Question about New Home Sewing Machines
My mother's old new home has been sitting for a couple of years now. I oiled and cleaned it today but when I tried to sew it just sits in one place. All the tensions are okay. Now what?
Model number not readable Purchased in the 1980's. Oiled and ran for 1 minute. The tensions seems to be ok although I threaded and rethreaded. Changed bobbin. All threads move easily. Machine just sits in place when you try and sew.
  • New Home Master
  • 1,860 Answers
Make sure the sewing machine is not in the darning postion, some sewing machine have a sew button an a darn button,, the sew button must be pushed or the machine will not sew.
Posted on Dec 15, 2014
Sewing machine jammed while sewing
go on line, google for- new home hf-2022 sewing machine and down load pdf manual for machine
May 10, 2013 | New Home HF-2022
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
How do you oil it
I checked a couple of sites & couldn't find anything,, I suggest
you contact babylock customer service & ask them about where
to oil the machine or if a sewing machine technican has to do it.
Aug 03, 2012 | Sewing Machines
New Home machine has not been used for about 2 years, and is very noisy and stiff. Seems to need oil but the manual says to not oil it. ??
since the machine has been sitting up for 2 years & it smells bad then the
machine needs to be serviced
Apr 14, 2012 | Sewing Machines
My New Home sewing machine has been in storage for 2 years. When I press the pressure foot, the motor just hums. Can you help me?
try oiling the machine, since you took the machine apart oil it, use only sewing machine oil, usually you can get it at a fabric store or I think wal mart sells some too.
oil the machine,, let it set for a couple of hours,, put paper towel or old towels under neath the machine because of the oil dripping
then try to turn the handwheel back & forth,, putting slight pressure but not heavy,, DO NOT FORCE IT
if it doesn't break loose oil it again & let it set another couple of hours
then try to turn the handwheel again like before
if that doesn't work then get a can of penetrating oil, & use that,, then wait a couple of minutes & try the hand wheel again & after it breaks loose then be sure to oil it again.
let me know if it helps you
Mar 30, 2012 | Sewing Machines
My bernina E65 will not work,Help
since the machine has been sitting up for close to 2 years it needs to be serviced also.
when a machine sit up the grease & oil can become yuckie & machine will not respond good & sometime not respond at all.
it's also possible that the machine can have a loose or broken part
Mar 19, 2012 | Bernina Sewing Machines
I had not used my New Home Memory Craft for some
The old oil and lubricants are most likely in some stage of solidification and caused the machine to labor to turn. This causes the safety fuse to blow so that the circuit board does not overload.
Replacing the fuse is buried deep within one for the circuit boards and requires a knowledgeable service person to extract it and also address the reason the fuse blew in the first place so that it doesn't happen again.
Jul 10, 2009 | Sewing Machines
My wife's mother had an old New Home Sewing machine. Instead of a belt drive off the motor this machine has a slip on rubber wheel about an inch in diameter that is spring loaded and presses against the...
I have these in stock. you'll need to give me the diameter of the rubber wheel as there are three different sizes. These run $5 +s/h. Stepping Stones Quilts
912-638-7128
Jun 11, 2009 | New Home L-373 Mechanical Sewing Machine
Sewing Machines Logo
85 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
