Question about Harman Kardon AVR 320 Receiver
My infrared senor on my AVR 320 works sometimes and then it wont .Its not the remotes they both have new batteries. .
My remote for tv wont work ,bought new one still wont work ,
It sounds that the infra-red sensor inside the TV is faulty. Contact any service technician. Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV
Jan 02, 2015 | Televison & Video
Telefunken 42 27 27 tv tpm 320
Try looking at the remote LED through a cell-phone/digital camera's view finder. If you see it blinking when you press some button on the remote, it means that remote is fine and there is some problem with the Infrared receiver of you television.
Good Luck!
Sep 04, 2014 | Televison & Video
New tledd-40fhd telefunken remote wont work
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts in the battery compartment, to make it a good contact with battery terminals. Look for any dust or rust accumulated. Clean it well with an emery paper. If you wish to get more details about how to check a remote control, check the site linked here. Pull up older posts.
Dec 03, 2013 | Televison & Video
Tv remote not working
Hello
Check the remote control for its infrared emission first. You can check it with the help of a cellphone with camera. Eventhough human eye cannot detect infrared rays, electronic cameras can. Put your cellphone to camera mode, place the remote control [ replace its batteries with new ones]; at about one feet away from the camera lens, and press each button on the remote control. If infrared emission is there, you can see its image on the cellphome camera screen. If there is infrared emission for all button press of remote control; the infrared sensor inside your TV is faulty. It should be replaced with same type and number. If there is no infrared images, the remote control is not working, and should be replaced. Check the battery contacts of the remote battery compartment for any rust or dirt. Clean it well before replacing new batteries into it. OK.
Jul 06, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
My Bose V30 system with the RCV1T-27 remote wont send the IR signal to my Motorola DCT 6416 if im not standing right in front of the Bose display unit. The light on the display still blinks as if its...
Hello
Check the cells in the battery compartment of your remote control handset. Replace it with new ones and check. Still you poise this problem, the intensity of infrared rays come from your remote control, or the sensitivity of the infrared sensor inside your bose front panel system may have the trouble. Just replace the infrared LED of your remote control with an other one of same type. If it does not helps you, repalcing the infrared sensor will reftify your problem. OK.
May 05, 2011 | Bose Lifestyle V30 Home Theater System -...
T.v. does not respond to remote control, but does work maually from side buttons
Turn tv on manually.Test the remote control all functions are dead or some functions work other don't?Tries take the remote control parts and clean the inner rubbers buttons between the rubbers insulater and the remote circuitries board and the battery connections + - connections with some rubbing alchahol.Then wait awhile like 20 mins and putting it back together again and putting in new battery in the remote,it might work again.If getting the same result than the remote CPU chip is probally dead,remote control devices are very depended on it CPU chip.Try website like Remotes.com to buy an original remote for the replacement.
Mar 24, 2011 | Vizio 42 in. LCD TV
Remotes not picking up anything
I would suggest replacing the senor bar, it is not that uncommon that one the the Infrared LED's in the sensor bar to have burned out or go bad.
I personally use the wireless sensor bar after my original senor bar went bad
May 05, 2009 | Nintendo Wii Console
Can't get remote to work
Since you don't know which end is defective, you might take the remote to about any store that sells and services consumer gear; they will have a primitive sensor that can detect if the remote is putting out some infrared but the common type of detector cannot tell you if the coding is correct or not.
If you find though that the remote is putting out anything at all, it is probably working properly.
Unfortunately that will mean that the receiving end is bad and that will be more costly to have repaired.
A handy device can be had for $10 US here:
http://www.ersweb.com/Infratector.htm
Oct 02, 2008 | Koss KS4102 System
Harmony 890 channels and volume wont work
Sometimes you need to go into the menu page for the device that doesn't work and you need to "learn" the keys to the new remote. "Learn" meaning pressing the buttons on your original remote with the Infrared part of the remote facing the Infrared part of the new remote. This will help the Harmony remote duplicate the signal to the device you want to operate.
Apr 09, 2008 | Logitech Harmony 880 LCD Remote Control
Harman Kardon AVR 320 Receiver Logo
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
