Question about Swan Freezers
I have an upright Swan freezer SR5030 which was given to me with no manual. been working well until today when green light was joined by red light. both on. I then also pushed a white button switch beside the temperature dial and now all three orange, green and red lights are on. Today I filled the freezer to capacity and I did remove one draw.
  • 7 Answers
SOURCE: Defrost light stays on
Try advancing the defrost timer manually.
Posted on Jan 17, 2008
SOURCE: flashing power light on Kenmore upright freezer
If the yellow light is flashing it may mean that the 9 volt battery is dead.
On my Kenmore there's a small battery compartment on the bottom right of the unit - under the door.
Posted on Aug 20, 2008
diths_kri
  • 67 Answers
SOURCE: red light on
The red light and the audible alarm both come on when the freezer gets warmer than the alarm point... unless you disable the audible alarm with the rocker switch
Posted on Jan 07, 2009
  • 9 Answers
SOURCE: Philips Freezer
I used to sell freezers.the green light tells you the mains is on and the freezer should work.The red light is to inform you the freezer is not low enough temperature,and the orange light is a fast freeze light to over ride the thermostat for use when introducing fresh food.It should not be used for prolonged periods as it may burn out the compressor although in your case you already have a problem and should seek advice or buy another freezer.If you get a cheap freezer thermometer it should confirm what I am saying.
Posted on Apr 23, 2009
  • 4793 Answers
SOURCE: Red and Orange light staying on on my whirlpool chest freezer
try a total defrost,to clear any internal ice(every 12 months)then switch on and if you have a rapid freeze button leave on for 24 hours to get back to normal operating temp.if you have hard ice around the door seals then you have an air leak which you must sort out(try using a hot cloth to warm seals back into shape.....seals should fit all round, all the time.
Posted on Apr 07, 2010
I HAVE A SWAN SR4150W CHEST FREEZER A ND I HAVE JUST PUT IT ON AFTER A YEAR THE RED ALARM LIGHT IS ON IS THIS JUST UNTIL IT REACHES THE RIGHT TEMPETURE
Most freezers have a red neon light on the door to indicate if there is a loss of power, so that you can mitigate food loss before you call a service co.
Nov 20, 2017 | Swan Freezers
Control panel on the front of the door on my Kenmore upright freezer show an Sb. Can't get it to do anything else!!
This code represents a malfunction. Call frigidaire and find out what that code means. Your manual should tell you as we'll.
Feb 04, 2013 | Frigidaire 14 cu. ft. / 396 liter Upright...
I am looking for the instruction manual to my lost freezer SWAN SR5030
If you lost the freezer, why do you need the manual?
Swan is a UK company that does not have a website for their freezers. The UK help center phone number for Swan is: SWAN helpline: 0845 610 4118
email: sales@swan-brand.co.uk
Also, isn't a freezer a little large and hard to loose?
Feb 01, 2011 | Freezers
Apr 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
ALARM WENT OFF ON OUR KENMORE UPRIGHT FREEZER. HOW DO WE GET IT RESET. WE HAVE PUSHED THE BUTTONS BUT RED LIGHT IS STILL ON AND FREEZER NOT RUNNING. THE PROBLEM STARTED BECAUSE WE DID NOT GET THE DOOR SHUT...
The light and alarm will remain active until the temp in the freezer is "normal" or satisfied. You should be able to push & hold the button (if electronic) until it stops. If it is a manual switch, they are usually located at the bottom of the cabinet below the door.(some are located inside the unit on the wall as well) It may be a "rocker" switch or part of the actual indicator light. Good luck
Sep 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Red light on not green ...has to be green to freeze up again
Try to unplug it for about 5 minutes, and then plug it back in
Apr 17, 2009 | Freezers
Freezers Logo
176 people viewed this question
Top Swan Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Swan Freezer Expert? Answer questions, earn points and help others
