Question about Refrigerators
How can I diagnose
Freezer and fresh food will not stay cold unless the "turbo" mode is used. I have replaced the thermistors, thermostat, the main control board (WR49X10147), made lots of voltage/signal measurements, and cleaned it to no avail. Does it have a self diagnostic feature? Appreciate any help you can offer.
  • Roy Bobbitt
    Roy Bobbitt Dec 14, 2014
    GE Monogram ZFXB25DTGSS Refrigerator - wanted to add to my previous post of ------Freezer and fresh food will not stay cold unless the "turbo" mode is used. I have replaced the thermistors, thermostat, the main control board (WR49X10147), made lots of voltage/signal measurements, and cleaned it to no avail. Does it have a self diagnostic feature? Appreciate any help you can offer.
4 Suggested Answers
  • 17 Answers
SOURCE: I have a GE side by side refrigerator GSH22JST and
Okay,
What is your Freezer temp rating?
Did you check the refrigerant PSI rating?
Is your condenser restricted?
Let try adjust refrigerator to less cold and adjust more cold for freezer. and see what your temp rating.
nguyen@ite.net
Posted on Jun 09, 2009
  • 2295 Answers
SOURCE: zisb480dmc monogram, replaced Fresh food
there's a temp sensor on the evap coil part WR55X10025,i would change that out and when you changed the board if there's a wire in the second pin of the connector with ithink 9 pins on it you have to cut the wire that's in the second pin,if there's no wire in the first pin but one in the second pin then leave it alone,look at the paper that came with the board and it will tell you what connector it is,let me know what you find,the old sensor has like a black piece on it where the wires come out of it,the new one is all white but you should change the sensor when you change out the board
Posted on Sep 30, 2010
richroth
  • 9472 Answers
SOURCE: compressor runs continuously freezer is
Temperature settings adjusted too cold.
If controls are set too high it causes the unit to run longer. See use and care guide for more detailed information. Doors being opened frequently or for long periods. Each time the doors are opened, the cold air inside is exchanged with the warm humid room air which causes the unit to run longer. Open doors as seldom as possible and close them promptly.
Warm humid weather causes the unit to run longer to maintain normal interior temperatures and humidity levels. Run household air conditioner if possible.When the condenser coil becomes clogged with dust and / or pet hair (if applicable), the unit has to run longer to compensate. Clean condenser coil at least twice per year or more often as needed. See owner's manual for instructions on how to clean condenser coils.
  • Turn unit off and unplug the cord.
  • Remove toe grill from the bottom of refrigerator.
  • Vacuum the accumulated dust from underneath the refrigerator and the back of the toe grill.
  • Brush the coil with the brush and then vacuum again.
  • Clean toe grill with mild soap and water and put in back in place.
  • Plug unit back in and reset controls.
Posted on Sep 07, 2011
Freezer working fine, fridge not at all
Brand name and model would help but here is a guess. Most frost free refrigerators have the main cooling unit in the freezer area side. To get the fresh food side cold, there is a small fan in the freezer side that blows cold air to the fresh food side through a duct work or trap door. If that fan stops or fails for and reason, the first place you will notice the temp rise is in the fresh food section. See if you can hear the freezer fan running. You may need to push in the door switch for the freezer light to hear the fan because they sometimes run the fan wiring through the door switch. It may stop when door is opened.
Apr 03, 2015 | Refrigerators
What else can I check - my fresh food side of fridge is still too warm, freezer fine.
GE refrigerators use a board to control cooling and defrost functions. The fresh food compartment also utilizes a motorized damper, and some models even have a fresh food fan. Air enters the fresh food compartment at the top left corner, and the return air is also in the left wall down near the crispers. Both paths must be clear.
Jul 21, 2014 | GE Refrigerators
GE ZIS420NX Refrigerator temp control not effective, food is freezing
you have a few things that could be wrong, a bad thermistor, a bad air defuser, or a bad main board. changing the thermistor could fix it but if not, i would call a pro that order the right part. lots of varibles.
Apr 08, 2012 | General Electric GE ZIS420NX (25.4 cu....
