Question about Schwinn City 1- 7 speed ladies 2013
Adjust chain on a womans city ii 3 speed internal gear rear wheel
    Habit-Forming:
  • 54 Answers
Loosen the rear wheel nuts. Move the axle forward to loosen or backward to tighten, keeping the tire spaced equally between frame and brake. Adjust so that chain is in that "sweet spot" between binding because it's too tight and slapping against the chain guard because it's too loose.
Some models have screws in the frame at the rear axle that make this job easier. Note that it's likely that you'll need to adjust the gear shift cable after moving the axle. Good luck, and happy riding!
Posted on Feb 01, 2015
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: When I ride up a
Before you go tearing everything apart it might help to understand how multi-speed derailleur shifting systems work.
Derailleur Adjustment: (likely cause of your problem)
http://sheldonbrown.com/derailer-adjustment.html
Shifting:
http://www.sheldonbrown.com/gears.html
Cassettes and Freehubs:
http://sheldonbrown.com/k7.html
Chains: (which also covers worn gear teeth, another possible cause)
http://sheldonbrown.com/chains.html
Of course everything requires special tools and procedures.
http://www.parktool.com/blog/repair-help
http://www.parktool.com/blog/repair-help/categories/cassette-and-freewheel-service
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Have fun.
Posted on Jan 24, 2011
  • 109 Answers
SOURCE: Meridian Adult 26-Inch 3-Wheel Bike: Schwinn Meridian Tricycle rear brake adjustment...
Wow Lady Hawk, it's hard to tell from what you've said. I've seen chains jump off their gear and get jammed, preventing the bike from moving. If the chain is off, you need to unjam it, then properly install it on the back gear. Next place the chain on one or two top teeth /cogs of the front gear. Next you turn the crank forward and this will move the chain forward onto the front gear.
Posted on Jul 22, 2013
Adjust chain tension on 2013 city II 3 speed internal gear hub
With the right wrench loosen the two rear wheel's axle nuts a little bit so you can slide the wheel back to tighten the drive chain's drooping. Be sure the wheel is still staying centered between the rear frame's arms. Tighten the two nuts each only a 1/4 turn at a time and alternate the tightening of each nut until they are very tight. The chain is allowed to have a little 1/4" droop. Do not make it very tight.
Dec 14, 2014 | Schwinn Cycling
Removal of rear wheel with internal geared 3-speed and coaster brake hub
Find the joiner link on the chain, remove the retainer clip followed by the link. Remove the chain. Remove the bolt holding the brake arm to the frame. Loosen the axle bolts on the wheel enough to be able to slide the rear wheel out of its slots on the frame.
Feb 24, 2012 | Cycling
I have a honda trx 350 es my problem is it wont go into any gear the motor was clicking but now its gone dead
Have a helper lift the rear wheel of the bicycle slightly off the ground.
Kneel beside the bike and turn the pedals slowly by hand. Using the shift lever, adjust the front derailleur so that it rests at about the midpoint of its movement range.
If the initial problem is that the chain won't shift onto the largest rear gear, locate the two small side-by-side adjustment screws on the rear derailleur. Turn the left (or upper) adjustment screw counterclockwise a quarter turn with a small Phillips screwdriver. If the initial problem is that the chain won't shift onto the smallest rear gear, skip to step 6.
Continue turning the pedals and shift through all the rear gears. If the chain will still not go onto the largest rear gear, shift the chain back down to the smallest rear gear. Turn the right (or lower) adjustment screw clockwise as far as possible before the chain begins to click or rattle.
5
Shift through the gears again to test. If necessary, turn the left (or upper) screw counterclockwise another quarter turn.
6
If the initial problem is that the chain won't shift onto the smallest rear gear, begin by turning the right (or lower) adjustment screw counterclockwise a quarter turn. Shift through the gears to test.
7
If the chain still won't go onto the smallest rear gear, shift the chain to the largest rear gear. Turn the left (or upper) adjustment screw clockwise as far as possible before the chain begins to click or rattle. Shift through all the gears to test.
8
Follow steps 1 through 7 for the front derailleur, which operates on exactly the same mechanism as the rear derailleur (you still lift the rear wheel in step 1). There are two side-by-side adjusting screws that control alignment.
