26 inch LCD element television Powers up but won't do anything else
    Top Expert:
  • Televison & ... Master
  • 74,106 Answers
Do a hard reset to this set and check. If it do not help you, the main board to your TV is faulty. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 15, 2014
  • 10 Answers
SOURCE: Gateway 26" LCD Power Supply
There is a silver lining....
Unless you physically see burned components on the power supply main board, it
is not fried. If you examine the board on the back side ( solder joint side) you will notice that there is a devider that is clearly marked between the Primary and secondary sides of the board. There will also be a large transformer accross this area.
All switch mode power supplies have optical couplers which cosist of a light emmiting diode usually infared and a photo transistor. These are for protecting the secondary side of the board or the expensive side. A typical switchmode power supply for an LCD tv will have at least three of these. They are roughly 1/4 inch long and 2/8 inch wide
and are black with four leads. They will be directly accross the marked portion of the board that seperates the primary or high voltage side of the board from the secondary.
These opticle couplers or switches cost an average of $ 7.00 a piece and are available
from any electronics supplier such as NTE.
I hope this helps. Remember it can all be repaired. Its a matter of if its economically
worth your time.
Posted on Feb 03, 2008
  • 298 Answers
SOURCE: Attaching 26 " lcd to stud wall
12 inches is the minimum for mounting the unit to the wall. I mounted a 42 inch LCD using a Sanus tilt (non-swivel) mount from Best Buy. We mounted it on wooden beams exactly 12 inches apart. Works great!
Posted on Mar 05, 2008
  • 1779 Answers
SOURCE: where can I get a power cord for niko 26 inch?
95% of all LCD's use the standard PC or Monitor cord. Best Buy ect...
Posted on Feb 06, 2009
  • 100 Answers
SOURCE: Element 26 model ELCHS 261. The tv powers up ok but
has problem on the board.the solder is loose or loose solder
Posted on Jul 18, 2009
budmrtn
  • 11361 Answers
SOURCE: ViewSonic N2635w 26 in. LCD Television is not working
It can be bad main controller board. Check power supply first.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=ViewSonic+N2635w+
Posted on Dec 16, 2009
How to reset mintek dtv-265-d telivision after replacing power supply
MINTEK DTV-373-D OWNER'S MANUAL Pdf Download.
www.manualslib.com > ... > TV DVD Combo > DTV-373-D
View and Download Mintek DTV-373-D owner's manual online. Mintek DTV-373-D OWNER'S MANUAL 37''. DTV-373-D TV DVD Combo pdf manual download.
Mintek DTV-265-D 26 in. LCD TV Factory reset - Questions ...
www.fixya.com > ... > Mintek > Mintek DTV-265-D 26 in. LCD TV
...factory reset to this TV. It will make all to factory settings. There are two types ofreset to TVs. The first is simple to do; a Hard Reset. The other is somewhat ...
Mintek reset button location Combination Televisions ... - Fixya
Dec 07, 2015 | Mintek DTV-263 26 in. LCD Television
I have a 26mf231 Magnavox 26 inch tv. The screen on the tv just flashes over and over. Never powers up. I took out the power board and all the capacitors look good. Thanks in advance
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 30, 2013 | Philips 26MF231D 26 in. LCD Television
Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Feb 10, 2010 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
Syntax Olevia LT26HVE, powers on, blue screen w/ sound
I have an Olevia LT26HV power is on stay blue, sound ok, but no display.
Dec 30, 2009 | Syntax LT26HVE 26 in. HD-Ready LCD...
Jul 18, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Where can I get a power cord for niko 26 inch?
Feb 06, 2009 | Niko OTP-2613W 26 in. LCD Television
26" Philips HD ready tv (LCD)
Nothing much you can do. The soft plastic will get worse if you try anything.
The screen could be replaced, but would cost more than the TV.
Jan 29, 2008 | Philips 26PF5521D 26 in. HD-Ready LCD...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
