1999 Chevrolet S-10 Logo
r
russ fusselman Posted on Dec 14, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 99 chevy s10 zr2 that will crank but wont start
My serpentine belt broke last week on my 99 s10 zr2 i had it towed home and replaced the idler pully and the tensioner pully unit , and the belt ,i tried to start it and it cranks but wont start ,i just replaced the fuel pump and the battery 2 weeks ago and i can hear the fuel pump kicking in,i'm getting proper fuel pressure ,i'm clueless over here
Vitally Alcher
Level 3:
  • Chevrolet Master 1,645 Answers
  • Posted on Dec 14, 2014
Vitally Alcher
Chevrolet Master
Level 3:
Answers
1645
Questions
Helped
467345
Points
3209
Check if you are getting spark .
My main belt broke while driving home, had car towed home we replaced the belts and car will not turn over its as if low battery but used another working battery so what else could it be
/mm.
What type of vehicle? Which type of belts?('V-belts or the wider (~1inch) multi-grooved Serpentine belt)
Your broken belt may have hit something when it broke. Does it click-click-click, or no responce to 'start' possition at key?
Might have knocked large battery cable, or small starter wire loose (or cut it 'open'), or some ground-wire, or ignition wire, or module/harness connector loose.
/mm
by Paula Rubidoux on Apr 26, 2016
Add a Comment · Flag
Your Answer
I have a 1999 Chevy Tracker I have had to replace my belt on my car 3 times within a week why does it keep breaking I had my alternator checked and it's good
How To Install Replace Serpentine Belt Chevy Malibu 97-03 ...
? 9:28
www.youtube.com/watch?v=KyEm7LtoI8k
Sep 23, 2011 - Uploaded by 1A Auto Parts This video is applicable to 97, 98, 99, 00, 01, 02, and 03 Chevy ...my Malibu belt broke and quoted by a friend that works at a shop said it would ...
3answers
2answers
Does it have spark at the spark plug's ?
My 2001 zr2 s10 cracks hit an kicks back an wont start
Timing Issue
Belt,Chain,Ignition
Compression problem preventing
it from turning over
Does it turn over by hand
See if you still have the correct cam timing
with #1 cylinder at top dead center
1helpful
I have changed all the pulleys except for my A/C pulley on my 2002 chevy tracker 2.0 liter engine. The serpentine belt has been changed at least 8 times over the last 5 years. i changed to pulleys in...
REPLACE THE TENSIONER IDLER PULLEY.THE TENSIONER IDLER PULLEY MAINTAINS THE BELT TENSION WHEN IT GOES BAD.THAT WILL LEAD TO LOOSE BELT TENSION CAUSING BELT TO BREAK.
1helpful
2answers
1998 jeep cherokee turns over/ no start. broken serpentine
if you are getting fire to the plgs its not the cranksaft sensor...if you arent getting fire you need to replace it they are simple to replace on the jeeps. took my son 5 minutes to change one out
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
