Question about Singer Futura Xl-400 All-In-One Sewing And Embroidery Machine
My stitch is not tight. Bottom thread is loose. I've been told it could be my thread. Is that the problem? If so what threat should I use?
    Sergeant:
  • Singer Expert
  • 455 Answers
Hi Jean, I think Debbie is going in the right direction. Tighten the bobbin case tension to tighten stitching on the backside.
CHeers,\
Kelly
San Diego, CA
Posted on Dec 15, 2014
  • Singer Master
  • 1,860 Answers
Try loosing the top thread tension,, if that doesn't work then try adjusting the bottom thread tension.
SOURCE: thread on bottom, bobbin thread loose
Sounds as though you've misthreaded the upper tension. The best way to verify this would be to thread your machine, lower the presser foot on to the material. Now try pulling the thread through the needle. (Assuming your upper tension dial is set to a number greater than one). You should feel resistance. Should you not feel resistance, rethread your upper tension.
Posted on Feb 01, 2008
kent581
  • 87 Answers
SOURCE: bottom of stitch is bunched with alot of thread and machine jams
Try these time savers:
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Posted on Mar 18, 2009
Mimito7
  • 128 Answers
SOURCE: loose stitches on bottom
FYI.. Loops on the bottom, problem is on the top..
Loops on the top, broblem is with the bobbin.
Posted on Apr 19, 2009
SOURCE: I do a few stitches
sewusa.com has threading diagrams
singer.com has free manual for a singer 1120
just go to the singer website & put in the box 1120,,the 2 bottom ones are free
Posted on Nov 30, 2010
Testimonial: "Thank you. That's what I really want cheers cb"
  • 233 Answers
SOURCE: singer sewing machine bobbin thread knots rather
What you have going on is a bobbin problem. The knots are referred to as birds' nests and happen when your bobbin thread gets caught on a piece of the bobbin casing. The large, loose stitches are normally caused by a problem with the bobbin case, a bobbin that is would properly, or when you're getting to the end of the bobbin's thread and the thread is loosely would on the bobbin at that point.
You're best bet is probably to buy a new bobbin casing. They're usually about $25 or so and you should be able to find one on eBay by searching for Singer (your machine name and model) under the Crafts category. The silver plate on top of the area covering where you place your bobbin into has screws you need to carefully remove (careful not to loose them!). If you need to, take pictures with your cellphone or digital camera as you remove the old bobbin casing so you can see how to put the new one in.
This should take care of the problem. If, for some reason it doesn't, you may well have a problem ALSO with your bobbin tension, and that should be looked at by a Singer Technician. You can find one in the yellow pages near you or probably by searching Yahoo Local. Happy Sewing.
Posted on Apr 04, 2011
I need to find out how to set up my machine for polyester/spandex material.
For spandex you will probably want to use a size 70 needle for stretch fabric. You should be able to leave your tension settings on standard tension but may need to go for a slightly shorter stitch length.
try stitch length of 2.5 or 3
tension of 3.5
check your bobbin tension, to do this thread the bobbin and suspend it in the air holding the thread. If the bobbin falls to the floor the tension is too loose. If the bobbin hangs in the air and you give a gentle tug on the string the bobbin should slide along the thread an inch or so. If it doesn't budge it's too tight.
When you say the thread is not the same on top as the bottom do you mean you are using different threads or that the stitches are coming out different on the top to the bottom of the fabric?
Mar 28, 2013 | Bernina Activa 140
Singer 2517c. When sewing, the bottom stitch is using to much thread, excessive amounts & the stitch isn't tight. I've tried all settings & have used a new bobbin. I'm at a loss......
Your description isn't very clear. When you say the "bottom stitch is using too much thread" Do you mean you see lots of loopy threads on top of the seam? Or do you mean you see loops on the bottom under the fabric? If your loops on the bottom, that means the top tension is too loose, you've not remembered to put the presser foot down, you have not threaded the top thread properly... Start by rethreading carefully with the presser foot UP. Then do a test stitch, remembering to put the presser foot down. If you still get loops underneath... tighten the tension.
