Question about Stihl Garden
Fuel going into cranckcase but new sparkplug is dry, why wont it fire?
Put new carb kit, new sparkplug
  • Stihl Master
  • 1,169 Answers
Check your muffler's spark arrestor.
Posted on Dec 14, 2014
Testimonial: "checked spark arrestor,it's clean, not plugged"
I have a baja 90cc quad it dose not have kickstart i put in the key and it wont start i got a new sparkplug and a new battery still wont start
Do you have fire at the spark plug. If so check compression, then if not check fuel system(( carb)
Jul 29, 2017 | ATVs
Gets fire and gas wont start
Be careful with primerbulb especially if use alkylat fuel for a fuel surplus some times remove the sparkplug and holding the mufler in down to the ground position so to release the surplus out of the machine , if that is not working after replace sparkplug and starting , then you can have a problem with compression but first the spark of your machine must be colored white/blue and not red. if thats also good then remove the muffler and look on the exhaustside of your piston if there are grooves on then you know whats wrong in the fastest time if that is not that it looks smooth like a mirror then seals on the crankshaft , tankairiation good ? gasket(s)carburetor and cilinder underside .
Feb 08, 2016 | Garden
My kfx50 will not start
your jets is blocked
Oct 13, 2014 | Motorcycles
Got a 1978 ds100 wont start when i put sparkplugs next to motor little if no spark but when i hold it ,it shocks me
If you see a spark most likely you have enough energy to fire it. If it wont start more than likely your carb needs to be rebuilt. Kits are cheap, just remove carb, clean with carb cleaner, clean all orifices with a piece of brass or steel from a brush. Try not to enlarge the holes, blow out with air if you have it, be careful to put it back together. Clean out tank an replace fuel lines. If you have compression it should start after rebuild. If you want you can just purchase a new carb an make it easy on yourself. Somewhere between $30-50 to replace. That should do it.
Mar 23, 2014 | Toro Snowblower 826 Oxe 38624w With 3 Year...
Scag zero turn 52"deck tiger mower
If you have spark, compression, and fuel to the carb but not at the plug. You have a clogged carb. Try starting with starting fluid, if it fires briefly, your carb needs to be removed and cleaned.
Sep 03, 2013 | Garden
I've put a new sparkplug and new filter -but the blower won't start . Doesn't even feel like it wants to start
Put a spoon full of gasoline straight down the plug hole. Reinstall the plug, if it starts then you obviously have a fuel problem. You may need a new kit installed in the carburetor. Easy fix.
Nov 17, 2010 | Craftsman 4 Cycle Blower/Vac
Hello i have a 1986 Honda fourtrax 250 2wd atv and i just bought it. the previous owner stated that he hit a ditch and it flipped. once turned back over it would not start. 2 years later i buy it and it...
Pull the carb and throughly clean it after sitting the old fuel will turn to varnish and clog everything up. also if the machine was on its top check the oil and make sure it is clean. leaking gas is a indicator that you will probably need a carb kit for it that must include the float valve and needle.
Oct 29, 2010 | Honda CB 250 Motorcycles
Starting 2007 kawasaki klx 250
• The first thing to do with ANY engine that has sat for any longer than a couple of months is to dump ALL the fuel in the tank and carb(s). ALL OF IT !! You'll want to refill with some high priced fuel that has fuel system cleaners (Like Chevron with Techron) not becasue you need high-test fuel, but because you need the cleaners. It's ether that or disassemble the carbs and clean out jets you can't find much less see. Your choice. The carb kits alone will cost you about $50 so a tank of high-test is looking pretty good, huh?
• Now the fact that you tried to crank the engine with old fuel has fouled the sparkplugs. All of them. Go buy all new sparkplugs.
• If your bike has a vacuum fuel valve, then you'll also need to set the valve to "Prime".
Mar 21, 2009 | 2007 kawasaki KLX 250
Yumbo wont start
• Now the fact that you tried to crank the engine with old fuel has fouled the sparkplugs. Go buy a new sparkplug.
Mar 21, 2009 | 2004 Yumbo Dakar 200
Will not start
you dont need a manual. you need competent troubleshooting knowledge.
do you have an ignition spark? if you do then it will fire up on WD40 or StartingFluid sprayed in the opened carb. if it does and you have a clean fuel supply flow. clean the carb paths.
If no ignition spark present, check wiring, meter the coil for possible open circuit,
Mar 11, 2009 | Garden
Garden Logo
63 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
