Question about Nordic Track NordicTrack - Elite 12.7
How do I disassemble a Nordic Track Elite 12.7 Elliptical Trainer so that I can move it to the basement in smaller, more manageable pieces? It is over 300 pounds and came almost completely assembled.
I have tried to contact Nordic Track customer support, but have not yet heard back.
maxtreadmill
  • 832 Answers
SOURCE: knocking noise
Unplug unit open motor shroud , then replug unit , start the unit up then place tip on to the a 6" length flat screw driver tip on the front roller shaft put your ear on the insulated end and you should be able locate the knocking noise also check the motor and rear roller you insert tip where th adjustment is made. I believe that the front foller is causing your problem. Go to iconfitness.com go to customer service then replacement parts you will find your M# and pricing
Posted on Mar 03, 2010
maxtreadmill
  • 832 Answers
SOURCE: manual for a Nordic Track Personal Performance
Go to iconservice.com click on to manual Input manufacturer : Nordic Track then model # NTL349050 and you manual await you.
Posted on May 15, 2010
  • 34 Answers
SOURCE: Need to disassemble NordicTrack X7i trainer to
To get the manual go to iconservice.com and select the manuals link. You will be asked the model name or number. You can download a PDF file of the manual for free. Use the assembly instructions only backwards and you will be able to disassemble the machine.
Posted on Aug 10, 2010
  • 34 Answers
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Posted on Aug 18, 2010
SOURCE: Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
Posted on Feb 13, 2011
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Jan 05, 2016 | Exercise & Fitness
Nordictrack 1300 elite elliptical manual
go and download the instruction manual and follow the instr.
normally the batteries goes under the display board.
However follow the instr manual
www.fitness.manualsonline.com
God bless you
Dec 15, 2012 | Nordic Track Nordictrack Elite 1300...
In what way is an elliptical trainer different from a treadmill?
Treadmills have a moving belt while elliptical trainers have two foot pedals guiding movement - making it more controlled and safer. Elliptical trainers also have handles, in which the user has the option to move their arms in opposition to their legs to better control movement.
Aug 02, 2012 | Exercise & Fitness
Nordic Track X5 belt won't move
1) Lube the deck belt, this happen because the electronic system protect the system and shut down.the cause is deck worn.
2) Lube the rollers bearing too.
3) Measure the input voltage motor, if there are the motor need repair.
4) Measure the output voltage board, for input voltage motor, if there are Not the board is faulty.
God bless you
Jun 12, 2012 | Nordic Track Exercise & Fitness
I need an owner/repair manual for a nordic track elliptical trainer
You can log onto www.iconservice.com for a pdf version of your manual for free.
Hope this helps
Jan 02, 2011 | Sport & Outdoor - Others
Need to disassemble NordicTrack X7i trainer to move it. Don't have the manual
Aug 10, 2010 | Nordic Track Nordictrack Apex 6500 Reflex...
Nordic Track elliptical E7: The tension belt came off. It's not apparent how it goes back. Are there diagrams that show the way the belt is attached to the tension cable?
If you are looking at right hand side of unit you have the flywheel next to it adjusting tension plate.If you have your manual handy it will show how to loosen this part so you may loop over the small idler pulley which goes around the much larger pulley wheel if not here is the web page to go to and its on page 21 Hope this nugget will help!
http://www.iconservice.com/CustomerService/manualsProductManuals.do?model=NTEL07808&version=0&company=11&modelName=NORDICTRACK+E7+SV+FRONT+DRIVE+ELLIPTICAL&language=
Apr 06, 2010 | Endurance E7 Elliptical Trainer
My nordic track exp 1000 x slips when the speed is approx. 6. We have tightend the belt and lubricated it. The motor also sounds like it is struggling.
This is usually caused by either a slipping drive belt or a broken front roller/drive pulley. Lower cover must be removed to tighten the drive belt. There are 4 screws located on the bottom of the unit that will release the cover.
Nov 11, 2009 | Ironman Fitness Achiever Elliptical...
Have a nordic track exp 1000x treadmill and the belt is slipping
my nordictrack exp1000x doesn't elevate anymore, what can be the problem and how can i fix it?
Nov 01, 2009 | Ironman Fitness Achiever Elliptical...
Nordic Track NordicTrack - Elite 12.7 Logo
146 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
