Question about Vision Fitness T9250 Simple Folding Treadmill
My Vision Fitness T9250 treadmill. Can hear a low noise when no one is on it but gets much louder when anyone is on it and operating...any ideas where to start looking for repairs?
Stopped using it...no attempts to repair yet. Difficult to describe but kinda sounds like its rubbing or labored sound from motor. Has been operating fine until lately, bought used over 5 years ago, used in winter only. Don't know where to call for service. Husband will attempt to repair if we get ideas. Thanks
Try to open and separate the motor carefully from treadmill chasis, turn the motor shaft with hand if it not easily turn or you hear a unsual sound try to open the motor and add a lubricant to motor bearing, and turn the motor on if its still noise replace all the bearings with new one
Posted on Dec 14, 2014
The belt catches when running. it is fine when walking. Vision Fitness T9250
There is a special lubricant spray for treadmills that you spray. injection pump. The air injection pump is designed with a check valve inside which only allows air to flow in one direction, preventing exhaust gases from escaping through the air pump and only allowing air to enter. When this check valve fails, moisture is able to get inside the air pump. Make sure you don't have dirt and dust build-up before spraying.
Sep 11, 2017 | Vision Fitness Exercise & Fitness
My belt has stopped working, but all other functions are fine. I've removed the motor cover, but now what should I look for?
Try to check the carbon brush of the motor. If it's OK then the motor control board would be faculty
If you wish to get some more details about treadmill repair then check the following link
http://electro-medical.blogspot.com/
Aug 20, 2016 | Vision Fitness T9250 Treadmill
E4 coming up on my screen display , what is this and how do I fix it so it will work again ....
What device are you talking about your stereo ATV a computer or a cell phone?
Most manufacturers have a support site on the Internet and given the error code and the model number they'll give you a solution
Nov 25, 2014 | Vision Fitness T9250 Deluxe Folding...
Getting E2 error on my vision fitness t9250 treadmill
68a1477a-4453-48c8-9f94-cd15c6c6fea7.giffollow this steps and fix it. God bless you
This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board or lower board. The error codes will differ between makes and models but could be e1.
See the diagram attached.
Oct 13, 2013 | Exercise & Fitness
My Vision 9259 stopped midworkout.
please LUBE the deck belt see the video, lube the rollers bearing front and rear, test the drive belt for worn and replace. God bless you
Jun 08, 2013 | Dmm Vision Fitness T9500 Treadmill
Noisy Landice Treadmill
It could be the bearings or it could be the brushes are worn out and need to be replaced. normally it would be the front roller that needs to oiled or replaced. I suggest having a fitness equipment repairman come out and see and hear the unit. it cost very little and is worth the investment
Oct 09, 2017 | Landice L7 LTd Pro Sports Trainer...
When inclining/declining it make a terrible noise.
Vision Fitness should be able to help and may be able to supply a manual
Jan 25, 2013 | Vision Fitness T9200 Treadmill
ERROR CODE E9 VISION FITNESS TREADMILL T9200
If you wish to get some details; check the site linked here. Pull up older posts treadmill . http://electro-medical.blogspot.com/ Surf the site with patience.
May 08, 2012 | Vision Fitness T9200 Premier Treadmill
I have a vision fitness treadmill T9250 and now the console display isn't working properly. Some of the
Dear Sir:
Please see the diagram attached from REED switch, adjust, clean, and tight the connector wires very well.
2) change the batteries by new ones, use the best.clean the contact batteries.
3) tight the ribbon cable from keypad .+ tight the connector from display board vs lower board.
4) after you fix it RUN THE sofware calibration for diagnose, troubleshooting, See my personal tips for help
sincerely. God bless you
Apr 30, 2012 | Vision Fitness T9250 Deluxe Folding...
I have a vision fitness treadmill. I turn on the treadmill and it starts at P1 and then it automatically goes through all the programs and sppeds until it gets to 10 miph. I have tried unplugging it. I...
It sound like either the function pad ( more likely the problem ) or the upper electronics have failed. You will need to call Vision Fitness customer support @ 1-800-335-4348
Jun 11, 2010 | Vision Fitness T9550 Folding Treadmill
Vision Fitness T9250 Simple Folding Treadmill Logo
112 people viewed this question
Top Vision Fitness Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
rattack1511
Level 1 Expert
ray gallant
Are you a Vision Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
