Question about Dryers
Replace lint filter, guide filter and filtercover on gas dryer dlgx3361
  • 78 Answers
Either vent pipe is blocked or sensor is bad
Posted on Dec 18, 2014
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
Gasket for dryer lit catcher is coming off
The gasket on the lint filter is not very important, but you can get a replacement lint filter. There is a screw at the center bottom area of the lint filter area which can catch on the gasket. If you replace it with a shorter screw or remove it, grind it down a bit, and replace it you will help avoid a repeat condition.
Jan 02, 2011 | LG D2526 Gas Dryer
How to replace the belt
Try this link Dryer belt replacement video or if your lint filter is in the door try this link Dryer belt replacement video
Nov 01, 2010 | Kenmore 73952 Gas Dryer
Keep replacing thermal fuse
This is going to sound like an owners manual but here goes:
1. Keeping the lint filters clean after each load is every important.
a. if you use dryer sheets (bounce etc) you should clean you lint filter with vinegar about every 90 days. The material from the dryer sheets collects on the lint filter. It will appear clean but will restrict airflow.
2. All air passages must be kept clear:
a. Around the lint filter (look deep and hard) clean with crevice tool
b. At the rear connection of the dryer check the vent ducting for obstructions. It can appear clean yet have a caked build up inside the ducting that restricts airflow.
c. The through the wall vent ducting flapper.
Other than the lint filter the is the leading cause of ducting restrictions. Lint can build up on BOTH sides of the flapper so it keeps it from fully opening or closing and restricts airflow.
Thermistors are there to prevent your dryer from burning down your home. The thermistor is doing its job.
Sorry for sounding like an owners manual / user guide but everything above I see over and over and over..... and over. People say the ducting lint filter and thru the wall vent are clear... Yet I go out there and they pay me to prove them wrong.
Thanks for using FixYa.
Kelly
Mar 20, 2010 | Kenmore 63942 Dryer
My problem is i installed a new igniter but now i get no gas to the burner
You have a bad thermal fuse . This is a narrow 1 " white piece , with 2 blue wires going to it . If your lint filter is on top of the dryer , then the fuse is behind the dryer , mounted on the blower housing . If you lint filter is at the bottom of the door , then this thermal fuse , is located behind the lint filter housing .
Jan 27, 2010 | Kenmore 63942 Dryer
Where can I get a lint catcher for an Amana Gas Dryer Model No: LGA30AW.
Hi
You can buy a Lint Catcher/filter for your Gas Dryer from this link---
Amana Gas Dryer LGA30AW Lint Filter
Please do rate this solution as FixYa if found helpful and revert for further assistance.
Thanks
Rylee
Apr 28, 2009 | Amana Dryers
I took lint filter out to clean it and forgot to put it back in, I started gas dryer and it stopped, I believe there is a sock stuck in there somewhere. Does the front come off and what do I need to take...
Hello Kims987K,
You may want to check circuit breakers in your Breaker Panel to see if the one for your Dryer is tripped, and reset it if it is. Even though you have a Gas Dryer the Drum still operates on electricity, so without it the Dryer wouldn't function at all.
I don't think that the sock is stopping your Dryer, as the lint filter just filters lint from your Dryer's exhaust. So, even with the lint filter out a sock couldn't fit through the small holes in the drum that ventilate it (that's how the lint gets to the filter). I guess there could be a switch that detects whether the filter is in the machine and cut it off though, so you may try to re seat the lint filter (replace the lint screen/filter making sure it's in all the way), and try to start it again. If you look inside the Drum and see any way that a sock or anything else could get out other than through the door opening? That would be a problem.
If the filter was missing for several loads of laundry? Then you could have a restriction in the exhaust causing a thermal overload circuit to cut it off too (prevents the Dryer from catching fire). Does the light come on in the Dryer when you open the door?
From the information you posted, all I got is that it's a Gas Dryer that won't run and you appear to be missing a sock, so more detailed information will probably help in finding your solution.
I'll check back, and Good Luck finding that sock.
Mar 05, 2008 | Dryers
Front loading dryer
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Nov 21, 2007 | LG DLG2524 Gas Dryer
Dryers Logo
54 people viewed this question
Top Dryers Experts
