Question about ASUS Vivo Tab TF810C - tablet - Windows 8 - 64 GB - 11.6"
Reset asus vivo tab via sd card
Tried to reset manually with success up to marking the check box in the agreement section. Screen is cracked diagonally, and I can't mark the box in this section, and the screen does not rotate in this area
Unlock cracked screen nextbook 8
On some touch screen device, the tough part of the screen won't work when it has a crack. So it ill be difficult to unlock the screen as long as it has a crack. Ask yourself if it is worth repairing the screen, when you know what a repair shop asks for the repair and what a new device costs.
Success
Apr 25, 2015 | Nextbook Premium 8 Se Android
I lost all of my books, how do I get them back?
All Tablets are not the same ... may be if you give us the mark and model number we would be able to help you
Feb 02, 2015 | Tablets & eReaders
Fix motorola xoom
there are places that replace them Do a google search
Feb 01, 2015 | Motorola Mobility XOOM Android Tablet
Cracked screen on my Trio tablet, can see the display but it won't respond to touch. It's not under warranty. Can I fix it myself?
Yes touch screens are very sensetive.Because of the cracks on the screen ,the board can't read the command.The screen can be replaced only if you know what you doing however it can cost upto and around between $250 and $350 mark to repair by a professional.to get better ideas of what your up for research on Utube .
Jan 06, 2014 | Samsung Galaxy Tab 3 10.1" Dual Core...
Cannot install learning lodge - cannot download content for purchase
Are you getting any error message when installing the Learning Lodge?
To delete info on toy go to Settings>>My Name>>type R-E-S-E-T then tap the check mark on top right corner of the screen. Toy will turn off automatically if reset is successful.
Dec 30, 2013 | Vtech InnoTab 3S The Wi-Fi Learning App...
Paloroid 7
Hi Kidada
Press power on and volume up button together, this will reset. If you get the Android icon with an exclamation mark, press down volume, select master reset then reboot.
Gary
Jul 30, 2013 | Polaroid pmp280c-4
Can't turn off
You can solve many troubles by restoring factory setting.
Press Home Key > Settings > Privacy.
Press Factory data reset > Reset phone > Erase everything. All settings will be restored
Jan 09, 2013 | ZTE V9 Smartpad Android Internet Tablet
I turn off my cookies and i need to turn it back on
Samsung Galaxy Tab Cookies on/off
1.From a home screen, select Applications.
2.Select Browser.
3.Press the Menu button.
4.Select Settings.From the Privacy settings section, select Accept cookies to enable / disable.
5.Enabled when a green check mark is present.
Jan 06, 2012 | Samsung Galaxy Tab Tablet PC
ASUS Vivo Tab TF810C - tablet - Windows 8 - 64 GB - 11.6" Logo
105 people viewed this question
Top ASUS Tablets & eReaders Experts
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