If your loops are on the top of the fabric. loosen the top tension... then do a test seam... and if you still have loops loosen again and repeat. If you start to see loops on the bottom... tighten the tension a bit.
Good luck
Dec 30, 2012 | Sewing Machines
Bottom thread on Juki DDL-5550 is coming up. Top thread seems to lie flat
Check your upper thread at the spool. I've had industrial machines randomly throw a loop around the spool holder spindle which is hidden under the spool itself.
Also check your threading guide to be absolutely certain you are threading it correctly. Also make sure needle/thread diameter are suitable for each other.
Good luck.
Dec 02, 2012 | Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
My top stich is tight but my buttom is loose on my brother sewing machine
if the bobbin stitch is loose tighten the top thread tension one number at a time & sew alittle bit & if it's still loose tighten it one more number till you get the correct stitch
Feb 10, 2012 | Brother XL2600 Mechanical Sewing Machine
The bottom stitch is very loose. I've tried tightening and loosening the screw and the problem remains...HELP!
The bottom stitch is affected by the TOP thread tension :) First go back and make sure your bobbin tension is correct since you adjusted it. It should drop slightly when held suspended by danging it by the thread. If it reels out to the floor it is too loose. If it doesn't drop at all it is too tight.
Now that you have that adjusted look at your top tension. If it is loopy on the bottom side of the stitch the TOP tension is too loose. Increase the top tension.
Now take some scrap material and set machine to a wide zig zag, medium length stitch and sew a bit. Compare the top and the bottom sides of the stitch. They should look identical. Remember the TOP side effects the bottom and the BOTTOM tension effects the top side. Adjust accordingly until they look identical with no loose threads or loops and no puckering (puckering means it's too tight).
May 03, 2011 | Brother LX3125 Sewing Machine
My tension is bad. I've tried adjusting, but no success. The lower thread can be seen between the stitches on the top side. How do I correct this.
I'm not completely familiar with your machine, but I would suggest tightening the bobbin tension on your machine. Check you owners manual for instructions. The symptom you've described is either top tension too tight or bottom tension too loose. Good luck!
Apr 18, 2011 | Bernina Activa 130
My top stich is tight,but bottom is loose of my singer sewing machine.
Think in opposites... the top stitch is formed by the bottom thread tension and the bottom of the stitch by the top. So either the bobbin thread is too tight or the top thread is too loose. Check the bobbin thread first as that is the one most overlook. It should come out of the bobbin without having to yank it hard but it should have a little resistance.
Mar 22, 2011 | SINGER 7470 Sewing Machine
The thread underneath when sewing is too loosed
Usually thread too loose on the bottom is caused by the upper tension being too loose. The top and bottom tensions work together with the top thread making the underside of the stitch seem too taunt or too loose and the bobbin thread causing the top side of the stitch to be loopy or too tight. Select a large zig zag stick and sew a couple of inches. Then examine the stitch. It should look identical on both sides. Look to see which side is drawn too tight, the zig zag being smaller on that side with threads from the bottom threads pulled through. Then adjust the two tensions so that they make a uniform, identical stitch.
Also, when the bobbin tension is right you can hold the bobbin dangling by the thread and it won't spool out to the floor but will let loose a bit with a slight flick of the wrist. Too loose it will just spool out. Too tight and it won't drop at all. When you get that set right then do the above zig zag test to see where the top tension should be set.
Mar 02, 2011 | Sewing Machines
Top stitche is to tight and bottom stitche is to loose
Meaning you have adjusted the tension for the top thread as well as the bobbin?
Use two distinct colors of thread - one for the top and one for the bottom.
Thread the machine with the presser foot up.
The two threads should meet in the middle of the stitch with neither obvious on the opposite side of the seam.
Set the top thread tension to 4 and adjust the bobbin as needed.
May 01, 2010 | Brother CS6000i Computerized Sewing...
Singer Futura Xl-400 All-In-One Sewing And Embroidery Machine Logo
192 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
