Question about Kitchen Ranges
ORDER TRANSFORMER - Kitchen Ranges
My Model N0:D3-15A Transformer needs replacement
  • I have not been able to find a replacement transformer anywhere! I have been looking online and in stores for an entire week. This is the second time, I have blown a transformer. I believe we have to purchase a new unit once again.
Jul 19, 2014 | Brookstone Softtouch Acuvibe Body Massager
Main transformer voltage
Google the complete model number of your "amplituner" and see if a schematic is available from the parts suppliers or if a complete schematic is available from Denon..
Dec 26, 2012 | Denon AVR-1604 Receiver
Our Transformer became very hot a couple of days ago and eventually turned darker brown across the mid-section of the transformer within an hour. We disconnected the unit and want to know if this is...
ours did the same thing with the darker area in the middle of the front of it. My andyman tested the battery and wire and all is fine so ordering a new transformer.
Jun 02, 2011 | Philips Pittway Transformer 120v 60hz 45a...
Firing Order diagram for 2006 Ford Explorer
Hope this helps. The ignition coil:
  • changes low-voltage pulses from the PCM to high-voltage pulses.
  • fires 2 spark plugs simultaneously.
  • has 3 transformers.
    • One transformer fires the spark plugs for cylinders 1 and 5
    • One transformer fires the spark plugs for cylinders 2 and 6
    • One transformer fires the spark plugs for cylinders 3 and 4
Spark plug wires:
  • carry high-voltage pulses from the ignition coil to the spark plugs.
The spark plugs:
  • change high-voltage pulses to spark at the gap, which ignites the fuel and air mixture.
The firing order is 1-4-2-5-3-6.
Jun 06, 2010 | 2006 Ford Explorer
I have a Cavaliere 218 range hood and the lights don't come on. Lamp button illuminates, but no lights come on. Bulbs are good.
We have a Cavalier range hood as well that the two halogen lights stopped working. Bulbs were good and the light switch illuminated. I ended up ordering and replacing the transformer and it works great:
https://www.lightsonrus.com/store/products/Hatch-RS12%252d80M-(RS)-Series-Electronic-Transformer-80Watts.html
Dec 30, 2009 | Kitchen Ranges
"Error applying transforms. Verify that the specified transform
Run kb404307.exe on affected systems. Important: You should be logged in as an Administrator in order to use this tool.
  1. Download the kb404307.exe utility from the Adobe website.
  2. Double-click kb404307.exe to run it.
May 17, 2009 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
Power transformer broke
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Jan 05, 2009 | Tech Solution TS-4500 Shredder
HV Sound no Picture
Sounds as though there is an intermitant, heat-related problem with the HV transformer. You can order this at a tv parts shop or from Sony (probably more expensive) the part number should be on the part or on a schematic. If not, the parts dealer can look it up from the model number.
Good luck! :)
Dec 27, 2007 | Sony KV-36XBR400 36" TV
Kitchen Ranges Logo
64 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