If otherwise,
Tighten the high gear screw, the one that hits a cam when you shift to the smallest sprocket, until you can no longer shift into high gear. Put the shifter in high gear position and while turning the pedals, unscrew the high gear screw until the system engages high gear again. Shift between high gear and the second smallest several times, backing the screw out a little more, just until the derailleur shifts smoothly.
2. Tighten the low gear screw until you no longer get first gear. Repeat the process for this low gear limit - back the screw out just until the bike shifts smoothly from the second largest to the largest sprocket.
3. If you cannot engage high or low gear, or if the above technique does not work for high or low gear, the cable may be improperly adjusted.
Shift into high gear and push the shifter all the way to the end of its travel. Loosen the cable inner wire anchor bolt. That's the bolt with a hole through which the derailleur control wire is clamped. Pull the slack out of the wire, and retighten the anchor bolt.
If your bike has index shifting, you'll find an adjusting barrel either at the derailleur or the shifter. The adjusting barrel is a hollow screw at which the cable outer housing stops, but which the inner wire continues through. Fine adjust the cable tension by turning the adjusting barrel until the clicks on the shifter correspond with proper shifting at the derailleur.
If your bicycle does not engage high gear, or is slow to engage high gear, even though properly adjusted, the cable is probably the culprit. Replace the sticky or rusted cable, and the problem will usually go away.
If you have done everything right, but the bicycle does not shift reliably, the most common reason is that the chain and freewheel are too worn to work properly. If you replace one, you must replace both. A new chain on an old freewheel or visa versa usually skips, and the new part wears out very quickly.
Another possibility is a bent derailleur. The guide pulleys, those little wheels that take up the chain slack, must pivot on the same plane as the freewheel sprockets. Derailleurs become bent when the bike falls over on the right-hand side. Whenever you set a bicycle down, or put it in a car, set it on its left side to protect the derailleur. You can sometimes straighten out a bent derailleur by simply bending it back and readjusting the limit screws.
Hoping this will help to solve the problem, do take care....
Sep 19, 2011 | Quad Cycling
How to adjust front derallier on fuji 18 speed
You will need to raise the back wheel to perform these adjustments... so that you can activate the pedals and oberve closely the functioning, as you adjust....
On the tube mounting: The derailleur needs to just clear the teeth of the front chain wheels, as it moves from one to the other. It needs to be square with the chain wheels.
The other adjustments are limiting in nature. You need the derailleur to not move the chain off of the outside of either front chain wheel. as you get closer, move the rear derailleur to extremes and then shift the front derailleur, slow and fast..... Limit is correct when you can move the derailleur so as to not ride on the chain, but not throw the chain off the wheels.
Sometimes, guys turn the front derailleur, slightly so that the last portion of the derailleur body gives the chain a little boost to the bigger gear...This is just a very small amount. Sometimes it just works better that way.
Nov 22, 2010 | Shimano 24 Speed Road Racing Bike Bicycle...
We have an 18" boys huffy bike and the chain keeps falling off. How can I repair.
If a single speed bike loosen the rear wheel and pull it back away from the pedals to get the chain tighter
If it has multi gears the arm hanging down has a ser screw that will need to be adjusted to align the chain to stop at the last gear
May 20, 2010 | Cycling
I need to tighten the chain on my derbi cross city 125
looks like you have a nut at the rear of thr swing arm, one on each side, these are the rear wheel/chain adjusters. slacken the wheel nut and then adjust the nuts, there should be some kind of markings on the swingarm so you can get both sides the same. when done tighten the wheel nut and you are done
Mar 25, 2009 | 2008 Derbi Cross city
Tourqe
going to a 42 tooth rear which I'm hoping will fit with a 15 front has anyone managed this without lengthening the chain? i also need the torque settings for the rear wheel axle and sprocket retaining bolts does anyone have them to hand please? TIAI have the 15/42 on mine, it is tight but you should have between 5-10mm of your chain adjustment bolt sticking out of the locknut once it is on and adjusted,,,
Nov 10, 2008 | 1999 Ducati Monster 600 - Dark - City -...
Schwinn City 1- 7 speed ladies 2013 Logo
102 people viewed this question
Top Schwinn Cycling Experts
Tony
Joseph Hoffmann
numbers819
Level 1 Expert
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
