Question about NAD Audio Players & Recorders
My 747 goes to Protection what do I do
Power up power down
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
My crown vid 4000 amplifier doesn't work.after switching power it goes off after maybe 2 sec.no speaker and input during powering. Same thing happen even there is speaker and input connected
Check speaker to power bank protection circuit. The circuit is faulty indicating to the power amp that speakers are disconnected that shuts down the amp to protect the unit
Mar 10, 2015 | Crown Audio Players & Recorders
3 wires red black and green what goes were
Red is +
Black is possible -
I would try it make sure its DC power. You can test it on the panel find a 12vdc terminal and a ground terminal and just touch it and see if it works.
Mar 13, 2014 | Honeywell 747 Alarm Siren
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Sep 26, 2011 | Denon AVR-1907 Receiver
I have dell optiplex GX280 when i press the power button i dont get any display and cpu fan reach to its max speed how can i fix this prob?
May be serious. See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans sound like 747 taking off. Power light goes amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad.
I obviously can not be 100% sure about this as the unit is not here.
You can google this and see the issues. Here is one such link.
http://en.community.dell.com/support-forums/desktop/f/3514/p/19253544/19414291.aspx
Feb 11, 2011 | Dell OptiPlex GX280 PC Desktop
The computer dose not turn on.when i push the power button the cpu fan speed up and the speed of fan is going on.there is no video on the monitor.
This is a response I gave to someone else with a similar issue.
May be serious. See if the power light goes amber after power up. I had (have - still siting in my basement - gx280 minitower) one that did same. Power up, fans sound like 747 taking off. Power light goes amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad.
Dec 24, 2010 | Dell OptiPlex GX280 PC Desktop
Behringer mixer power goes off after running about 5 0r 10 minutes then power turns on.what is problem with the power supply board
That time lag would indicate a thermal problem.
Likely the power supply is a switching type that has some three terminal regulators after it such as 7805, 7815, 7915.
These have thermal protection in them and one may be shutting down.
Use circuit cooler to isolate the part that is shutting down.
May 20, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
No Picture, The power and the OPC Led's are blinking
Your TV is in fault protection. Due to blows caps on the PSB-power supply board.
Best Regards and Semper Fi
Mar 27, 2009 | LCDDigital LCD7 Television
Car audio amp in protection mode
If you power up the amp with the RCAs plugged in, does it go into protection mode.
If you power up the amp with the RCAs plugged in, does the woofer pop?
Oct 26, 2008 | Pyle PLAD413 Car Audio Amplifier
59 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
