Question about Home Security
I have replaced the batteries on the S3877 and nothing happens, no lights, no movement
Batteries have been battery pack was sanded to remove corrosion, new batteries inserted and nothing happens ie no light, no current seems to reach the electronic pad. Any suggestion?
I have the same issue, have you fixed the problem? thanks.
Posted on Jun 24, 2015
How do I get my Sentry Safe S3877 to open when one of the wire is dangling from the battery pack?
Check, you are connecting to the correct spot. That is the place the wire broke off.
It could be you only are using 2 or 3 from the four batteries. Then the voltage is always to low.
Then check you got the right batteries. Never use manganese (Zinc-Carbon) batteries. They don't have enough capacity and can start leaking.
Sep 27, 2014 | Horace Small HS2148 Mens Sentry Plus...
I have a Sentry safe S3877 the batteries were replaced with new it still gives the error beeps for batteries need to be replaced the safe will not open, how can I get the safe to open?
A1 Locksmith Burlingame CA Once you get the error light that means you are entering a user code that was deleted when the batteries went dead . Simply replace the batteries then use the master code in your owners manual to open the safe. Reprogram new user code instructions bottom of this page.
Apr 17, 2013 | Sentry Fireproof Safe
Have only used a couple of times battery will not charge I checked the fuse charger shows orange light no light on charge
It sounds like the batteries have gone bad and need to be replaced.
The batteries contain a gel that needs to have current run through it on a regular basis (at least 8 hours once a week) or it will solidify. If you attach the charger, what will most likely happen is the green light will either stay green or go to green after a very short time. When you turn on the power chair, nothing happens. The charger will indicate the batteries are full, but instead of being full of pwer, they are full of crud. Your warranty will most likely not cover replacment as this is due to customer neglect, but your insurance may still cover the replacement if you can wait for the process to go through. Otherwise, you will need to replace the batteries on your own. Good luck!
Nov 06, 2010 | Pride Mobility Products Go-Go Elite...
I replaced the batteries in my daughters "Butterscotch" but she still does nothing. No sound or movement at all. HELP!
make sure the batteries are in the right way and contacts are clean , try new batteries from a fresh pack,make sure switch is on if it has one, then if that doesnt work, beat butterscotch on the floor a few times, may get him going (seriously)
Jul 30, 2009 | Hasbro Fur Real Friends Smores Pony
Wii remote works with normal batteries but not with battery pack
same poblem if this is solved cud somwon plz send me the solution to jordanchattington@hotmail.com cheers
Jun 30, 2009 | Nintendo Wii Remote Controller
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
Sentry s3877 battery compartment broke
I had the same problem with my Sentry S3877. I found the exact 4-battery replacement (with snap attachment on top!) at an online electronics.retailer, but had to purchase a lot of three. I don't need the other two, so I'll sell them for just $6 each to the first two folks to contact me mark@irregardless.net.
Oh, by the way, once the batteries went dead, you lost your combination! When you pop the new battery compartment in, the factory default combination will be in effect. That default combination is in your user's manual. I'm currently searching frantically for mine! Gee, how could I have misplaced it ... I just had it in my hands when I purchased the safe 10 years ago !!!
Anyone know the default combo for the S3877?
---- Mark
Sep 15, 2008 | Sentry Fireproof Safe
Zoom
If the batteries are a common type, install them into another device to see if they really are still OK or buy a cheap digital multimeter or battery tester.
The latter can be bought at the chain hardware stores or Radio Shack and draw some current to lightly test the load capabilities of them.
These batteries do fail to a short; NICads are the worst but lithium ion and NiMh can fail as well.
The 'sand' diagnosis may be right but what you describe could still be only batteries.
Aug 25, 2008 | Olympus FE-230 Digital Camera
Kodak easyshare C530
the problem is with the power - the lens being stuck out is a side effect
if there's enough/right power - the lens would retract if you shut if off. it shuts back off by itself that's why it won't retract and power is not sufficient for the lens lens to go back in
if your getting a red light, that means it's not totally dead
are you using alkalines?
the response of the cam towards an alkaline batt is very upredictable, sometimes it would take 30 pics, 10, 2, sometimes it won't even come on, just a blinking light
please use lithium batteries or ni-mh
if you are already usign a new set of lithium and it's doing the same thing, please arrange repair through www.kodak.com/go/itg
Jan 18, 2008 | Kodak EasyShare C315 Digital Camera
Home Security Logo
152 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
