Question about Video Game Consoles & Games
What are the settings on the controller? Is one wave hottest?
Can't control climate control and it's stuck on defrost at hottest setting. 2006 Hyundai tuscon
possible heater control unit failure as this system has a hot/cold blend door actuator and a separate defrost floor blend door actuator so default setting is defrost for that actuator but not hot setting so controller fault is most likely
Mar 26, 2017 | 2006 Hyundai Tucson
2008 chevy equinox heater control on hottest setting blowing cool air why ?
Have heater core checked. Sounds like it is not working.
Dec 06, 2016 | Cars & Trucks
There are no active mixer drivers available information msg comes when i clicked volume cntroller
Go to Start - Programs - Accessories - Multimedia or Entertainment and then select Volume Control. Note: If you have more than one playback device installed in your computer, make sure that the proper device has been selected before modifying the mixer control settings. To do so, select Properties from the Options menu, and make sure that the proper device has been selected.
Make sure that the Mute All check box below the Volume Control slider and the Mute check box below the Wave slider are not checked, and that the Balance sliders for Volume Control and Wave are in the center of the scale.
Move the Volume Control and Wave sliders at least halfway to the top of the scale. If the Play Control and Wave sliders do not appear, select Properties from the Options menu, and then make sure the Play Control and Wave check boxes are checked. You may need to adjust the current Play Control or Wave slider settings to play wave files at the volume level you want.
If you hear popping or crackling noise from USB speakers, turn off the SpeedStep (if you have a Intel Mobile Pentium III processor) functionality during the sound session. To do so, set the power scheme to an non-adaptive mode: Click Start, click Control Panel, and then click Performance and Maintenance, and click Power Options. On the Power Schemes tab, click Always On in the Power schemes box, and then click OK.
Jan 01, 2011 | Creative Labs SBS 250 Computer Speakers
Dance Dance Revolution Hottest Party for Nintendo Wii: where to plug in pad on wii...
You plug in the DDR Controller in the GameCube controller slots on the Wii system.
The GameCube controller slots should be on top of the Wii. It should be inside a small door you can open if you haven't used it.
May 17, 2010 | Konami Dance Dance Revolution Hottest...
I can't seem to adjust the time using the remote
You can obtain the Bose Wave radio instruction manual in electronic form, here: http://products.bose.com/pdf/customer_service/owners/og_wrcd.pdf
See page 15 for setting the time. You should be able to do it with the unit controls.
Apr 13, 2010 | Bose Wave Radio
2001 silverado, 5.3L. heater control stays hot,
I have the same problem, I think the door inside the heater box gets stuck when you turn it to hottest setting. Try going 1/2 or 3/4 to hot and see if it recovers without turning off the truck.
Feb 20, 2010 | 2001 GMC Sierra C/K3500
Plugin issue
plug it into the top of the wii system. its the gamecube controller port.
Aug 15, 2009 | Konami Dance Dance Revolution Hottest...
I have a bose wave model awrc-1g cant set time from military time to regular
Hold the alarm setup button and at the same time hit the on/off button.
Oct 16, 2008 | Bose Wave Radio
Wave on master volume keeps decreasing on its own
I have nver come accross a setting that will lock the volume to a set level before, but here are a couple of possibilities that you may want to investigate for the cause.
  1. Not all programs use the master volume control, so do, but most adjust the sound by the wav output. Put the mixer onto the desktop, open things like winamp, media player etc and adjust the volume controls on those to see what is doing what.
  2. If you have a multimedia keyboard with a volume control on it, make sure when your typing it's not adjusting the volume at the same time. Again, put the mixer on the desktop out of the way and type as you would normally. It could even be just the vibrations from typing setting it off.
See how you go and post back your results
May 09, 2008 | Microsoft Windows XP Home Edition
Video Game Consoles & Games Logo
87 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
