Question about Crafts & Hobbies
Why is my cricut create blade forcing itself agains the side of the machine
4 Suggested Answers
CricutAddict
  • 13 Answers
SOURCE: Cricut Expressions Machine error
  1. Make sure your cricut is off when you plug it into your computer via usb.
  2. Make sure your usb cable is plugged directly into the machine, and not to a usb hub.
  3. Start up the DS Once the DS is fully loaded, choose HELP > UPDATE FIRMWARE.
  4. On the cricut machine, hold down the STOP button. Keep holding it down and briefly hold down the power button. Keep holding down the stop button and in about 3-5 seconds, you will hear a beep. That means you are good to go.
  5. On the "update firmware" screen on your computer, select the model you have and then click "begin updating now"
  6. Go and read a magazine or make a cup of tea because it takes a while to update. If it goes really fast (no matter how cool your computer is) it means it did not install properly and you will probably have to do it over again.
Hope this helps you.
Posted on Mar 25, 2010
SOURCE: how do I change a cricut machine blade
Take out blade housing by unscrewing black plastic nut. Push down on the top of the blade and pull it out. It is held in by a magnet. Push in new blade and screw back in. Also look on Youtube to see instruction videos for cricut basics.
Posted on Dec 02, 2010
SOURCE: WHen the cricut is cutting it tears my paper even
After having the Cricut for many years, I finally figured out how to cut the intricate cuts. Use multi cut 2, speed on med (3) and pressure on 4. I also keep my blade at 4. It takes a lot longer to cut but it cuts out good!
Posted on Oct 17, 2011
How do Imuse markers with my cricut machine?
It depends on the machine the expression 2 the expression and the little machines use markers that fit into the blade housing slot. The explore machines use special markers put out by cricut or there are some called slick writers that fit in the accessory clamp.
Nov 20, 2017 | Crafts & Hobbies
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • Jan 16, 2017 | Crafts & Hobbies
    The blade on my cricut expression won't stay down and cut the entire image, only part of it. how do i fix this?
    you have something under the mat or the mat is bent. If you are using Expression which I assume you are if it is cutting on the right then make sure you haven't got your mat kinked. It should line up with the side on the left and the little bar on the base of the machine on the right. Try putting it in portrait made and doing some cuts to see if the same things happen.
    Flo
    Apr 21, 2013 | Provo Craft Provocraft Cricut Expression...
    Black plastic blade arm broke on cricut, where do i get replacement part
    Sheila,
    After much useless searching and an hour on hold with Cricut support, I finally got an answer. It would seem that the cradle arm is not a replaceable piece. Cricut can not supply anything to fix the problem. However, I have found that if you can get the cradle arm back into position you can lock it into place with the thumb screw. It will still hold the blade housing and marker/pen housings, you just have to be careful when removing them to make sure you don't damage your project. Hope this helps.
    Jul 25, 2012 | Cricut Expression Cutting Machine
    The cricut blade holder doesn´t go up or down.
    My housing was not going up or down. Every time i wanted to make a cut it dragged and cut shapes in half. So when I took it apart I pushed it up and down myself and noticed that it was very difficult. So where you see the coils, I lightly sprayed WD40 (my cricut is out of warranty, I would not advise to take apart if you are still under a warranty). I lightly sprayed until it was easy to move up and down. When your done be sure to wipe any access WD40 that dripped to the bottom. This fixed mine and thank goodness because I was close to pulling out my hair! Hope this helps someone else!
    Jul 26, 2010 | Cricut Expression Cutting Machine
    Brand new cricut doesn't turn on, just clicks with lights blinkin
    Yes, I was just going to recommend contacting them. I see you have contacted them already. Good luck with getting it fixed~they are prompt in helping with machines. If you have any further questions about the cricut feel free to ask.
    Aug 20, 2009 | Provo Craft Cricut Disney Font Cartridge
    Cricut not cutting anymore
    I was reading lots of forums and tech support pages on how to get my Cricut back online. I went to the store and got the Deep Cutting Blade & Housing and I got two replacement blades for the original housing that came with the Cricut. I also bought a pack of new mats. I replaced the original blade with a new one, used a new mat, and tweaked the depth and speed of my cuts and my little Cricut is whirling again!
    Jun 25, 2009 | Provo Craft Cricut Disney Font Cartridge
    Cricut wont cut
    My wife's Cricut recently developed the same problem. I work on computers and mechanical stuff, and figured it couldn't hurt to open the machine for a look. What was happening was that the solenoid (like an electromagnet) that pulls the blade down into the paper has stopped working. I don't know if the solenoid itself has gone bad, or if one of the two wires leading to it has fatigued and broken. Whatever the case, my wife called ProvoCraft, and the rep told her it wasn't repairable and she'd have to buy a new one. Personally, I'd like to try and fix it first...
    Jun 15, 2009 | Computers & Internet
    Cricut personal blade appears to be dragging
    Have you checked to make sure the blade is inserted all the way??
    May 22, 2009 | Provo Craft Cricut Disney Font Cartridge
    Crafts & Hobbies Logo
    378 people viewed this question
    Top Crafts & Hobbies Experts
    R.A. Ellis
    R.A. Ellis
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Are you a Craft and Hobby Expert? Answer questions, earn points and help others
