Question about KitchenAid Refrigerators
For Peter Goodwin: The model is KitchenAid KBFS20ECWH - french door, bottom freezer. What problems will removing the entire filter housing cause (if it's possible to remove it)? The fridge is not/will never be connected to a water line.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 176 Answers
  • 74 Answers
SOURCE: water leaks when filter is connected
Does it leak from the back or the front of the appliance ??
Posted on Aug 28, 2008
SOURCE: cannot install water line
I too had to scratch my head to locate where to connect the water line for the ice maker. Looking at the rear of the frig on the bottom right you will see a white plastic cover that the black plastic line goes into. There is a screw on the right side. Undo the screw and then pry off the white plastic cover. You will see a black plastic cap over the threaded water line connector. This is where you connect you line as approprite. I hooked up the line and turned the water supply back on and then you have to turn on the ice maker. I works great. Problem is the manual is not clear at all. Guess they assumed that the installler would be hooking it up. Once you know what to do is is a piece of cake. Good Luck. Doug S. in Poland, OH
Posted on Oct 25, 2008
tborn6
  • 700 Answers
SOURCE: GE Profile 25.1 cu. ft. fridge is too large for door entrance
yes you can, or just removed the bottom drawer, open the upper doors and slide the refrigeraro thru the doorway by just swinging it thru. a mover friend of mine showed me that trick at it work great.
Posted on Jan 24, 2009
  • 29 Answers
SOURCE: Why does my water line shake on the back of the fridge?
Does it shake all the time
Posted on Feb 24, 2009
  • 71 Answers
SOURCE: water dispenser line leaking at bottom of freezer
if you have enough room left you can just cut out the hole and go to any hardware store and pick up a water line coupler and repair it....if it is too short or broke up inside the door then you need to remove the water/ice dispenser and pull the line through and run the new one down the track.
Posted on Oct 03, 2009
KBFS20ECWH - On delivery, large coil of white tubing behind the two crispers. What is this?
it is most likely the water line. If you are not hooking it up to water, you can remove it.
May 18, 2015 | KitchenAid KBFS20ECWH Architect II...
Kitchenaid kbfs25ewms2 freezer leaking water
Normally I would agree a water line is the issue however on this particular fridge this is not the case. If you open the freezer door, notice the placement of your hand. Unless it is dead center of the handle this is the cause of the problem and what I believe is a major design flaw. Depending if left or right handed, every time the door is opened the metal tracks that hold the door are being bent. If you remove the bottom freezer basket you will notice the back support bar that is attached to the metal rails is not longer straight.What ends up happening is, certain times when the door is pushed closed it seals completely and other times it does not. The times it does not, there is inch gap between the rubber seal on the door and the fridge itself(left or right side). The freezer warms up and items start to melt. As the cycle of freeze and thaw continues you end up with the entire basin full of ice. Eventually when the door does not shut properly and the ice melts it has nowhere to go expect your floor. This is why sometime you will have a pool of water and sometimes you won't but it always leak from a corner. Learned this first hand and ending up ruining 30sq of hardwood floor
Feb 02, 2012 | KitchenAid KBFS25EW (24.8 cu. ft.) French...
How do I remove the water filter cartridge in order to replace it?
On the link belwo page 14 and 15 will tell you how to replace the water filter. If this is not your fridge please give the correct make and model # so I can get you the right info.
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%2012828140.pdf
Jun 01, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
My freezer on the french door model is freezing over. All of my food has what appears to be snow. Why
warm air is somehow leaking into the freezer or a common problem with bottom mount doors is they get left open and that's what happens,check the gasket or the door was left open.
Apr 11, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
Where is the water filter? Can't find it to change it.
It depends on the model. For side-by-side refrigerators, the filter is usually in the grill on the freezer side (not quite centered on that door). Usually it has a cap over it that you push in to get the filter to pop out.
For French door models, the filter is usually inside the refrigerator above the top shelf (right or left side). The housing will tilt down to allow you to get at the filter.
I hope this helps.
Feb 06, 2011 | KitchenAid Refrigerators
French Door to right swing on Fridge
Go to this link and you can see all the identical sized models with a right swing door. The hinges are the same so you could easily swap them; http://www.kitchenaid.com/catalog/category.jsp?categoryId=77#85 here's a link to the user manual if you need it; http://www.kitchenaid.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202300253.pdf check page 7 and 8 for how to swap a door. Page 20 gives you contact details for spare parts. Hope this helps :)
Jun 27, 2007 | KitchenAid KBFA20ER Bottom Freezer French...
Refrigerators Logo
95 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
