Question about Pool & Spa
How much lead weight would a person weighing 13 stone need to use going scubu diving ?
Google
  • Pool & Spa Master
  • 1,363 Answers
This all depends on the type of water and if using a wet suit , you will need to experiment, start off light and just add weight untill you start to slowly descend down What Suba Divers Need to Know About Buoyancy
Posted on Jan 09, 2015
What is the correct metric weight for 13 stone.
14 lb = 1 stone
so 13 stone = 182 lbs ( troy )
182 lbs = 67.929 kg
or in ave poy lbs
182 lbs = 82.5 kg
the difference is depending on which country you are in
Jun 07, 2017 | The Health & Beauty
How many yards in a ton?
As a rule of thumb, you can multiply the cubic yards by a factor of 1.4 to get tons. But remember, yards is a measure of volume where tons is a measure of weight. Thus, depending upon the material being calculated, true weight can vary greatly. Obviously a yard of wet sand will weigh far more than a yard of dry sand, as water is more dense and has more weight than the sand it displaces in the volume. Large crush stone may weigh far less than pea gravel for the same volume as there is less air gap around the gravel than there is around the large crush. If you need a true weight of a yard of some material, you would have to know its weight in a particular volume and then calculate from that value.
Nov 03, 2016 | Cars & Trucks
Does anyone know how many average size bluestones one coould put into the aluminum tray of a 1992 Rodeo. Or what the caring weight of this tray might be.
weigh a sample of your average bluestones and divide that into 1000kgs (1ton) and by spreading the stones all over the tray that will be the total number that you can carry. So if you average weight is 10 lbs (5 kgs) then you could fit 200 stones on the tray. If you cannot weigh the stones because of size then load the tray until the distance between the axle bump stop and axle has decreased by half . This will be within the load limit . Any more and you can be considered overloaded.
Apr 25, 2014 | 1992 Isuzu Rodeo
ERr
Are you talking 31 "Stone"? If so, I believe that comes out to 434lbs. You are lucky if your scales can read that high. For testing purposes, remove your shoes or more if you think your right at the upper limit. Or let a slightly lighter friend try it. I assume your talking "Stone" as used in the UK. Are you from there? (I,m in the US, in Florida.) Also, there should be a switch on the bottom of the scale (upper left corner) allowing you to switch between lbs, st and kg. You can try that as well, although the limit should be basically identical. If you tell me more, I can help you more.
(By the way, I weigh 197 lbs right now, that's 14 stone.)
May 19, 2013 | Health & Beauty
1 cup is to how many grams?
A cup is a measure of volume, but a gram is a measure of mass.
Depending on the density of the material you are going to have in the cup, the weight in grams of the material will vary. For example, if you fill the cup with lead, the cup will weigh much more than if you fill with feathers.
This question would be similar to asking how much does a 6 foot person weigh. It depends on the person of course. A cup of water will weigh more than a cup of flour.
Examples:
Granulated sugar: 1 cup = 200 grams
Brown sugar: 1 cup, packed = 220 grams
Sifted white flour: 1 cup = 125 grams
White rice, uncooked: 1 cup = 185 grams
Aug 23, 2011 | Computers & Internet
Kitchen scales & weights
Hope this helps,plz let me know
JonnieC
Weighing 1
006s1.gifWeigh 1 2 3 on the left and 4 5 6 on the right
If the weights are even go to Weighing 2a
If the left side is lighter go to Weighing 2b
If the right side is lighter go to Weighing 2c
Weighing 2a
006s2a.gifWeigh 7 on the left and 8 on the right
If the left side is lighter then weight 7 is the answer
If the right side is lighter then weight 8 is the answer
Weighing 2b
006s2b.gifWeigh 1 on the left and 2 on the right
If the weights are even then weight 3 is the answer
If the left side is lighter then weight 1 is the answer
If the right side is lighter then weight 2 is the answer
Weighing 2c
006s2c.gifWeigh 4 on the left and 5 on the right
If the weights are even then weight 6 is the answer
If the left side is lighter then weight 4 is the answer
If the right side is lighter then weight 5 is the answer
Mar 16, 2009 | Nintendo Professor Layton & the Curious...
Length of board
It's more about personal preference. I'm 5'8" and weigh 155. I ride a 155 burton blunt and 147 ride kink. For days with powder I like the longer board and for packed powder days and park days I love the 147. There's no one size that's right or wrong. If you like doing tricks a smaller board may make it easier if you like crusing a longer board makes sense. The longer the board the faster you'll go. The Palmer Prodigy is a fine board, a 160 would be well within the range you can ride, remember you're only talking a few centimeters difference between many models. Good luck and stick with it!!
Jan 21, 2009 | Palmer "prodigy" Snowboard Mens 160cm
Pool & Spa Logo
46 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
