Question about Trek Cycling
Remove front sproket on trek 1.0 bike - Trek Cycling
  • 74 Answers
Are you talking about the Trek 1.1 road bike or the Trek FX 7.0?
Posted on Feb 21, 2015
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: trying to replace the berrings
http://www.parktool.com/blog/repair-help/adjustable-type-bottom-bracket-service
Posted on Jul 07, 2011
How do I remove the front tire of my Trek Fuel Ex 7 29?
Check youtube my friend, there are great instructional videos there.Remove wheel from front forks, release any air from tyre, using 2 plastic tyre removal tools to remove tyre. Further instructions will be found on youtube.
Aug 28, 2017 | Trek Cycling
I have a trek 5200 OCLV Series with S/N WL0044613 what year is it.
You are already on the Internet, so do some research, which is what anyone here would have to do. Contact Trek - Trek Bikes The world best bikes and cycling gear Trek Bikes , Google "Trek serial number" or Google your model and look for images that match your bike, or check BikePedia
Mar 29, 2017 | Trek Cycling
What kind of Gary Fisher bike do I have adding the serial number
Its possibly a TREK, contact the nearest bike shop who sells either GF or Trek.
Sep 09, 2014 | Gary Fisher Cycling
How to remove trek bike pedal
contact local bike shop for assistance
Jul 16, 2014 | Trek Cycling
Need to adjust front brake pads
There is an adjuster where cable enters brake caliper
Also you could loosen mounting bolt. Realign and tighten.
Apr 09, 2014 | Trek 3700
What is leaking on 02 gsx 600 near the broken sproket cover
there is a oil seal behind the front sprocket that may be damaged.Also the case may be crack due to chaine impact. This type of damage is common when chaine is not kept to spec..If case are crack you can repair with jb weld no oil pressure at this location. Have to be clean and scuff for product to work properly.Mr cee's cycle Repair.
Sep 16, 2012 | Suzuki GSX-R 600 Motorcycles
Popping noise coming from front sprocket when wheel is turned on 01 suzuki gsxr 600
hi it sounds like your front sproket is really worn and hooked when you turn the chain its not releasing the links smoothly ,replace it with a new one and check the condition of your chain it may be worth replacing a complete chain and sproket set as running a bike with a worn front sproket could lead to a back wheel locking up at speed if the chain jams
Feb 22, 2011 | 2001 Suzuki GSX-R 600
The derailer front and rear move only two cogs
Take your bike to a Trek Dealer, you can cause more damage if it is loose or too tight. You have a good bike, don't skimp and have someone "fix" it that really does not know what they are doing. I've seen many that the owner's buddy "fixed" and it always means more work and more expensive because we have to undo the damage first
Sep 07, 2010 | Mountain Trek Fisher Bike Derailleur...
Cant undo nut
No they are not left hand thead,normal r/h thread.
make sure chain is still on bike and front sproket and then try good rattle gun. if this does not work,put bike in gear and hold on rear brake and use long breaker bar, if still no good will need to heat front sproket nut with oxy set very carefully and rattle off with rattle gun while nut is hot
Jun 23, 2010 | 1997 Yamaha YZF 600 R thunder cat
Cannot fit to my Trek 820 due to
You have to use a different fork. There are three standard steering tube sizes: 1"; 1.125"; 1.5". The 1" is found on budget bikes, older bikes and some cruiser/hybrid bikes. 1.125" is the most common size and is also usable on 1.5" head tubed bikes using reducing headsets. 1.5" is found on heavy-duty mountain bikes and some carbon fiber road bikes, although its use is increasing in popularity.
The point is, you can sometimes convert down, but never up. You have to source a different fork.
Sorry, mate
matthew
Nov 01, 2009 | Cycling
Cycling Logo
135 people viewed this question
Top Trek Cycling Experts
Andrew Crawshaw
Level 1 Expert
dante
Are you a Trek Cycling Expert? Answer questions, earn points and help others
