Question about Kenmore Washing Machines
Blows breaker when starting drain
Kenmore model 20692. Washes ok. When it goes to start the drain cycle there is a buzzing sound and after 10 seconds or so the breaker trips.
  • 43 Answers
Sounds like you have a shorted drain pump.
Posted on Dec 15, 2014
Dryer starts about 45 seconds into the cycle lights come on and then it starts beeping like the end of the cycle. 10 seconds later off. Very warm on top of the machine.
See my tip for buzzing dryer. Check Owner's manual, Troubleshooting. Sounds like air is not moveing and High temp cut off saftey switch doesn't like the lack of air flow. Duct clean? Check air flow from the outdoor vent. Clean vent tube/s
Mar 04, 2015 | Kenmore Dryers
Top Loading Washing machine Stopped working mid-load
You may find a piece of clothing has jammed the lower spinner or the mechanism is worn and jammed up.
Mar 06, 2014 | Washing Machines
WFW94HEXW door won't unlock and Door Lock isn't lit
if you machine is warranty you must call to the whirlpool, and get the assistance via online chat. However you must wait about 180 seconds since you did the command STOP, and stop the motor, fi the water level is higher must be drain before the latch door unlock.
2) if do not obey press and hold END OF CYCLE, wait about 10seconds
3) reset the machine unplugged from wall by 45 minutes, and then plug again, and turn on and unlock the door
God bless you
Jun 21, 2012 | Washing Machines
My kenmore diswasher model#363.153221100 when i start the wash cycle starts to fill up with water but then drains the water back out immediately and the wash cycle never starts.
Hello & Welcome to FixYa
This problem is caused when the motor goes bad and needs replacement. The control will fill water and then sends signal to the motor to start a cycle, if it won't work then it will drain the water and so won't start the cycle. However, it can also be a bad door latch-lock assembly as if the control senses that the door is not closed it won't start the cycle. If you hear any humming buzzing sound from the bottom of the unit then replace the motor if not then replace the latch assembly. Please get back to me if you have any other questions.
Kevin
Mar 15, 2011 | Kenmore Dishwashers
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
It fills with water, washes, then makes a buzzing sound.
This is a failed timer mechanism. replacing this failed mech will fix your issue.
Jun 19, 2009 | Whirlpool Washing Machines
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Please help
it is the timer or, it may be a short of some kind
Apr 19, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
35 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
