this yourself. Let me know if you wish to attempt this repair. If not, expect a parts cost of $10-$15 plus the local labor rate for the repair.
Dan
Oct 01, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
What`s seems to be the porblem
IT SOUNDS LIKE THE VERTICAL I.C. NEEDS SOLDERING. WHEN IT LOOSES THE PICTURE DOES IT HAVE ERROR CODE 2 ? THE RED LED BLINKING 2 THEN 2 THEN 2. THAT IS LOSS OF VERTICAL. IF YOU SMACK THE SIDE OF THE SET.(NOT TO HARD) WITH OPEN PALM ON LOWER BACK IF THE PICTURE COMES BACK IT IS THE VERTICAL IC THAT NEEDS TO BEE SOLDERED.
DON.
Jan 31, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Color Rainbow
Usually when a tv is dropped the phospher screen inside the picture tube will detatch making the rainbow color This cannot be fixed as it requires changing the picture tube. Only other thing is demagnatize it with a demagnitizing coil (used by tv techs) but not likely to fix it since it was dropped. You have a bad picture tube.
Dec 30, 2007 | Sony KV-32FS13 TV
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
Mar 31, 2007 | Sony KV-27FV16 TV
Sony Trinitron Stereo Kv-27s66 27 Inch Color 27" Tv Logo
70 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
