Question about Stihl Garden
How do you adjust amount of oil to the bar on stihl 29 chainsaw
Amount of oil per tank of fuel has gone down alot
  • Stihl Master
  • 1,169 Answers
The adjust is on the bottom of the saw. Be aware that you may have an oil pump or driver failure.You could also have just a dirty oil pick filter.
Posted on Dec 14, 2014
Need to know what kind of oil is used in 2.0 cid gas chainsaw?
Chain oil for the chain
STIHL Bar and Chain Oil - Chainsaw Accessories ' STIHL USA
www.stihlusa.com/products/oils--lubricants-and.../oils...lubricants/chainoi... Rating: 4.5 - ‎6 reviews Don't let friction cut down your chainsaw's performance. STIHL bar and chain oil is specially formulated to adhere to your chainsaw's bar and chain, providing ...
2 stroke oil for the engine
XP® Professional Peformance 2 Cycle Engine Oil 50:1 ...
www.husqvarna.com > ... > Accessories > Lubricants & Fuels XP® Professional Peformance 2 Cycle Engine Oil 50:1. Our best ... 610 00 01-31, 6.4 oz. bottle for 2 1/2 gal. mix (50:1 Mix), $ 3.29. 610 00 01-32 ... Chainsaws.
Oils and lubricants STIHL
Feb 08, 2016 | Garden
How do I disassemble bar oiler and tank on unidentified chainsaw?
Stihl 017& 018 repair to bar oiling system, showing oil pump ...
? 12:36
www.youtube.com/watch?v=lJFAmUz49DQ
Jan 1, 2014 - Uploaded by Andy Reynolds A common fault with the Stihl 017 and 018 is low or no oil getting ... 018 repair to bar oiling system, showing oil pump feed andoil tank removal.
Sep 30, 2015 | Garden
Stihl chainsaw 210 owners mannual
Fuel needs to be mixed with 2 stroke oil at a ratio of 50:1
50 parts fuel to 1 part oil.
Also it requires 'chain oil' used as a lubricant and bar coolant, this goes in the tank beneath the exhaust.
Jan 16, 2012 | Stihl Garden
Dont no how to ajust the ioler for the bar oil uses a tank of oil to a half tank of fule burned
what brand saw? Stihl saws are made to run Stihl oil. If you are runnin other oil, the viscosity wont be the same as the pump is designed for, and the oiler may pump more then it should. The oil adjustment screw should be a single flat head set screw on the underside of your saw near the sprocket. Alot of saws are not equipped with an adjustable oiler. Professional saws and larger displacement saws will have the feature.
Sep 15, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Cant find mix fuel/oil for stihl ms 181
Model MS 181 Engine single-cylinder two-stroke Capacity 31.8cc, 1.94cu.in Bore 38mm, 1.6in Stroke 28mm, 1.1in Ignition Electronic (Breakerless) magneto Spark Plug NGK CMR6H Electrode Gap 0.5mm, 0.02in Carburetor All position diaphragm type with built-in fuel pump Fuel Tank 0.27litre Fuel mixture 50:1 with Stihl two-stroke air-cooled engine oil Catalytic Converter No Chain lubrication Automatic oil pump Oil tank 0.265 litre Weight
(dry, no bar, no chain)
4.3kg (9.5lb)
Jun 22, 2011 | Garden
My saw is two weeks old it uses 3 tanks of bar&chain oil to 1 tank of gas is there a adjustment for setting?
Take the bar and chain off and clean both thourghly. Use a small blade screwdriver to scrape built up saw dust,dirt woodchips or whatever from bar track and make sure both are in good shape. The oil port should be located by bar alignment pin.Brush it clean and if you have access to compressed air then blow out to help clear port. Turn your saw upside down and locate screw that has directional arrow to + or - to add or subtract amount of oil flow.
I would start and run saw with bar and chain installed and properly tensioned. Let saw warm up then hold saw about one inch above clean piece of wood and run at full throttle for 30 seconds.There should be a light coating of oil on board. If you have too much oil then turn screw in direction on - until you get it set where you want it. There should be a light coating of oil on chain and bar at all times.
I mostly use stihl saws and run about 1 1/2 tanks of gas per tank of oil and this works great for me. Hope this helps you. Thanks.
Feb 07, 2011 | Poulan Garden
I have a Stihl 16" 012 AVT chainsaw. I cannot get
First thing I would try is wash out the oil tank with a little bit of diesel fuel then run some thinner oil thru it to see if it gets better . I usually leave bar and chain off when I do this.. or if it is oiling but not going down the bar check the bar oil holes.
May 10, 2017 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
My Husqvarna 455 saw is only using about a 10th ot a tank of oil per tank of fuel. I can't see any oil on the chain. I just had the oil pump changed under warranty and the saw still uses very little oil....
the saw should use tank of oil to a tank or fuel.if not you will wear out chains and bars very quickly.there should be an adjustment but see as you are under warranty go back and dont take NO fof an answer
Aug 16, 2009 | Garden
Garden Logo
95 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