My compressor runs but I think it shuts off and stays off too long...the box gets to warm and the ice starts to melt before it starts again
First of all, before you do anything, clean the coils under the refrigerator. I couldn't tell you how many refrigerators I've 'fixed' that needed nothing more than the coils cleaned. Dirty coils can cause a multitude of problems, many of them with the exact same symptoms that would be expected when refrigerant components fail. Dirt is the #1 enemy of any refrigeration unit.
If that doesn't help, since both sides of the refrigerator get warm before the compressor kicks back on, I'd suspect the fresh food temperature control thermostat. Not an easy fix for the average homeowner unless you've got specific skills in appliance repair.
Before you do anything, try this. Turn the fresh food thermostat all the way up, the set the freezer setting at a higher than normal setting. The way the system works is that the fresh food thermometer turns the compressor on and off and the freezer control simply controls how much of the cold air from the freezer is diverted to the fresh food compartment.
If you turn the fresh food thermostat higher, the compressor will run longer and adjusting the freezer control to a higher setting will allow less cold air into the fresh food compartment, forcing the compressor to run longer in order to cool it to the thermostat setting.
If the settings have to be abnormally high, this is a workaround, rather than a fix. To get a permanent fix, you'll probably have to replace the fresh food control thermostat.
I hope this was helpful to you or to anyone reading it.
Oct 10, 2009 | Amana Refrigerators
Freezer extremly cold, some frost on items. The fridge is also too cold, freezing food in the bottom crisper bin. Kenmore Elite side by side model # 5320902. We have the temperatures set higher to...
The compressor is cycled on/off by the fresh food temperature setting. The freezer setting controls a panel, or door if you will, that allows cold air to be blown into the freezer.
Since both compartments are getting too cold, the most likely culprit is the fresh food thermostat control, since it controls the compressor cycle. Try setting it to a higher setting, even if it's above normal. Use a manual thermometer to check the temperature of the fresh food compartment and compare it to the control setting. The readings should be the same or very nearly the same.
I assume your refrigerator is controlled by a solid state controller (i.e. a printed circuit board). Some of these allow for calibration of the thermostat to coincide with the actual temperature of the fresh food compartment. That would most likely have to be done by a service technician unless you have expertise in the field.
If calibration is not an option, if you can live with the thermostat setting not reflecting the actual temperature, a free fix is to simply set it higher than you actually want it to be, recognizing that the actual temperature is 'X' degrees lower than the thermostat setting.
The freezer compartment temperature will be similarly affected, and can be controlled by the freezer temp setting, which is actually nothing more than setting the position of the panel which allows or restricts air from being blown into the fresh food compartment from the freezer. Again, the compressor is cycled on and off by the thermostat in the FRESH FOOD compartment which gets its cold air from the freezer compartment.
Aug 29, 2009 | Refrigerators
Fridg is not working right
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 28, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge doesnt stay cold
Aug 28, 2009 | Maytag MZD2766GES Side by Side...
Freezer does not get as cold as the setting made but refrigerator
If the unit is working correctly, it could be that you are trying to adjust the freezer with the wrong knob. The fresh food section is cooled by forced air from the freezer and can get about as cold as the freezer if not adjusted correctly. The thermostat its self controls only the temp in the freezer. Some times telling which is which is confusing. Here is the best way to tell the difference.
The knob that will turn the unit off is the thermostat. The other one controls how much air can be forced into the fresh food section. The thermostat should be adjusted to where the freezer stays around -10 degrees. The other knob should be set so the the fresh food section stays between 35 and 38 degrees. If this does not help or if you find that there is indeed a problem with you unit, please get back with me and I'll be glade to walk you through diagnosing the problem.
Please post a rating if solution is helpful. Thanks
Aug 21, 2009 | GE Profile Arctica Stainless Steel Top...
Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Oct 14, 2008 | Candy CPCA270FFK Bottom Freezer...
Sub zero refrigerator freezes food
Hello. You need a new cabinet thermistor and while you are at it replace the evaporator thermistor. (The evaporator is the cooling coil behind the back wall of your fresh food section) . These sense the temperature in your frig. Both of them are behind the back wall of your fresh food compartment. You will need a wire crimper and a heat gun or lighter to heat shrink the wire connectors that come with the new ones.
Sep 20, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
