Question about Air Tools & Compressors
I need to find out how to adjust the cut off contact on a husky 60 gallon compressor , any one
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 22 Answers
There is a pressure switch mounted on the tank. Look under cap for instructions
Posted on Jan 03, 2015
protek480
  • 1714 Answers
SOURCE: husky 25 gallon air compressor turns on and off Y6020-WK
Pressure switch setting is off. Readjust to Mfg. spec. (on @ 60/off @ 8o...)
Posted on Sep 03, 2009
  • 4088 Answers
SOURCE: I have a model FP209501 Air Compressor 2 Gallon,
The spray gun consumes more air volume than the compressor can deliver. You can pause painting periodically to allow the compressor to 'catch-up' or buy a larger delivered-volume compressor. The compressor that you have was intended to supply air for pneumatic nailers and staplers in an intermittent fashion. Hope this helps!
Posted on Jan 18, 2010
SOURCE: I have an 60 Gallon Air Compressor Husky Pro, no
Read the owners manual,look at the motor label
20Amp is usually for 2HP and may work for your 3.2
Look at full load rating on motor. You won't need a
breaker that high.
You will need 12 ga wire and 20 amp breaker min.
two wire 240 volt circuit.
It should be wired for the higher voltage,if not look at the
inside of the small motor cover and move the terminals
to the two pole rating. Expensive to run at 115volt
Posted on Nov 25, 2010
  • 885 Answers
SOURCE: looking for manuals for husky air compressor model FP204500AV
The manual and parts breakdown for your compressor can be found at: http://www.chpower.com/IMAGES/pdfs/manual02/608800_1102.pdf
If that doesn't work look for it on the Campbell-Hausfeld homepage at http://www.chpower.com/ under Service and Support. They have been working on the site so some links are not working correctly.
Your compressor is an oil-less type that has very little for you to do as far as service. Mostly you just have to keep it clean and occasionally drain the water from the tank. The frequency of that is dependent on where you are (humidity levels in your area) and how ofter you use it.
Posted on May 23, 2012
  • 33 Answers
SOURCE: motor cuts off before reaching 125 psi
Im guessing this is a recip (piston Compressor) Sounds like your pressure switch may have adjusted itself by vibration. Take the cover off the pressure switch, there should be 1 or 2 screws on the top, one adjusts the pressure, the other adjusts the differential pressure (There may just be one) turn the pressure screw in the direction of the +, you need to do trial and error on this, turn it 1/4 of a turn, then switch on, see what the pressure gets to, then switch off, drain some air off, then adjust as necessary until you get your required pressure. Hope that helps
Posted on Sep 03, 2012
I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
Free Husky Air Compressor User Manuals ' ManualsOnline ...
powertool.manualsonline.com > ... > Husky > Power Tools Husky
Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
Sep 04, 2015 | Air Tools & Compressors
How to adjust cut in pressure on husky 60 gallon
what is the pressure switch model number, most of them have a nut with a spring under them, just turn the nut to adjust the pressure
Oct 21, 2012 | Husky Electric Air Compressor: 60-Gallon...
Motor cuts off before reaching 125 psi
Aug 31, 2012 | Husky Air Tools & Compressors
Husky 60 gallon compressor switch from 220 to 110
Try here, very good for asking problems http://www.about-air-compressors.com/husky-air-compressors.html
Jul 28, 2012 | Air Tools & Compressors
Shut off before it reaches 150 psi turned up the regulator up but it stops about 60 psi should go to 150 psi
the air regulator only regulates the flow of the air as to how much. their is a pressure switch that turns on and off the power to the compressor when it reaches it's set pressure.
follow the plug wire to a small box this should have the switch arm you flip to start it.
remove the cover with the unit un-plug.
there will be a spring with a nut on top tightening this nut or loosening it will adjust when the pump will cut off.
the best way is to test by adjusting one way and watching the pressure till it hits the desired rating you want.
if it keeps pumping un-plug the unit then back off the nut or tighten till you hear a click then plug the unit back in it should not run then.
drain the air and re try the unit it should cut off at the pressure then if so your fixed look for burnt contacts if their black and have little craters on the contacts then that hole switch should be replaced and you can buy them at the presetting you need.
hope this helps
Sep 03, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
HUSKY 26 Gallon Shuts Down After <75PSI!?
Possibly the pressure switch needs to be adjusted to reach a higher pressure. Trace the power cord into a box that also is piped into the pressure line from the compressor. If the pressure works itself back down again, use thread-locker fluid on the adjustment screw to hold it's setting.
Sep 08, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky 25 gallon air compressor turns on and off Y6020-WK
Sep 03, 2009 | Air Tools & Compressors
Husky 17gal 5hp compressor will not cut off when it builds up pressure. Pressure valve will pop open and then I cut it off buy hand
bad pressure switch or it is wired incorrectly replace switch and check the wiring or could be out of adjustment you compressor is made for max 125psi should be a screw to adjust on the pressure switch near where the wires are connected back out counter clockwise to lower and see if that turns it off
Feb 20, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
75 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
