Question about Zephyr Kitchen Ranges
The 4 lights on my zephyr 42 hood fan stopped working but the other 4 push buttons work fine. I ordered a new circuit board, replaced it making sure to take all grounding precautions while handling th
Replaced circuit board with new one. Lights worked while hood fan was off wall and powered up but after replacing it back onto wall and depressing the light button it did not turn on lighting.
  • 171 Answers
SOURCE: Zephyr Milano hood fan and lights stop working. Power is on.
Hi ronio,
I'm Harvey the Master Plumber.
Your problem is: After the power went out your Zephyr hood lights and fan don't work at all. There is a faint glow on the digital display but the fan and lights don't respond to pressing the control buttons.
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer. If OK then you have a bad control board.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 27, 2008
SOURCE: Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Posted on Mar 11, 2010
espressonist
  • 1711 Answers
SOURCE: My fan and lights stopped
You should check the lamps if they are ok and if you have a new one try to be 100%.
If not you should the fuse internal. We have here a parts diagram and fuse is part no 170 and is a 5A fuse.
Finaly since the board is new and consider that the connections have been set correctly then you should check the light transformer part no 208 in same diagram. Check whith a multimeter in and out voltage if it is ok.
Posted on Aug 19, 2011
  • 159 Answers
SOURCE: touchpad doesn't work, F1 code
Most likley you have a bad touchpad. Most times its a key that is stuck and there is nothing much you can do except replace the touchpad control. It is a common problem with all electronic ranges. If the range is 13 years old I would thik about replaceing it. Good luck
Posted on Jul 16, 2007
  • 833 Answers
SOURCE: kitchen aid stove problem
Peter,
First...be sure you cut power to the stove before you do anything. This is 220 volts and it can kill you. 220 Volts is based on two different lines of power coming to the stove, each of which is 110 volts...but opposite each other in phase. This may mean that some power to the stove is on and some is not. Let's go on.
I suspect a few things: First, the coil control for the burner is probably finished. What I also suspect is that it opened one of the two breakers (they are usually tied together in the panel and are either 40/50/60 amp units) causing some lights but no action.
What to do: Reset the breakers as a pair by turning them off and on. If one snaps off, you have a problem at the stove. If not,...which I doubt...you're in business.
Let's look at replacing the control. Shut the breakers. Now, take the burned control and remove it. Note the wiring positions if they are not on a plug. If they are terminals, tape the ends. Now, reset those breakers. If the other burners work, replace the control. Take the old one to the parts store. If it doesn't work, look around the burned area for broken wires. Repair and tape them up. Try again. Oh, and don't let anyone touch the stove while you're working with those breakers.
Posted on Dec 03, 2007
Replaced light bulbs but no light
Original bulb has a JDR designation. I ordered bulbs and received bulbs with a JDRC designation, the brand was Hikari--these bulbs were shorter than the original bulbs and will not seat properly even after removing filters and turning bulbs by the neck of the bulb (porcelain section). Since they won't seat completely in the socket there is no electrical contact and they won't work.
Feb 05, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
Fan and light does not turn on .
FAN AND LIGHT DOES NOT WORK
my zephyr typhoon stopped working. Neither light not the fan come up. I am sure there is power going into the unit. I turned on the light one day , the light cam on and suddenly went away. From then even the fan stopped working. any information on what happened is appreciated. Thanks
Jan 22, 2009 | Zephyr Typhoon AK2100 Kitchen Hood
Neither lights nor fans work
don't know model but they are all much the same.
there will be a pcb behind the control buttons and you will find some of the track burnt out causedd by the bulb blowing. do a soldered wire link across the burnt section of the track
Sep 25, 2008 | Zephyr Typhoon AK2100 Kitchen Hood
Hi ronio,
Thank you,
Sep 22, 2008 | Zephyr Milano-S ZMI-M90S Kitchen Hood
Zephyr typhoon AK2100 Kitchen Range Hood
its the relay inside that controls which speeds the hood works at this connects to the switch speed control
Jun 01, 2008 | Zephyr Typhoon AK2100 Kitchen Hood
Push Button Switched
zepher sent replacement sritch.
had to wait a while -parts from italy (heh)
so far ok
design is poor
Feb 29, 2008 | Zephyr Savona ZSA-M90S Kitchen Hood
Feb 21, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Zephyr ZMI-M90S stopped working
The company doesn't list such a part. Probably, you have a bad connection in the unit. With the power off, remove the motor housing. Find the connection box and fix up the connections.
Nov 20, 2007 | Zephyr Savona ZSA-M90S Kitchen Hood
Kitchen Ranges Logo
144 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
The Vanguardian
The Vanguardian
Dale Copeland
Dale Copeland
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
