Question about Refrigerators
Carrier fridge is blowing out warm air, could it
Carrier fridge is blowing out warm air, could it be the frion needing to be changed? If so what kind and where would I purchase it, and can I do it myself? Thanks!
2008 land rover sc warm up car turn on heat blower working warm air at first then clod no heat
When is the last time you change the thermostat and coolant?
Recommended interval is 2 years.
Coolant is the heat carrier to heater core.
Top off the coolant level for now and re-test.
Dec 31, 2013 | Land Rover Range Rover Sport Cars & Trucks
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
My ac blows warm air
You need to hook up a set of AC pressure gauges to the low side charging port and read the system pressures with the AC compressor turned on and running, it should be around 28-32 PSI. If the compressor press is correct you have some other problem like a broken air temperature control blend door inside the dash air ducting.
Jun 24, 2012 | Cars & Trucks
My Carrier Home AC unit stopped blowing cold air today. I opened it up and cleaned everything and didn't notice anything out of place, any ideas?
This could be complicated to resolve over the internet but I'll give it a try. When you stated that it stoped blowing cold air, did it stop blowing air all together? Also is the outside unit rtunning?
Sep 05, 2009 | Carrier 38CKC042 Air Conditioner
Yesterday I just had someone change the battery and now the AC does not work. It only blowes scorching hot air and no cool air.
you need to check the frion try to bring it to the aircondition repair so that they check the frion of your AC
Jul 19, 2009 | 2005 Chevrolet Malibu
My Carrier AC fan will not turn, only blows out warm air.
Breaker has popped either at breaker box or at the safety shut off switch. Fuses are blown or the sending unit has popped.
Apr 30, 2009 | Carrier BCA101R Air Conditioner
Hot air coming out of vent when air is on.
put some frion in and change out the antifreeze
Apr 19, 2009 | 2001 Ford F150 Styleside SuperCrew
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
Fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Feb 17, 2009 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
