I have LG KE770. I have problem connecting to the network. ''Limited service'' and '' No network'' messages friquently apear on the screen.I`ve been advised to apgrade the software but Vodacom South Africa can not help, because ''the phone was purchased from another country'' and their system can not reed the manufacturing number of the cellphone which is : IMEI : 355254-01-068743-G ; S/N : 706 KPG 5068743. My e-mail address is : [email protected] Is there any hope ?!...
You may occasionally get an error message that reads "This connection has limited or no connectivity. You might not be able to access the Internet or some network resources." It indicates that your PC is having a problem trying to access your network device to connect to the Internet. Very often, a bug that typically affects Windows XP Service Pack 2 causes this error message. This bug causes a loss of your network connectivity in workstations that use Microsoft's L2TP-based VPN (virtual private networking) client to connect to the NAT-based networks. You can fix the "Limited or No Connectivity" problem in a few steps. (If your connection works but you still get the error message, go to Section 2 to learn how to disable it.)
Review the following symptoms and determine if you experience any of them after you install the Windows XP Service Pack 2:
You get the error message "Limited or No Connectivity" when you attempt to connect to your network.
You have a problem connecting to your local area network or to the Internet. You keep on receiving an error message: "Acquiring IP Address" message. If you experience these symptoms after installing Windows XP Service Pack 2, then this bug is causing the problem. In this case, go to Step 2; otherwise, skip to Section 3 Download the Microsoft patch (KB884020) from the Microsoft website. Run this update to install it. Create a registry fix by launching Notepad and typing: [HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Services\\IPSec] "AssumeUDPEncapsulationContextOnSendRule\"=dword:00000002 Save the file as FixReg.reg to your desktop. Double-click the saved file to install it into your registry. Restart your computer and the error message will likely be gone. If you still see the error message, follow the steps in Section 2. b> If Your Connection Works But You Still Get the Error Message b> Navigate to the "Start" button and select the "Control Panel." Double-click on the "Network Connections" icon. Right-click the "Local Area Connection" icon and select "Properties" from the popup menu. Click on the "General" tab. Uncheck the option that is labeled "Notify me when this connection has limited or no connectivity." Click "OK." b> If the Patch Doesn't Fix the " Limited or No Connectivity" Problem b> Check your DSL router for any malfunctions. Re-configure or power cycle your router. Check your computer's network card configurations and network cabling to ensure that the problem does not lie here. Check your firewall to determine whether it is blocking you from connecting to the network or to the Internet. Disable the firewall and attempt connecting to the network or Internet while with the firewall is disabled. If the firewall is causing connection problems, then reset or uninstall and re-install the firewall. Reduce your connection speed to 10 Mbps and test this to determine if it fixes the problem. To do so, navigate to the "Start" menu and select the "Control Panel," "System" and "Device Manager." Review the properties of your network card. Click the "Advanced tab." Locate the "Link Speed and Duplex" section. Change the settings from "Auto Detect" to "10Mbps/Full Duplex." Hope this helps.
You can unlock your LG network using LG Shine KE770 unlock code for telstra. You can get that LG unlock code from third party sites or request from your network provider. Don't forget to pay some bucks for that unlock code but usually network provider will charge you more higher.
We have a family plan with AT&T and we each have different phones: a Blackberry Pearl, an LG KE770 Shine, a RAZR and a Pantech. All the phones get strong AT&T signals at home except the LG Shine which shows no signal at all. This is true also when we go to different parts of town...all the phones get strong signals except the LG may or may not have a signal. We took it to a service center and they gave us a new SIM card but the problem remains. What could be the problem except the possibility that the LG Shine really sucks?
im having a problem. Win xp wont even recognize that there is
anything connected, yet my phone still charges through the usb port. I
really hate bill gates, can anyone help me??
