Question about Miller Electrical Supplies
I have a miller welder / Generator 225G plus that does not have any power output
I checked all fuses and breakers.. The engine runs fine just doesn't have any power output at the ac power outlets
  • 1,249 Answers
These rigs are notorious for developing bad connections in switches and wiring, as well as getting stuck or burnt brushes in the generator. If it has been sitting for some time, I would definitely do maintenance on the brushes and check switches for rusty or burnt contacts. http://www.millerwelds.com/om/o175104b.pdf
Posted on Dec 14, 2014
Miller Trailblazer 302 Gas, will start but, but won't weld or generate. Does not show any readout on the digital meters, will not idle up, only idles at low RPM's. Any idea what may have...
Check the circuit breakers, one may have tripped or failed, such as CB4 which would also impact generator voltage output and since it controls power to the 24 control system- the first one to check or service. If you can access the rear terminals, check the voltage in operation at both lugs- if you do not get the same voltage reading at each lug of CB4 measuring them one at a time to chassis ground, the breaker is tripped or faulty .
CB1 is inline with the 240 VAC outlet and is ahead of CB2 and CB3
CB2 and CB3 are inline with the 120VAC outlets
In each case, switch them off then back on.
If you have the GFCI option, it may have been tripped by unsafe conditions.
Sep 20, 2011 | Miller Trailblazer 302 Welder Generator...
I have a miller trailblazer 301g. It worked fine yesterday and now only the 120/240 volt outlets will work. No weld output and also the idle will not kick down. when I opened the unit the only visable...
Hi:
Probably your machines just overloaded; the engine will run and produce voltage but no weld output.
Check your fuses F1 and F2, if they are open replace them.
Both fuses are located at left hand side of machine, open it and you will find them on the bracket.
Good Luck.
If this was useful please vote, thanks.
Apr 28, 2011 | Miller Trailblazer 302 Welder Generator...
My bobcat 225g runs full bore all the time, I thought it would idle then when you strike an arc it would pick up speed,
A welder does not speed up when an arc is struck. It is normal for a gas welder to stay at a high rpm. If it did not, it would be very hard on the machine as a high amperage is needed to start an arc for welding, and to be consistant. Unlike a generator which will "idle down" when not in use.
Aug 21, 2010 | Garden
I have a Miller 225G plus. it idles up good and
Take off shroud, look at where the positive lead hooks into the transformer. You may find that the wire has melted, If you are lucky, you can loop it tnough to make a fresh connection. (also check the negitive)
Dec 09, 2009 | Miller MATIC 140 MIG WELDING PKG w/cart...
Miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
May 06, 2009 | Miller Welding Tools
Welder will not power auxillary outlets
sounds like either something is shorted out or the governor is stuck. Check the governor linkage to start with and make sure it is free. Then check the push in breakers for the outlets to see if they are popped. If not the brushes or the armature could be stuck or corroded.
Mar 28, 2009 | Hobart Welders 500433 Champion? 10,000...
Electrical Supplies Logo
281 people viewed this question
Top Miller Electrical Supplies Experts
littlewheel
Level 1 Expert
Lawrence Oravetz
jeff5may32
Are you a Miller Electrical Supply Expert? Answer questions, earn points and help others
