Question about Seiki Televison & Video
Seiki flat screen less than two years old show white vertical lines and a bullet hole bleed in middle of screen. Charter cablebox and remote were giving trouble with on/ff and volume. Bought from Sea
NOTHING. IT IS DISCONNECTED NOW
    Top Expert:
  • Seiki Master
  • 74,383 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Dec 15, 2014
Have 39 inch seiki tv have white lines vertical no picture
Aug 25, 2014 | Seiki Televison & Video
I have a Toshiba 32"
You need to replace the TV screen. It could not be repaired. Just get it replaced at dealer.
Regards
Dec 17, 2010 | Televison & Video
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
My TV is less than a year old. It has white
Do these lines disappear after the set warms up a little? If they don't then you most likely have bad buffer boards(X buffer or Y buffer). Sometimes it is also caused by a bad panel. Since your tv is less than 1 year old and is still under the 1year manufacturer warranty I strongly suggest that you contact the manufacturer for repairs.
Contact info:
E-mail: support@sanyotv.com
Phone: (800) 877-5032
Fax: (870) 630-4223
Please rate this solution if you found the information helpful.
Thanks,
Sai.
Mar 29, 2010 | Sanyo DP50747 50 in. Plasma TV
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Heavy white lines accross the screen
Replace it, it is going bad. I could tell you what would cause this such as bad driver IC etc. but bottom line is its five years old, you got your moneys worth out of it so bite the bullet and get a new one.
Feb 11, 2008 | Envision EN 9110 19" Flat Panel LCD...
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Polaroid FLM 2632 HDTV
I hae replaced my polaroid FLM-2632 3 times it is a crappy tv same problem every time do not buy one
Dec 18, 2007 | Polaroid 3211TLXB 32 in. LCD Television
Televison & Video Logo
60 people viewed this question
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
shaun taylor
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
