Question about NEC LT280 LCD Projector
I replaced the lamp on my NEC LT280, but am unable to reset the lamp so that the projector works again.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Whe the lamp exceeds 2100 hours (up to 3100 hours in ECO mode) of service, the projector cannot turn onand the menu is not displayed. If this happens, press the HELP button on the remote for 10 seconds to reset the lamp clock back to zero. When the lamp clock is reset to zero, the LAMP indicator goes out.
Here is the URL for the User Manual:
http://www.necdisplay.com/documents/UserManuals/LT380_user_manual.pdf
Posted on Dec 19, 2014
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
Will not turn on. power light is orange
Many projectors will not turn on, or will turn on and immediately shut down, when the lamp needs replacing. How long has the projector been in use? Most lamps say they're good for up to 2000 hours, but in my experience they're only good for 1400 to 1500 hours. Also, check that the electrical cord is attached tight.
Jan 13, 2011 | NEC MultiSync LT280 LCD Projector
Colour out of nom
swap the cables and reset the settings to factory default. if that doesn't help, you may need to replace the polarizers.
Jan 07, 2010 | NEC MultiSync LT280 LCD Projector
Nec lt380 changed lamp for new one still doesnt work?
If the unit is powering up but the lamp is not igniting, most likely there is a problem with the ballast.(Ballast is the circuit that starts and then maintains lamp current) When starting the projector, it is sometimes possible to look directly into the lens and see small "lightning" flashes. This is the high voltage ignition current trying to start an electrical arc in the lamp. You can also hear a "clicking" sound--same thing. If the ballast is defective, the unit must be repaired at a facility--send it in directly--not through a store. If the unit is totally dead(no lights at all), there usually is a main fuse located near the power cord(inside the unit) that blows. If you've never had tech training, don't attempt to open the unit--it is very easy to accidentally damage components unless you know exactly how to remove the top cover.
Dec 30, 2009 | NEC MultiSync LT280 LCD Projector
Just replaced vt700 lamp. projector still indicating faulty lamp. i also reset the lamp hrs by pressing help on remote. can any one help thanks
Try the old lamp again and reset again and see if that works. When you originally replaced the lamp did it give you a warning that replacement was required or did it just stop? I haven't worked on that model before but you may require a new Ballast (power supply ) that runs the lamp (technician job usually)
Dec 26, 2009 | NEC REPLACEMENT LAMP FOR VT700
Replcing bulb
There is lamp cover at bottom of projector, unscrew it, take it off, you will see Lamp inside that also fixed with screw, unscrew it and take it out, place new lamp and put thing in same way.
Jun 09, 2009 | NEC MultiSync LT280 LCD Projector
How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Sep 20, 2008 | NEC MultiSync MT830 Multimedia Projector
NEC LT30 - Lamp dosen't turn on.
From the manual: To reset the lamp hold down the "HELP" button on the remote for 10 sec and the lamp indicator will turn off. Then start up the projector again.
It worked for me!
Mar 17, 2008 | NEC LT30 Multimedia Projector
NEC LT280 LCD Projector Logo
298 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
