We rent and have a baxi Bermuda sp we have had a few problems with it in the past ie not lighting had a new spark bit fitted but today we came home from shopping to find the gas gad run out ( on the pre pay netter ) so we got some more and my partner tried to light the boiler . On the slow release of the button the boiler flew a large amount of flames out and made a very loud bang causing the top of the fire place and the sides to blow off . We have turned the gas if and left a message at the estate agents . But I'm a little peed off with then trying to prolong replacing it now and am very anxious that it's just not safe . What would cause it to do this ? Is it safe ? Any info would be appreciated
namizhka
  • 148 Answers
SOURCE: natural gas patio heater
MAY I KNOW THE EXACT MODEL # OF YOUR UNIT.
Posted on Sep 27, 2008
  • 2458 Answers
SOURCE: Dayton 3VE51 oil fired heater
Hi check for blockage in the flue check out the pressure switch, check heat exchanger
Posted on Feb 08, 2010
  • 2458 Answers
SOURCE: got a baxi bermuda 552, back boiler not working
Hi clean pilot light and change the thermocouple , you will have to remove the gasfire to get to the boiler if unsure best get a gas fitter to do this as this is not easy to explaine , simple job but you have to know what you are doing , it might be you need a service on the bbu and the gasfire then the thermocouple could be done at this time.
Posted on Feb 20, 2010
  • 120 Answers
SOURCE: how to light pilot light for baxi bermuda sp3
Go to this link.Bottom of page 15 on the manual
http://www.aroundtownflats.com/manuals/Boilers/Baxi/BAXI%20BERMUDA%20SP3%20GCNo.37-077-63.pdf
Basically it says (turn on the power first) Turn the knob to the the star/flame marking. Push the knob in, hold it for approximately 10 seconds. Release and check the small flame is lit. Now turn it to your desired heat setting.
Posted on Jul 21, 2010
  • 13 Answers
SOURCE: pilot light on baxi bermuda
Sometimes the thermostat wire (not sure of the technical name) gets oxidized and can't sense the heat (it's there as a safety measure so that when the pilot light goes out, the gas shuts off). If it isn't to hard to get to, sometimes you can use some aluminum foil to clean the wire so that it senses the heat of the pilot light flame. Make sure the main unit is off, and let the unit sit for awhile to make sure there is no residual gas hanging around. If this doesn't work, you might have to get a specialist out to replace that piece. Hope this helps.
Posted on Feb 17, 2011
Were can i get a mannual for a baxi bermuda 50/5inset back boiler fire
You can download one from there wed site baxi potterton wed site
Apr 10, 2012 | Heating & Cooling
Instructions on how to re light my pilot light onb a baxi bermuda back boiler picture if possible thanks
http://www.baxi.co.uk/products/bermuda-back-boiler-unit.htm?view=download , i hope that will help
Feb 16, 2011 | Heating & Cooling
Service manual for baxi bermuda 572 boiler
Try;http://www.baxi.co.uk/about/products.htm "Product Literature" on left side of page and supply needed info. Failing that, I generally type the manufacturer's name into a google search then space, then .pdf.
Dec 03, 2010 | Heating & Cooling
Where would i get a baxi bermuda 552 owners manual
on the baxi potterton wed site you can down load them from there , but a 552 is old now you can but try
Sep 01, 2010 | Heating & Cooling
Baxi Bermuda VP gas fire. No spark to ignite the gas burner, has the spark generator given up?
try cleanig the spark elctrode could be dirty use some steel wool carefully to clean it
Jul 24, 2010 | Heating & Cooling
How to light pilot light for baxi bermuda sp3
Jul 21, 2010 | Heating & Cooling
ENGLAND, UK. DOMESTIC HOUSE CENTRAL HEATING. Baxi Bermuda
try bleeding the radiators in the order of downstairs first and then the upstairs and try to bleed them in the order they fill, trapped air can take a while to escape, a good sign on a radiator is the bottoms being warm where the tops( where the air is trapped) stays cooler, a sure sign to which radiator needs bleedin, hope this helps, colin
Apr 02, 2010 | Heating & Cooling
Got a baxi bermuda 552, back boiler not working
Feb 20, 2010 | Heating & Cooling
How to light pilot light on back boiler?
Hi. we have a baxi bermuda. I know that you need to hold in the silver button on the left while repeatedly pressing red/ignighter button until pilot is lit. Hold in the silver button for at least another 30 seconds.
Good luck, ours wont light anymore so was on here looking for advice.
Cheryl
May 07, 2009 | Kitchen Ranges
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
