Question about Maxi-Cosi Baby Gear
How do I fix release catch cable on maxi-cosi is a fix base
Tried to click cable back onto catch
  • 4 Answers
SOURCE: i need full instruction manual for the maxi-Cosi Priori XP please !
Go to the maxi cosi website, for the XP model you need to go to the UK-Britain website...you can download the manual there.
Posted on Feb 15, 2009
SOURCE: Maxi Cosi Tobi straps locked
hi i had the same problem so i took it back to toys r us where i got it from, they rang manufacture and were advised that they r going to recall them as it is a fault. hope this helps
Posted on Sep 19, 2009
SOURCE: size 0 maxi-cosi sun shade
The sun shade is already on the car seat! It comes with it! When I recieved my car seat I thought it was missing this part. It is actually pushed in behind the plastic ridge at back of car seat!! I found it kind of hard to pull out but it is def there!!!
Posted on Oct 08, 2009
SOURCE: bugaboo adapters for maxi cosi got stuck to the maxicosi carseat
We have just released the Bugaboo adapters by pressing buttons on the Maxi Cosi seat and gently pulling the adapters at the same time. These buttons can be found either side on the top of the seat, next to where the seat carry handles are attached. The adapters come away very easily, no force needed. (I dont know if this is true if the adapters are in the wrong way round!)
Posted on Dec 12, 2009
SOURCE: Is Maxi-Cosi Mico Base compatible with CabrioFix?
No, they are not interchangeable.
Posted on Jan 05, 2010
I have released the hood on my 2009 Rio but now it won't catch as I close it.
Try lubricating the catch and release cable. Maybe cable hasn't released properly stopping the catch plate from springing back.
Apr 04, 2017 | Cars & Trucks
How to replace speedometer cable
No problem Henry. Reach under dash and remove the cable from the speedo. Probably just a clip to squeeze or depress. Remove the cable from the transmission and any clips that may attach it to the frame, go under hood and pull the cable and rubber boot from the firewall, pull it all the way out and discard it. all the way out and discard it. Put the new one back in the same way the old one came out and connect it to trans and through the firewall pushing the rubber boot back onto the firewall and push it back onto the speedo till the clip clicks. Your done.
Dec 01, 2014 | Toys
Samsung sp01 is undetectable through PC HDMI I am
This could be as simple as a defective HDMI cable. Have you tried connecting anything else with this cable? Have you tried another HDMI cable?
Oct 21, 2013 | Fujitsu Siemens LifeBook® C1410 PC...
The bonnet of my nissan misra wont fastern
Doe`s it click onto the secondary saftey catch?
it could be that the cable has stuck, try pushing the bonnet release handle back to it`s original postion (the opposite to how you opened it!) then try shutting it.
Mar 19, 2012 | Cars & Trucks
I took out the memory card in our z915 to put the card in a reader to transfer images onto a computer. When I tried to put the card back in, it won't catch and stay in the camera.
Here's a url so you can download a guide if you need one, just google i :-
resources.kodak.com/support/pdf/en/manuals/.../Z915_xUG_GLB_en.pdf
It shows which way the card should go in, normally they push in then press again to catch.
I prefer to download to a PC using a USB cable, keeps my grubby little fingers of the card.
Jun 25, 2011 | Kodak EasyShare Z915 Digital Camera
Bonnet cable come away fron front catch on bonnet
replace it.... buy a new cable assembly and install it (unless, of course, that's not exactly what's wrong with it). You say it keeps 'coming out'... tell you what, take a photo of 'where it's coming out' and perhaps we will be able to help you.
Jun 01, 2009 | 1994 Hyundai Excel
Bonnet catch will not engage
Had the same problem today. First I thaught the catch had slipped out or the spring that connects onto the catch had let go. I was fumblng about for ages, poking around with a screwdriver. Anyway simple answer (if you're sure no cable has broken) oil, Oil, OIL! Spray lots of oil. Push and pull the catch lever under the bonnect. Push and pull the latch which is inside the car. Click the bonnect shut. Open from the latch inside again. Repeat it a few times. Just get all the moving parts, well........ MOVING! with lotsa spray oil. This is particularly the case if you drive lots of miles and like mine ur car is dirty (5 quid for a hand car wash doesnt seem that bad now). If nothings bust it will open (and let me tell u when it does, you'll feel so damned relieved). if that doesnt do it take it to a mechanic cos u'll just frustrate urself and brake something. Good luck
Gayan
Feb 22, 2009 | 2003 Volvo V40
Handbrake adjustment?
there is a cable tha runs to each break . sometimes the cables are adjusted from the handle just move the cover from the lower part of the lever and check the cables i think it's a 7/16th bolt you use to adjust the cable might be a 1/2 in
Feb 04, 2009 | Hyundai Motor 2002 Elantra
Lexmark 6170 encoder strip reattach help needed
There is a spot where the strip goes through and it MUST be in this slot. It might be just a slot or it could be a hole it goes through. On all inkjets the strip will ALWAYS be straight and not pushed either frontward or backward, if it is, its not where is should be.
Sep 14, 2007 | Lexmark X6170 All-In-One InkJet Printer
Cannot connect to modem
if you know the cables are connected and not faulty, then it could be the fact that the network card itself is dissabled, so right click on the network icon in your taskbar and click status if showing and click enable in the next window, if when you right click on the icon in the taskbar and the option to 'connect' is displayed, click this instead. If non of the above work, you may have a faulty cable or network card.
Jul 31, 2007 | Linksys BEFSX41 Router (DHBEFSX41)
Baby Gear Logo
81 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
